355 - Gearbox / Driveshaft Leak? | FerrariChat
355 Gearbox / Driveshaft Leak?
Discussion in '348/355' started by huzilulu, Jan 31, 2024.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    I pulled out the driveshaft today to rebuild the CV, and as soon as the driveshaft came out, a LOT of greenish oil came pouring out the gearbox driveshaft housing... It smells like gear oil to me, and has a greenish tint to it...
    I have not drained the gearbox before pulling the motor (not sure what I was thinking), but now - can I replace the seal behind the CV flange if the gearbox still has oil in it?
    Any other recommended seals/bearings to be checked while "I am in there" ?
    Secondly, when I pulled the hub off, I noticed some orange/red grease around the bearing (last picture). Is this a leaking bearing, or is this grease applied during installation?
  2. Rifledriver
    37,089
    That oil is not leaking past the seal, it is leaking past the splines and retaining bolt/washer.
    INTMD8 likes this.
  3. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Brian - Im sorry, I didn't quite understand... You mean this oil leaked from the CV side, past the splines and into the cavity? So this 'oil' is from the CV grease that was previously in the CVboot?
  4. Rifledriver
    37,089
    How can that happen? The end of the CV has a cover. Besides the CV is full of grease, not oil.
    INTMD8 likes this.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Is that just a matter of using a thread sealer? Or could it be indication of that bolt loosening up?
  6. Rifledriver
    37,089
    Never seen one get loose but I have seen lots leak.
    People ignore how the factory did it thinking it was some hack using lots of sealant because he didn't know better. In reality a big fingerfull needs to be smeared in to fill the splines and a bunch needs to be gooped on the shank of the bolt.
    bobzdar likes this.
  7. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Thanks for the tips !!
