Gearbox autopsy...UDDATE | FerrariChat
Discussion in '348/355' started by Lars_vet, Sep 20, 2008.
  1. Lars_vet
    Lars_vet Formula Junior
    Feb 25, 2007
    603
    On the open road
    Lars
    #1 Lars_vet, Sep 20, 2008
    Got the ring nut off today, and sure enough, here is another oil pump bearing failur..
    I am so glad that is did not drive the car a mile more! That bearing could have come apart any second!
    Another scary thing is that the bearings has the updated SKF number on it, that means that I will soon be on the 3rd bearing on a 39K car
    What is the price on these bearings? Can anyone rememberwhat they paid?
  2. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    #2 saw1998, Sep 20, 2008
    Man, that is scary!!! Three bearings in less than 40K miles? I don't know much about 348s, but what is up with this design? Lars, I am really glad that you caught this before............$$$$$ Ernie, FBB, et al., as usual, were right.
  3. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Well, in less than 600miles I havd the oil pump tensioner and gearbox "blow up". I am so glad that i both cases I stoped driving the car after the sound came....
  4. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    OMG, I thought this was from your original post problem! I think it's time to call an Exorcist.
  5. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    This is my first gearbox issue.
    But at my first hole Ferrari seasson, botht the engine oil pump tensioner and gearbox have gone bye bye, these cars are NOT for the weak minded!
    I am glad that I have 2 hands to sort out these issues, imagine taking it to the shop each time!!!
  6. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Sorry. I thought your box broke on 2 separate occasions. BTW, Lars you should really be very proud of yourself and your mechanical abilities. There is probably only a handful of people on FChat that would tackle this problem on their own. I don't know that I would have the bal_s to do this in my garage. You da man!
  7. fatbillybob
    Aug 10, 2002
    29,224
    socal
    That is not factory ferrari silicone. Don't blame the 348 gearbox. Someone was in that gearbox before you! Who knows what they did or did not do.
  8. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Yes, as I said they falid bearing has the updated part no. on it. So the is the 2nd failed bearing in this gearbox.
  9. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    #9 Marco Bussadori, Sep 22, 2008
    Lars look at http://www.ferrarichat.com/forum/showthread.php?t=207294&page=2 I enclose pictures of my bearing damage, which is exactly as is in your case, just not as far progressed. While you are there, you may as well check the ringnut in the clutch control diagram, and the plug at the end of the mainshaft which ensures the pressurized gearbox oil makes it up to the differential (which mine did not).
    I want to practice some Danish...
    Lars, de to lejre på begge sider er sat op som par. De to på oljepump siden er "thrust bearings", og de to på den anded side er "roller bearings". Thrust bearings has både funktionen at holde akslene i linje med hinanden (derfor er det så vigtig at "ring nuts" er stramme, så akslen kan ikke flytte fra side til side, mens roller lejrene har kun et rullende funktion.
    Når bilen bevæger sig, saa er der en del drejemoment der prøver at flytte hovedskaften til venstre og "lay" skaften til højre (du kan se hvordan selver gærne er sat op. De to "thrust" lejre holder dem i ligning samt med den normale rulning af skaftet.
    Now I give up and go back to English...
    You may be able to get them from SKF - I did get them from there for about GBP 68.00 a pair plus VAT.
    If the Danish folks at SKF are a pain, try these guys (where I got them) Acorn Industrials (+441709789999), ask for a lady called Lynn. The Original Ferrari bearings were part number BA2B633912 with a C3 designation (hardness and precision) - these have been replaced by BA2B636151A also with C3. The dimensions are : outer race 76mm ø, inner race 35 mm ø and bearing width is 28mm - I don't remember the thrust angle, but I do remember it matches the original (don't know why 43.5 degrees rings a bell). I got them for about DKK 300 each (yes 300... - GBP 34) + VAT and shipping and they got delivered in 3 days.
    Marco
  10. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    If you have a clunk when you turn the shaft underneath the one going from the engine to the clutch, you also have a loose ringnut on the drop gear. Look at the link I posted just above, I had that too. The solution is either a new SET of drop gears (megabucks / Kroner) or if the splined shaft (see clutch control diagram) is not too damaged, you can clean it, put a bunch of special bearing/axle adhesive (similar to loctite but stronger) on the splines, put some Loctite one the ringnut and tighten the "lort" out of it. Let it set overnight, then reassemble. The clunk is now gone in my car. Incidentally, that is the gearing that Michelotto tunes for the different race profiles, and also the main difference between the 348 gearbox and the Mondial t.
    Marco
  11. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Thanks alot. I found the bearings, and orded a set for both the lay and main shaft. They will be here in 3 days.
    Now how do i get to that ring nut you describe, can I even see it?
  12. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    So now a new round of questions, preparing for putting my gearbox back togehter.
    1. How do I "hold" the gearbox, when I tighten the ring nut?
    2. What kinda of loctite do I need?
    3. What is the torque spec on the 2 ring nuts?
    4. What is the tq spec on the gearbox covers (think I am gonna feel my way here anyway)
    5. What is the tq spec on the bolt from gearboc to engine?
    6. What is the tq on the CV bolts?
  13. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Marco:
    You are a true "renaissance man" - Ferrari mechanic, fabrication expert, linguist.... You are really an intelligent man and you certainly impress the hell out of me.
    Scott
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Great thread!
  15. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    I am going to take my gear box apart this winter..........better safe than sound.
    Just to check that everything is in order........just to prevent what you have gone through.
    Would it be possible for you to give me a hand..........whenever it suits you of course.
    Where do you live??? Which town I mean?
    //B//
  16. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Hi.
    Thats a good idea!
    Also have you gone thru the oil pump tensioner thing?
    Ofcause I can help you, a pleasure. I live in Århus.
    I did mine at a friends shop. He could do this job at very low price compared to ferrari mech. if you are interested.
    Either way just let me know.
  17. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #17 ernie, Sep 24, 2008
    When fatbillybob and I put my ring nuts back on, one of us held the the shaft on the other side of the box while the other tightened down the ring nut.
    You need to use Loctite 271
    In my shop manual it gives a torque rating of 22 daNm.
    If I'm remembering correctly I think we put mine back on using couple of blips from an impact wrench? We wanted to make sure that the ring nuts were on there good and TIGHT, if you know what I mean. Then I beat the crap out of the ring nut to make sure it was staked on there GOOD.
    The shop manual spec for the oil pump cover is listed at 2 daNm. I put mine back on by feel.
    The intermediate cover is the one you want to pay attention to because that is the one holding the bearings. I tightened that one down by hand also. The manual doesn't give the torque specs for the intermediate cover. But what I did find was the specs for the differential flange covers and that is listed at 2.8 daNm. So, I really have no idea what the specs are for the intermediate cover on the oil pump side of the gear box. Like I said I put mine back on by hand.
    Try hitting up fatbillybob, he may have the specs for those, because I can't find anything for that one in my book.
    Again did it by hand.
    The manuals are missing sooooo much information.
    As you have probably found out the CV joint bolts are on there TIGHT! I had to use a cheater bar on the end of my long handle ratchet to get them to come loose. So when I put them back on I just tightened them back down as tight as I could by hand.
    However,
    I ran a search of the archive and found the torque specs for the 328 CV joints and those specs are, 8 Kg-m (57.5 ft-lbs) for the cv bolts.
    I hope that helps Lars? Sorry I couldn't give you the rest of the specs, my manual just does not have that info in it. Maybe someone else has that information but I don't. If I had the information you know I would give it to you. Hopefully if someone else has the info they will share it.
  18. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Okay now,
    About that failed bearing. I am assuming that is the one on the oil pump side of the main shaft, that was on the back side of the intermediate cover, right?
    Which brings me to my next train of thought.
    Fatbillybob was sure it was loose ring nuts, and he was correct. However, I was sure it was bad bearing design. By the looks of it I am also correct. Because it is evident that the bearings will still fail even though the ring nuts are on properly. We now know this thanks to you posting the pictures of your main/lay shaft outer ring nuts being on tight and staked properly. Then when you posted the video of your oil pump bearing ball bearing retainer having play it, that demonstrated what I had been advocating all this time. And that is that, the bearing is not up to handling the lateral loads being imposed on it by the transmission.
    Now what we need to do is figure out what bearing design will work best with our application, so that we can prevent this this from continually happening.
  19. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Thanks alot! A big help as always!
    I am waiting for parts. Orded 2 bearings sets, one for the both the lay and main shaft.
    I orded the Ferrari parts at Eurospares, allthough I promised myself not to do buisness there anymore. Everybody deserves a 2nd chance I guess, and I really hope they deliver this time...without an attitude...
  20. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    You are right. main shaft, inter. cover side bearing.
    THe worst thing is that the failed bearings has the updated part number on it. Also you can see that gaskets that they have been changed before..
    so 40K and will now be on the 3rd bearing. And yes the ring nut was very tight on there...
  21. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #21 ernie, Sep 24, 2008
    You should have bought them from Daniel at Ricambi. Right now the €Euro is more valuable than the $Dollar. Just had a look at the exchange rate and as of this pposting $1 would have only cost you €0.68. In other words you would have gotten a 32% discount for buying it from here in the US just because of the exchange rate. Come on bro, if we are going to save ourselves money we have to think about how to save money anywhere we can. ;) Plus Daniel-son is the man. He has outstanding service, and ships internationally.
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #22 ernie, Sep 24, 2008
    One more thing.
    When I put my gearbox back together I used Hondabond HT to seal it up. The stuff works great. I have absolutely NO leaks coming from my gearbox. Not one drop.
    Hey did you ever take up Marco on his offer? He said he had a couple of extra bearings sitting around. Never mind, I guess you didn't since you already ordered from Eurospares.
  23. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Here is the catch...
    The exchange rate has been in to “our” favor for a while now. The problem is that if you buy parts from the US, customs will add ~30% in tax and besides from taking forever to get the parts it isn’t that much cheaper any more :-( This is the way it works in Sweden and in most EU countries as well.
  24. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well that SUCKS!!!
  25. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Lars,
    The bearing I mention is behind the panel with the 4 bolts you posted in a previous message. It is the hollow shaft through which the engine shaft runs from the engine to the clutch. When you take the clutch bellhousing off, you can't miss it.
    The data in the book is OK, on new kit. Just make sure you go 5-10% above and then use FatBillyBob's method of breaking the ring into the shaft recesses/dimples, to ensure the ring nut does not loosen. Also drown the threads in loctite.
    Marco
