Gearbox fluid change interval | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ferrame, Mar 1, 2015.
  1. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Mitch you're funny, but he did say air the composition of which is,
    N2
    O2
    CO2
    H2
    Ar
    Xe
    Ne
    He
    Kr
    SO2
    CH4
    N2O
    O3
    NO2
    I2
    CO
    NH3
    And as we know air contains water vapor. Sooooooo yeah pretty much anywhere there is air. :D
  2. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    If that is happening --- and, I'll take you at your experienced word that it is --- then that is entirely different from the "routine service interval" rationale for changing the oil.
    And, it is certainly a good enough reason to change the oil frequently regardless of other time / mileage considerations.
    Are there retro-fixes out there for this design defect --- either from Ferrari or on the aftermarket ? Any TSB's issued ?
  3. finnerty
    May 18, 2004
    10,406
    If I send you some lead will you change it into gold for me, please ? :)
  4. tazandjan
    39,319
    All that splash lubricated experience people have with transmissions is not really applicable to a pump lubricated system like a Ferrari, like the pros are saying. That pump and all the heat from the exhaust system and cats really beats up the transaxle oil. Add in the possibility of coolant/transaxle oil cross contamination and you V8 owners should change the coolant annually, too.
    Oh yeah, F1 fluid needs to be changed, too, even though the maintenance schedule does not mention it until the 599 maintenance schedule (3 years) came out.
  5. Rifledriver
    37,288
    The later transmissions that seem to have to worst of the heat problems also have rather small gears for the power output. Especially the ring and pinion. I have always believed that was the major source of the heat and breakdown of the lubricants. Daytona, TR, BB, even the 308/328 had oil pumps and didn't have the heat associated problems of say a 360 but in contrast had large gears. My observation anyway. They had their own lubricant related issues but serious oil degradation like we see these days hasn't really been a problem.
    Different design syncros too. Ferrari never seems to use standard tried and true designs and all have shown oil sensitivity, in different ways but definitely oil sensitivity.
    Yea, F1 oil. Lifetime oil. Lasts the lifetime (or dictates it) of the components.
  6. scudF1
    scudF1 F1 Rookie
    2,919
    Long Island, NY
    Billy
    Guys...
    We are not coming to this forum to argue with everybody. We are coming to exchange information and hopefully to learn something.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    My point is that rust will form if the only substance present is H2O; anything and everything else is not relevant.
  8. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    So what is the correct interval for a 308/328? I was under the impression that once every two years for trans oil was correct, assuming around 3000 miles per year.
    -F
  9. Ak Jim
    Ak Jim F1 Veteran
    9,754
    North Pole AK
    Another variable, especially for the low mileage car, is how long are the trips? If you drive 1000 miles per year and do it in 500 trips there is going to be a lot more contamination than the same 1000 miles distributed over 25 trips. I know when ever I drive my F car I plan to drive it long enough to get it up to full operating temps, this helps with exhaust system life also.
  10. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    This is the most important post of this thread. It explains why some conventional wisdom is being turned upside down, and specifies the scope.
  11. ModenaInv
    ModenaInv Karting
    157
    South West Michigan
    Dave
    Rifledriver, what trans oil do you recommend for the 308 qv?
  12. MrF355
    MrF355 Formula Junior
    Mar 4, 2008
    495
    Kimi
    I would not question Brian when he offers advice. He gets his hands dirty fixing these cars. From what I have read about him and his posts he is extremely knowledgeable. A Ferrari cannot be compared with any other high performance vehicle. These cars run extreme heat and all components are under stress that most cars never see in their lifetime. Changing fluids is cheap insurance its also called preventative maintenance. For a rarely driven vehicle I believe regular fluid changes are more important.
  13. Sigmacars
    Sigmacars Formula 3
    1,241
    What dos the Manual say for the 308/328?
  14. BJJ
    BJJ Formula 3
    1,301
    Always these fairytales .... ;).
    Modern Audi performance engines have their turbochargers within the cylinder-V (i.e. within the top of the engine and not at the sides). Consider further use on German Autobahn, i.e. permanent full throttle for considerable periods and in hot weather also. THAT are thermal engineering problems ....
    A Ferrari is a car just like any other high performance car. Making a myth of it helps make money, of course ;). Any (!) performance car needs specialists knowledge and experience (the latter mainy with respect to design flaws :D).
    The service intervalls provided by all super sportscars manufacturers are provided as "worst case scenarios", that is, for example, use on German Autobahn with frequent and long during speeds over 250 km/h. Combined with "sporty" acceleration and braking attitudes. Through the whole year and at any weather.
    This in turn also justifies to prolong some service intervals, if a) use of the car is moderate in attitude (e.g. rather rarely over 200 km/h, hi over there on the other side of the pond, "normals" get sick at that speed already ;)), b) storage is in a non-humid garage with more or less constant termperatures throughout the year (no strong fluctuations).
  15. Rifledriver
    37,288
    You can always tell a German
    But you can't tell him much.
  16. BJJ
    BJJ Formula 3
    1,301
    #41 BJJ, Mar 23, 2015
    :D Are you sure that I am a German? :D
    It is true, though, that no one can easily tell me fairytales, at least in the technological field ;).
    The issue is somewhat different. If the service provider does not himself know how a car is been used by the owner, he would be crazy to advise anything else than official service schedules. The owner, for example, does not necessarily mention frequent trackdays or the like, or other "abuse".
    Thus, it is, I believe, the responsibility of the owner to judge himself how he has used and stored the car. If, for example, one has attended to trackdays and spent hours around the track under full throttle, it is always advisable to have all (oily) fluids changed immediately afterwards (I do at least). Brake inspection out of service schedules is also very advisable ;).
    If, on the other hand, the owner has just had frequent weekend joy drives along US roads at fine weather and more or less stuck to speed limits, and the car is otherwise stored in a heated/dehumidified garage, then it seems justified to consider stretching gear oil change intervals.
    P.S.: Or must I ask in the workshop since when the large barrel with oil had been opened .... ? If since 6 months, must I then change oil after further 6 months already? ;).
  17. BJJ
    BJJ Formula 3
    1,301
    That reminds me when searching for a XJ220. On all I saw, virtually nothing had been done for at least one decade (so-called "collector cars"). With such "service intervals" you indeed will go into all kinds of trouble.
    Since then the phrase "collector car" means to me nothing else than condition 4 at best (with respect to technical components).
  18. Rice-Racer
    Rice-Racer Formula Junior
    Jan 10, 2015
    252
    Totally agree with you BJJ. These people or dealers selling 'collector' status cars etc, hardly driven, low miles can be a persons worst nightmare, right beside a hard driven clean car.
    We all share advice, our locations can have a huge impact on the vehicles mechanical status. High humidity-areas, dry areas are factors. My car had all new fluids when I bought it, other then gearbox. So, it's worth it to me to know it's all changed by me now, knowing the type of fluids and recorded for next change, cheap insurance and peace of mind!
  19. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,950
    Weston, FL
    Scott
    Brian,
    I have a Maserati GranSport for which Maserati recommends a 2 year fluid change interval on the ZF gearbox. Should I be doing annual instead? I live in SE Florida and drive about 3,000 miles a year.
    Thanks,
    Scott
  20. Rifledriver
    37,288
    Sorry I have no information or experience with modern Maserati's or their transmissions so can't comment.
  21. Mitch Alsup
    Nov 4, 2003
    9,742
    Basically, it comes down to this:
    A) if you want you car to last longer than the manufacture wants your car to last, change the fluids more often
    B) if you are going to dump the car on the used market while still in warrante, you don't have to do jack ****.
  22. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Typically in the US, brake fluid changes are ignored. "Oh, I never heard of that". Automatic transmission engineer told me that these quick oil change stations that push automatic fluid changes for profit. That they sometimes cause more harm than good. This could stir up contaminants that were best left alone.
  23. Dr Tommy Cosgrove
    36,599
    Birmingham, AL
    Tommy
    I had my Touareg in for a service last week. I called to tell them to flush the brake fluid and they acted surprised. Said I just had it done two years ago...
  24. f355spider
    f355spider F1 World Champ
    18,055
    That is exactly the advice I give friends. I am a 'buy and hold" guy when it comes to cars, so I am "old school" when it comes to maintenance, and change fluids much more often than manufacturer recommends. My friends all get new cars, either right at, or shortly after warranty expires...I tell them only do the maintenance outlined in the manual...no reason to do more, if you are flipping the car with less than 50k miles on it.
    My current BMW has 230k miles on it. Original engine and transmission, drives perfectly.
