Gear Shift Lockout Broken on 355 | FerrariChat
Discussion in 'Technical Q&A' started by jakermc, Oct 1, 2007.
  1. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    Here is the problem - When shifting to the left towards the 1st gear/2nd gear gate there is supposes to be some resistance to prevent you from shifting too far left before moving up or down into the gate for the proper gear. Additionally there is supposed to be a lockout feature for reverse that requires you to push down on the handle before engaging reverse. Both the resistance and the lockout appear to have disappeared from my car. Finding 1st and 2nd gear is difficult and a mishift into reverse is possible. There is still resistance when moving to the right so the sift lever still centers properly.
    The cause - not sure, but it may have had something to do with my installation of carbon fiber bits in the center console. I replaced all the sticky stuff with carbon fiber and when everything was reinstalled, the problem appeared. I'm not sure what I could have done. I took the ball off the stalk to remove the metal gate and the melting console piece, but other than that I didn't apply any pressure or move the shift lever at all.
    Any ideas on what I might have done to cause this? What is the fix?
  2. Ricambi America
    Sponsor Owner
    They can actually just wear down over time. I doubt the carbon fiber had much to do with it -- unless it was severely misaligned and the lever was constantly rubbing on that little lockout 'winglet'.
  3. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    Sounds like there may be something that fell down into the shifter and is now stuck between the shifter housing and the 'ball' portion of the shift handle so it is pushed down all the time. Take the gate off and make sure that you don't have something that fell into the mechanism.
  4. f355spider
    f355spider F1 World Champ
    18,044
    Remove the shift gate and examine it? Is it possible you have it upside down (inverted)?
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The reverse "lockout" is just a metal tab that hangs down from the metal gate. The base of the stick shift will hit this lockout tab, preventing you from going into reverse...unless you press down on the stick shift.
    Since you can go into reverse without pressing down on the stick shift, I'd look at 3 things:
    1. Can you press the stick shift down and have it pop back up .5" to 1" while in Neutral? If no, then your spring delock mechanism may be jammed down.
    2. If not #1 above, then it may be that your carbon fiber pieces are too thick (or some similar problem with installation such as screws not being all of the way down on the metal gate). If your gate is too high, then the base of your stick shift will slide under the Reverse Lockout mechanism just the same as if your stick shift was always pressed down.
    3. If not #1 or #2 above, then lift up your metal gate to examine the reverse lockout tab underneath. This is a common wear item. If it is worn or broken then the underside of your gate will not protrude down far enough to block the base of your stick shift, allowing the base of your stick shift to slide under the worn/broken Reverse Lockout mechanism just the same as if your stick shift was always pressed down.
    The underside of your metal gate should have a tab in front of the Reverse channel that sticks down like the rudder on a sailboat. That underside should not be universally smooth.
    Take a picture of the underside of your metal gate and post it here.
  6. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    Thanks everyone, this helps me understand how the mechanism works. The stick will move down if I press on it. I have not measured the travel, but it feels the same as before. I'll do some disassembly tonight, snap some pics, and report back .....
  7. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    #7 jakermc, Oct 2, 2007
  8. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    #8 jakermc, Oct 2, 2007
    This shot shows that the gate is OK. There is a small amount of wear on the bottom peg but not nearly enough to be a problem. (OK, its a bad pic but take my word for it)
  9. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    The problem is that the carbon fiber piece does not allow the gate to fall deeper into the cavity, thus the shift lever slides under the stops as though it were pushed in. You'll notice in the first pic that the top surface of all the pieces line up nicely. The design flaw is in the lowest edge where the gate rests. It is too shallow. One thing you can't see in the pictures is that the black plastic spacer that goes immediately under the gate and rests on top of the screw holes floats freely in space. In other words the gate does not drop low enough to come in contact with the piece. Ideally the gate, the spacer, and the screw holes would all be touching one another. In this case the gate sits too high.
    I took some pics that show how the lever slides under the stop when fully erect and how it looks when pushed in but I am having some trouble loading the pics. This validates that the lever is working correctly. I'll try again to upload them tomorrow night.
    I see three options to fix the problem:
    1) Get the supplier to send another piece from a corrected mold
    2) Weld extensions onto the gate shifter stops
    3) Shave the bottom ridge off the carbon fiber piece. This will allow the gate to slide through the carbon fiber and rest on the black plastic spacer where it should. This might be the best design for the supplier but I worry about doing a good job modifying the piece myself.
    Obviously option 1 is the best. I'll show this thread to our F-chat sponsor and see what they can do. It's a beautiful piece so I hope they can make this right.
    Thanks again for all the help.
  10. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    Well..... that's certainly our console. We have not had this problem reported by any of our other 355 console customers. We'll work with jakermc to figure out what's happening and get it resolved. We'll update the thread with the resolution of the issue once we have it.
  11. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    Thanks John, I appreciate the quick response. As stated, the pieces look fantastic. After seeing them in place I certainly don't want to go back to stock!
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Could you photograph the area of the console under the metal gate, but with the carbon piece removed?
  13. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    Wow, those carbon pieces do look fantastic! John, would you PM me a price for similar console setup for my 355? I have an F1.
