Gearbox Fluid, What Type Are You Using? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by christopher, May 25, 2005.
  1. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Generally, I believe Redline suggests MTL for non-synchro transmissions. I use Redline MT-90 in the transaxle of the Mondial ('84 QV) and it works great. Smooth shifting, warm or cold, and has held up well on the track, no degradation in performance. A friend is using the Redline 75W90 NS in his race modified 308 and loves it.
  2. Rifledriver
    37,363
    MTL actually is for syncro transmissions but is a GL4 instead of GL5 so Redline will not recommend it.
    GL4 spec is for low to medium offset hypoid gears while GL5 is for medium to high offset hypoid gears.
    The 308/328/348/355 transmissions do not have hypoid gears of any type but Ferrari specs GL5 gear oil so a lubricant supplier will not suggest any but the spec'd oil.
    I am not an experimenter of that nature when it comes to client cars but I have seen 308/328 transmissions running MTL for most if not all their lives and it was the gear oil of choice for many of the 355 Challenge teams. I know of zero incidents due to it's use. That is more than enough for me.
    My shop is about 20 miles down the road from Redline and I talk to them frequently. I have asked point blank about MTL and was told it would be fine but due to it's rating they cannot officially condone it's use.
    I use Redline 75/90NS in the shop to keep it simple because it can be used in almost all the cars I service but when I get a shifting complaint in a 308/328/348/355 I put in MTL.
    As Kris said, it comes as close to making a Ferrari shift like a Japanese car as I've seen.
  3. FasterIsBetter
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Brian,
    Thanks for the insight on MTL. Always good to learn something new. As you said, I've taken the recommendations of Redline from their website. I was planning on trying the 75W90 NS next gearbox change instead of the MT-90, but might have to give the MTL a try. The MT-90 smoothed the shifting out a lot, so would be interesting to try the MTL for comparison.
    Steve
  4. sp308qv
    sp308qv Karting
    Nov 20, 2003
    101
    South Jersey
    Steve Ponzetto
    I just switched from Mobil 1 to Redline 75/90NS and there was a HUGE improvement, much smoother shifting and I can get the car into 2nd gear when it's cold now.
  5. f355spider
    f355spider F1 World Champ
    18,060
    Nice, keep us posted on if anything changes as you accumulate miles. I had initially great results with Mobil 1, but after a few thousand miles, the gearbox started 'crunching"....switching to Redline 75/90NS fixed it for good.
  6. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I still like Mobil 1. Have used it since 2000. Over 114K miles and running strong.
  7. f355spider
    18,060
    Perhaps my 328 had worn synchros or something? That may be why it preferred an oil without any slip additive?
  8. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Dave, undoubtedly. The friction modifiers in oil for limited slip diffs aren't helpful in the gearbox. However, without the friction modifiers, the limited slip diff won't perform as intended (more slip)...although the gbox will shift easier as the syncros can match speeds easier/faster. It's really a compromise b/w the needs of ease of shifting and needs of the diff to have the right friction coeficient in the oil.
  9. yank05
    yank05 Formula Junior
    Nov 8, 2003
    272
    New England
    Anthony
    Hi,
    ....Royal Purple on my '76 GTB - shifts like butter, no diff. chatter, straight from the bottle....
    Anthony
  10. Llenroc
    Llenroc F1 Veteran
    5,592
    Colorado
    Vern
    Hey Brian, Question on the above mentioned MTL. Do you add any friction modifier?
  11. Rifledriver
    37,363
    Nope, use it right out of the bottle.
  12. SEAL2CC
    SEAL2CC Formula Junior
    Jan 19, 2005
    352
    Different animal but the Maserati Biturbos had "slow" somewhat crunchy gearboxes and any problem was completely eliminated by MTL...completely changed the character of the car and it became a pleasure to drive. That's going into my Mondial t and 355 soonest I can get to it..
    Chris
  13. Prova7
    Prova7 Formula Junior
    Nov 17, 2003
    257
    Dallas, TX
    DamonB
    Surprised to see nobody has mentioned NEO synthetic. Everyone I know who has tried both NEO and Redline preferred the NEO. It's has an even nicer shifting action than Redline and works just as well when it's 30 degrees outside as when it's 100.
    http://www.neosyntheticoil.com/
