gear box oil change 2nd gear better | FerrariChat
Discussion in 'Technical Q&A' started by zsnnf, Mar 29, 2004.
  1. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    I know there has been many threads on this topic. Sorry if it is a repeat.
    2nd gear has been hard to engage when my car when cold. I sort of thought I would just have deal with it or rebuild the gearbox. I have about 30K miles on it. Well, I changed the gearbox oil this weekend to Torco 75-90 and on the first shift cold it went right in. I have used this oil in my race car up to 230 mph so I know it works, but I was real surprised how much better the cold shift was.
    Rick
  2. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    #2 Chiaro_Slag, Mar 29, 2004
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    What model was this in? You list an F40 in your personal info...
  4. mondialmerle
    mondialmerle Karting
    Nov 9, 2003
    165
    Egg Harbor Township,NJ
    Merle Graham
    THANKS FOR THE POST. WHERE CAN I FIND THIS BRAND. I WORK AT A DEALERSHIP AND I'VE NEVER HEARD OF IT.
  5. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    Well, That's ME under the F40 in the dark............
    You can find Torco at www.torcoracingoils.com
    Hope this helps.
    Rick
  6. f355spider
    f355spider F1 World Champ
    18,055
    have you noticed any limited slip noise (or chatter) when making a 90 degree turn from a stop, accelerating briskly? I noticed this product does not have the limited slip additive, and the note that it will need to be added.
    Redline recommends adding some to their "NS" or non slip gear oil.
  7. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    We did a tight 360, a few 90s and a few full power passes with no noises yet. I do have the additive if needed. I'm not sure how the additive will effect the gearbox though.
  8. f355spider
    18,055
    Thanks for the info. The more feedback on peoples experiences with different products the better. Based on Redline's recommendation, I used their 75w-90 NS product, but within a month, noticed some noise and vibration when making a sharp 90 degree turn coming out of parking lots. Adding 2% slip additive did the trick. All is fine now. Their standard 75w-90 gear oil (with the slip additive) is 5%, and their concern was that 5% would be too much, and might cause problems for the synchros (crunching). Not sure if they are being overly cautious or not as I have heard of people using the standard Redline stuff with no problem. A friend recently had Redline MTL installed at that seemed to be working well too. Though MTL is not recommended as it is less viscious and GL4 rated.
  9. zsnnf
    zsnnf Formula 3
    Sep 11, 2003
    1,877
    Dave,
    I went thrugh all the NS no NS with Redline in my Corvette transmissions too.
    Torco makes a RTF (racing transmission fluid) But the F40 gearbox cooler has a spring that is viscosity sensitive and the RTF is too thin.
    I will keep aware of any chatter or gear noises and let you know. I have a busy weekend planned with the Redhead.
    Rick
