GD epoxy floor fix! | FerrariChat
GD epoxy floor fix!
Discussion in 'Detailing & Showroom' started by Juan-Manuel Fantango, Feb 14, 2019.
  1. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,609
    Juan
    Ok, don't care what you say, every, EVERY, epoxy floor or painted floor, has done this for me-had a tire peel the paint up or leave a unsightly stain.
    I've ordered the ******** little tire pads that you drive up and they are expensive only because they don't work well for me, are often too small, you have to glue them or double side tape down yada yada yada ********.
    So I found a solution that works for me. Tractor supply has these horse trailer mats (keeps the horses from slipping in the trailers) for 20 a pop. Huge flexible mats in solid heavy duty rubber. In this application I think it will work well for my daily driver. Thinking about cutting them down, but all I have to do is drive up on them, don't have to be perfect as they are so large.
    I am sure there are other options such as flat stainless steel or other materials. For daily drivers these so far seem to do the trick.
    BTW, what causes the floors to peel? Seems I've heard it's driving the tires in warm or hot? These mats are rubber, like the tires. I wonder if they will cause any issues....will find out soon. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Christian.Fr and flash32 like this.
  2. energy88
    energy88 Three Time F1 World Champ
    32,169
    West of Fredericksburg, VA
    ^^^ Hope the mats don't get "glued" to the floor next! :eek:
  3. LBBP
    LBBP Formula Junior
  4. Juan-Manuel Fantango
    14,609
    Juan
    Thanks, those do look thiner. The one thing I do like about these mats is that they are firm, yet spongy if that makes sense. I was even wondering if they might help somewhat with flat spotting of the other cars. That said, I think they would not give as much as would be needed like the tire pads you purchase just of this very reason.
    Maybe for storage I need the for the collector cars.
  5. Jaguar36
    Jaguar36 Formula 3
    1,079
    Cherry Hill, NJ
    Why bother putting a fancy epoxy floor down if you're just going to put those ugly mats on top of it?
  6. Juan-Manuel Fantango
    14,609
    Juan
    Yeah I get it, but that rubber for the truck at least is more functional, and I could cut them down to a smaller version (cut has to be perfect). For the other garage, I guess I could just use oriental rugs. Image Unavailable, Please Login Image Unavailable, Please Login
  7. Culprit
    Culprit Formula Junior
    503
    Santa Ana, CA
    Ian
    I realized my floor peels every time I park with wet tires. I might need to pick up a few of these mats.
    Eventually I'll have the concrete sanded down and polished like you see at Home Depot stores etc. The floor will then look cool and industrial-like without any top coating to peel off.
  8. Shaun Oriold1
    Shaun Oriold1 Karting
    Mar 21, 2008
    206
    Burlington, Ontario. Canada
    shaun
    My company does epoxy floors, so I'm speaking from experience. Floors dont peel if prepared properly. And if the concrete is in good shape too. If the concrete is grinded down or shot blasted then the epoxy will permanently bond to the concrete. Now, if the concrete is poor it can peel up, but it would take some concrete with it - not like you show. Its hard to tell, but that floor doesnt look like it was prepared at all. If it was professionally installed, then call the company back and get them to fix it. Its an easy fix. We grind our floors way more than necessary as I never want to replace/ or fix a floor, the additional cost of diamonds, or extra material needed is significantly cheaper than fixing a floor.
    At my shop, I regularly do burnouts on the floor, and dont have issues. My guys hate it, but I want to see how much abuse the floor can take. I've yet to have any issues with my own floors ( houses, and shops) or any customers' floors. I bought out a company a bunch of years ago, and they had issues on their floors, and every time it came down to poor prep.
    Shaun
    Jaguar36 and 12097 like this.
  9. Juan-Manuel Fantango
    14,609
    Juan
    Funny guy said same thing (that his floors never peel) but I hear what you are saying. Makes sense as it obviously did not bond properly.
    Question: on the other grey floor painted garage we have; what causes the black tire pattern marks from where the tires sit?
  10. Shaun Oriold1
    Mar 21, 2008
    206
    shaun
    Its one thing to say they never peel, but he should be there to correct it if it does. We recently did a repair on a floor where the homeowner ripped up a corner of their garage to run in floor heating in the driveway. It was 95% undetectable, if we had re-clearcoated the whole floor it would have been perfect. but they didnt want to pay for it
    As for bonding, my biggest complaint with floor coating companies, is that they want to get in, and out quick. They do poor prep, and use a quick curing basecoat, so they can move onto the top coat in a single day. A good epoxy basecoat cures slow, bonds proper, and is perfect every time. Do you know if they used a polyaspartic basecoat? -but maybe called it epoxy, just 'cause its easier to say.
    As for black marks on the floor. Its usually dirt. We tell out customers to use simple green on any stains. If they're super stubborn, then a bunch of hot water, with simple green siting on the floor for a while takes care of most stains with some light rubbing with a brush. What concerns me slightly is cheap tires, and their unknown chemical makeup -that could potentially leech into the floor if its full of solvents.
