Gear box oil | FerrariChat
Gear box oil
Discussion in '348/355' started by fxdwgs, Jul 15, 2007.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Just emptied the gear box from that old witchp1ss.
    Bought some extremely expensive Red Line shockproof superlight stuff.
    It looks like conc. orange juice but it smells like ****.
    Are you guys sure this is the best there is?
    //B//
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    #2 PAP 348, Jul 15, 2007
    Worked MAGIC in my gearbox mate!! :D:D
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I'd used the OEM tranny fluid, Redline's Superlight Shockproof, Redline's MTL, and am currenty on Redline's 75W90NS.
    The Shockproof had the best shifts.
  4. f355spider
    f355spider F1 World Champ
    18,045
    I'm using Redline 75w-90NS in my 355, used it in my 87 328GTS too.
  5. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    just switched to it on thursday and went for a lot of driving this weekend. It is much better with the superlight shockproof. Do it.
  6. jasonporsche
    jasonporsche Karting
    May 7, 2007
    192
    auburn, al
    jason gautney
    I just used a 75-90 product made by BG. BG is a chemical company that you will only find in nice shops and dealerships. They are highhly respected in fuel injection stuff (cleaning). I have a friend who is a local rep that sells for them. It's a pretty big thing down south here at dealerships. Anyway, my tranny has never shifted better, I was totally impressed. You will have to find a local rep or got to a local dealership and ask if they have any or can get you some. Very reasonable priced also. I've used Swepco, RedLine and all, and this has worked great for me. Just My 2 cents worth
  7. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Funny you mention them, friend of mine is a local BG rep as well. I never heard of them but apparently they're pretty good. I'm trying the fuel injection cleaner this week (not a tank add in, it connects to the fuel system and does a complete 'flush'. First on my daily driver, maybe on the 355 later.
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    What gear box fluid is used in F1 355's?
    I ask because F1 355's don't seem to have a problem shifting into 2nd gear when cold.
  9. f355spider
    18,045
    According to the workshop manual, the F1 355 specifies the same Shell gear oil as all other 355's.
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    With all the talk about transmission gear oils helping cold shifting I tried Redline 75w90NS (in my 355) after previously having the OEM Shell gear oil.
    Never had any particular problems with the OEM oil (usual balkiness when cold) but I also found absolutely no improvement with the addition of Redline.
    I think I will probably go back to the OEM at the next change.
  11. BigSky355
    BigSky355 Karting
    Nov 8, 2004
    196
    Montana
    Chris
    Any recommendations on internet sites that offer redline 75 90 NS for a good price? No one local carries the stuff and I'd like to do a fluid change this summer. Thanks in advance.
    Chris
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Even great gearbox oils aren't going to always smooth your shifts if you shift at low rpm's.
    You'd better have your 348 motor above 3000 rpms to go *in* to 2nd gear smoothly when cold, and I'd suspect similar or higher rpms for 355's.
  13. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    I got mine through amazon. Found a case of 12 quarts for $140 for the shockproof stuff. The regular stuff was cheaper
  14. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
  15. f355spider
    18,045
    Brian Crall (Rifledriver) said that if he had a particulary balky gearbox, he used Redline MTL and it would usually do the trick. But he started with Redline 75w-90 first. Not sure why....perhaps the MTL is considered less suitable for the application, even if it does improve shifting?
  16. John Harry
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    When I talked to Redline about this recently they said: “A GL-5 gear oil is designed specifically for high offset hypoid applications, as you mention the Ferrari final drive doesn't have hypoid gears so an EP type gear oil shouldn't technically needed. The MTL is a 70W80, a lower viscosity than called for [Ferrari calls for 80W90] as well as being a GL-4. My biggest concern with its use [as opposed to 75W90NS] is the viscosity difference.”
    I was also told that MTL and 75W90NS have very similar coefficients of friction, which suggests to me that they should be comparable in terms of getting the synchros spinning. Since Brian found MTL to be somewhat better in smoothing rough shifts maybe the difference he noticed is due to its lower viscosity.
  17. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    That was a very interesting article by 'rifledriver'
    How does Redline MTL and NS compare to Redline Superlight Shockproof?
    What is the the viscosity and intended uses ?
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I've used both. Redline's MTL shifts better in my 348 than Ferrari's OEM tranny fluid, but Redline's 75W90NS shifts better than does the MTL.
    I'll also add that Redline has confusing names. Redline offers both "75W90" and "75W90NS."
    Very similar names, but very different results. The 75W90 does *not* improve your shifts. The 75W90NS *does* improve your shifts.
    ...and Redline's Superlight shockproof improves 348 shifts even more than does the 75W90NS.
  19. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Yeah, this is what I found through my research online as advice from you No Doubt and others like Pap, so I went straight to the shockproof stuff.
  20. John Harry
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    The Redline website says: “SuperLight ShockProof™ A unique product with the viscosity of 75W90 gear oil but lower internal friction similar to that of an ATF. Used when temperatures are not high and when the maximum power output is required such as in stock car qualifying laps.
    Used in low-power road racing transxles like Formula Vee and low-power SCCA Production classes (dog-ring type, generally not sycro application where this product can be slippery).”
