GE Aircraft Engine Commercial | FerrariChat
Discussion in 'Aviation Chat' started by UroTrash, Sep 19, 2009.
  1. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
  2. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    Tangentially, those wind mills are really cool IMHO. Why are they considered an eyesore? I think they are elegant and cool.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Sep 19, 2009
    I think it's all the dead birds littering the ground around them that's the problem. ;)
    or maybe this :D
  4. GuyIncognito
    99,862
    hmmm. good question. would seem to make more sense to be metric...
  5. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    Well, GE is a US company so it would use US sized bolts and nuts. With the obvious reason being Metric is more universal around the world, why would Metric better? Don't the US sized bolts hold as well?;)
  6. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Then there is always the issues of lightning strikes. The Wind farm here in Cent MT has had 3 generators go down recently due to lightning damage. Each one had to have all 3 blade replaced.
    This factor along with seeing half of the windmills with the blades feathered while the others are running and generating. I don't see how this can be a source of cheap electricity when 50% of time they are idle.
  7. GuyIncognito
    99,862
    Aerodynamics only applies to the metric system. Duh :D
  8. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    #8 solofast, Sep 20, 2009
    Aircraft engines are, still, for the most still use the the SAE/English fasteners and are designed in English units. That's why, if you look at an aircraft engine part drawing the dimensions won't be even numbers in Metric units. The T800 was an exception becaused it used spline drive nuts and bolts and that cost a fortune to implement.
    Virtually all of the fasteners in turbine engines are AN/NAS/MIL standard. In a turbine you need fasteners that are made out of exotic high temperature materials like A286. These fasteners are reduced head, 12 point bolts and nuts that are a lot lighter than conventional fasteners. If you look at a typical flange in a turbine engine, there are literally hundreds of small nut and bolts holding things together. The weight of fasteners is a major issue, so conventional fasteners aren't an option.
    You could use a meteric fastener, but the AN and Mil fasteners give you a standard to design to with accepted limits for strength at temperature. You would have to spend a forutne to create a standard to replace that and aircraft engines aren't like cars, we don't make that many of them. Not sure what they use in Europe, but here in the U.S. even the engines we are designing today are still using the English system.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's a commercial intended for a US market.
    "eleven sixteenths" rolls off the tongue better than "seventeen milimeter".
    It might be as simple as that. :D
  10. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    Thanks!!!!
  11. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Probably truth in that too..
    Also in most cases we don't use open end wrenches on anything since they don't work too well on a 12 pt nut, but hey, it makes a good commercial.....
  12. Etcetera
    Etcetera Two Time F1 World Champ
    23,992
    C6H14O5
    I was a mechanic on F-15's, and we used crescent wrenches and vice grips almost exclusively.
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #13 2NA, Sep 20, 2009
    Certainly one of these as well :D
  14. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Whitworth gentlemen, specifically British Standard Whitworth!
    KevFla
  15. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Aside from the technical aspects, I think that this crybaby new-age whine over jet engines (of all things) - is endangering my flat screen.
    I have locked up the handguns.
  16. Scaramouche
    Scaramouche Formula 3
    Oct 6, 2007
    1,459
    Ostraya
    Red Power Ranga
    #16 Scaramouche, Sep 22, 2009
