Gear shifted to 'N' | FerrariChat
Gear shifted to 'N'
Discussion in '360/430' started by TakoC, Dec 2, 2013.
  1. TakoC
    TakoC Formula Junior
    May 10, 2012
    549
    Occurred to me last week on my F430 Spider. Was on a expressway doing around 120mph on '6th' gear and out of a sudden the gear shifted to 'neutral'. The rev just dropped to 1k-2k, not redline. Did a couple of clicks on the downshift paddle and it went back to 4th gear (if I rmb correctly).
    The next day was doing a freeway run again and again it happened. If my memory serve me right around 4th gear this time, and gear was changed to neutral.
    Any idea?
  2. yaserw
    yaserw Karting
    Sep 17, 2011
    127
    check the clutch wear
  3. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    The previous owner of my car told the dealer the same thing and they replaced the clutch. Apparently a common symptom of a worn clutch (or maybe a badly out of adjustment PIS).
    Alan
  4. TakoC
    May 10, 2012
    549
    I been thinking and thought that it has something to do with the gearbox. Possibly to replace to whole gearbox. Thank goodness. Any idea how it has to do with the clutch? Clutch and gears? Hmm..
  5. 993man
    993man Formula Junior
    878
    New Zealand
    Graham
    I would have also thought the worse! Good that it's probably something easy.
    Can you come back and let us know what the cause was?
  6. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    If the clutch is worn beyond a certain point, I believe that the TCU puts the car in neutral to avoid damage. Someone with more technical knowledge please chime in. Gearbox is okay -- only the clutch is affected.
    Alan
  7. Stout
    Stout Formula Junior
    May 9, 2013
    259
    Helotes, TX
    Victor
    I'm researching this issue also. While shifting, sometimes N is selected instead of the gear. This also happens in Automatic mode so it's not the paddles. No TCU errors at all. I'm going to do a "self learn" with the Leonardo this week to see if that clears it up. Maybe some wear has caused a potentiometer to be out of range.
  8. Financialman
    Financialman Formula 3
    Sep 8, 2005
    1,841
    San Jose CA
    Dan Carpenter
    My 430 did this and it was a worn out clutch.
  9. star4747
    star4747 Formula Junior
    Dec 28, 2010
    363
    Midwest - USA
    Rick
    Geezzzz....
    Hope your insurance agent doesn't read this forum, or any law enforcement officers
  10. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,202
    Beverly Hills, CA
    Jay
    Most often a sign that the clutch is going
  11. stokpro
    stokpro F1 Rookie
    Jun 25, 2003
    4,383
    Himalayas
    As others have said, possibly a worn clutch or faulty clutch position sensor.
  12. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    One other possibility not yet mentioned is low pressure and/or low level in hydraulic system
  13. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Good point.
    Alan
