Gauge lights flicker on 97 355 | FerrariChat
Discussion in 'Technical Q&A' started by billwann, Dec 15, 2004.
  1. billwann
    billwann Formula Junior
    Jan 5, 2004
    324
    Bristol Wisconsin .
    Bill Wann
    At night when I have the headlighs on the gauge lights flicker , just the ones under the little bonnet thou, spedo , Tack ,ect .Any ideas what this minght be ?
  2. Robin
    Robin F1 Rookie
    Nov 1, 2003
    2,931
    Arlington, VA
    Loose connection maybe? My 99 355F1 lights change intensity each time I shift. Not sure if the alternator is up to par... If they're actually flickering though, it sounds like a bulb or wiring connection is the culprit. Does it just flicker randomly or only when you drive on rough roads or take a hard corner?
    -R
