Gearbox is out! now what? | FerrariChat
Discussion in '348/355' started by Lars_vet, Sep 13, 2008.
  1. Lars_vet
    Lars_vet Formula Junior
    Feb 25, 2007
    603
    On the open road
    Lars
    #1 Lars_vet, Sep 13, 2008
    Where do I start the search for my noise and fail. I want to take as less apart as possible, as I am not an gearbox experienced guy..
    I have a whine when I drive and a horrible sound while idlig in netural. I found these finger nail bits looking parts in my gear oil...
    Car shifted fine, but I noticed that the gear stick started to move around in the slot when accelerating or deacelerating.
    So what could be wrong and where do I start?
    BTW. From what I have been able to see thru the hole in the end and thru the inspection plate, all gears look good.
  2. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #2 FandLcars, Sep 13, 2008
    Hi Lars - As far as inspection, I'd start by removing the side covers on both sides (see red circle on this pic). Take a look to see if your ring nuts are tight and "staked down". I've attached a pic below of what mine looked like (tight and "staked down"). Also... take some pics of the pieces you see in your oil, or any other pics of the inside that you can. PS - my first pic is of the driver's side, and the second pic if of the passenger side. Good Luck :)
  3. PAP 348
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    Im with Rick on this one. Take those side covers off 1st and have a look. :):)
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Me too. Rick is right on the money.
    By the way, NICE JOB getting your gearbox out!
  5. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,858
    Juan
    get ready to take a big dump....does the gear box oil smell like a turd?
  6. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    smells like gear oil I guess....??
  7. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Great, I will do that monday, and report back...Guess it is getting exciting now...
    BTW, I stoped driving the car as soon as the whine got really noticible. Total I have done 100 miles or so since the whine could barely be heard, and the whine only got really bad and loud just before is was back home where it has been parked since.
  8. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Thanks, your guide made it a friendly job!
  9. Juan-Manuel Fantango
    14,858
    Juan
    It was an inside joke, mine smelled like crap, and it was a big dump that I took, on my secound gear box.
  10. fatbillybob
    Aug 10, 2002
    29,224
    socal
    You start before you take the gearbox out and listen very carefully from multiple places in the engine bay and on the gearbox with a mechanics stethescope BEFORE you take the box out. At this point you can only guess as the most typical failure and hope some other posters are right and it is the lock rings. If you are wrong you will be taking the box out a second time. If you want to take no chances you completely disassemble the box spec it out and put it back together with new bearings. I am pretty lazy and don't want to do a job again. I personally always take the boxes completely apart and reassemble, however by the time the boxes get to me it is pretty bad. There are just some things you can't see or spec with everything together. For example Ernie had a synchro that was in spec but when taken off the shaft there were big wear groves in it and it was junk. Remember that Ernie? Ferrari says if you open the box with fairly low miles like 25k km (I forget the spec) change the synchros which = reassembling the box. Personally I just spec the synchros and if they are in spec and look good I reuse them. There is a difference between a consumer acceptable result and doing it right. DIY'ER's already at looked down on my pros. We need to spend the time and practice the craft at a very high level.
  11. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    I have whining sound as well.......however no parts in the oil.....just very few pcs harly noticeable.
    The whining sound change every now and then why I suspect it comes from elsewhere and not the gear box.
    I have checked the wheel bearings, but nothing wrong there.
    More suggestions........apart from the stethoscope which will be shopped asap????
    //B//
  12. PATLEW
    PATLEW Formula 3
    Dec 3, 2007
    1,004
    Marvin /Waxhaw
    Patrick Lewandowski
    I had a simular noise in my tranny and it turned out to be 15k fix. I have a 348 Mondial t and the noise turned out to be a bad worn syncro that broke and jamed between 4-5 gear. My stick shift was also moving in and out of gear all of a sudden and then it threw out of gear so hard that the stick actually snaped. It ended up breaking a gear and instead of trying to fix it I located another tranny and had it installed. Sounds like your situation is alot different and there may not be any major damage which is in your favor. You would know if there was major damage when you drained the oil because you would find metal large fragments in it. I hope your issue is not as severe good luck.
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Sure do, which is why I replaced them. But my gearbox was way far gone. I am hoping that Lars will get lucky and only have to replace the outer bearings and ring nuts.
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Check your gearbox oil level.
  15. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Ernie please check my "Gearbox autopsy... " thread, I need help again...
  16. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    I did check that is why I know there were some very diminutive pcs of metal.
    Nothing wrong at all really.........just that whining........
    //B//
  17. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I meant check the level of the oil. If the gearbox is running with a low oil level you will also get some gear whine.
    The metal you found in the oil, was it the metal fuzz on the drain plug, or was it bits of metal.
