Gassing up a 2010 Cali | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Tides, Oct 4, 2015.
  1. Tides
    Tides Karting
    Sep 5, 2015
    53
    Hi - just morphed from a 997 turbo cab to a 2010 Cali. - does anyone have a problem with blow back when gassing up - can't seem to find a sweet spot angle for the pump nozzle. -
  2. DavidJames1
    DavidJames1 Formula 3
    Mar 6, 2010
    1,800
    Bangkok, Thailand
    My solution was to simply put the nozzle in sideways - worked every time.
  3. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    I've been having the same problem. I'll give this a try. Thanks!
  4. Brumma
    Brumma Karting
    Jan 24, 2015
    119
    West Hollywood, CA
    Christopher
    Same problem. Only pressing the trigger to the slow fueling speed (first detent) and/or rotating the nozzle 45 degrees to one side seems to work for me.
  5. jcavalie
    jcavalie Formula Junior Owner Rossa Subscribed
    Jun 4, 2005
    660
    Oakland, CA
    Jim
    I fill mine with the gas nozzle in upside down. Seems to solve the issue. Alternatively, if you use your other hand and pull the vapor shroud on the nozzle back slightly, it seems to do the trick also. But upside down seems easiest to me.
