Gear Oil?????? | FerrariChat
Gear Oil??????
Discussion in 'Mondial' started by roberth9855, Apr 8, 2013.
  1. roberth9855
    roberth9855 Karting
    Feb 4, 2012
    63
    Murrysville, Pa
    Robert Henkel
    I may be going in to no mans land here BUT. After looking into gear oil for my 1985 Mondial I see no data to support using Red Line or swepco gear oils over let say Kendall limited slip 80w90. Am I wrong? If someone could let me know, it would be a great help.
    Thanks Bob
  2. mulo rampante
    mulo rampante Formula Junior
    May 31, 2011
    997
    Terra Incognita
    Charles
    Wade references some of the better threads on this, and the topic indeed has a rich tradition of discussion here.
    FWIW, I have had great results with GM synchromesh... 2nd gear is well-behaved with it. I did a ton or research (most of which I've forgotten) and my research suggested it would be relatively benign. If you want to try to lick the 2nd gear issue without the hole-drilling fix that was advanced many years ago (and now seems forgotten), this stuff might help.
    You will find the various gear lubricants are defended with religious fanaticism by their adherents. As a matter of debate, it is exceeded only by motor oil and stick vs. paddle discussions. You have been warned :)
  3. ronfrohock
    ronfrohock F1 Rookie
    4,154
    MA
    Ron Frohock
    Search for his oil wisdom.
    Ron
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    No better way to put it :)
