360 - Gearbox oil, what are you using? (Yes another of these threads) | FerrariChat
360 Gearbox oil, what are you using? (Yes another of these threads)
Discussion in '360/430' started by KILOCHARLIE, May 28, 2021.
  1. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    I’m going around in circles reading everyone’s current choice for this. I have a manual and are based in the UK so sky options are likely different to those in the UK but I’d be grateful if you could all tell me what brand you are currently using please.
    I plan on changing gearbox oil every 2 years minimum as despite whatever brand I’ve used previously it seems to be in a state at around this point. I’ve tried redline which costs a small fortune over here and seems overkill for the little use I use my 360 for. I’ve also previously tried really cheap stuff my garage only had in stock (a fifth of the price of redline) and it seemed to perform the same and last just as long.
    Is the consensus still gl4 vs gl5? And am I supposed to favour non slip or limited slip?
    Thanks for any advice. I just want some half decent run of the mill stuff that I can buy in bulk and not have to research and compare prices for every 2 years.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,166
    Central NJ
    Dominick
    Can you get eni rotra lsx or ravenol vsg
  3. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    not for anywhere less than silly prices (£30 per litre)
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,166
    Central NJ
    Dominick
    Can you buy a pail of the ferrari OEM fluid ..shell spriax
  5. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    I’m assuming it has to be fully synthetic no matter what but then is MT90 (gl4) or 75w90 (gl5) the better option?
  6. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    I looked into that before but it was crazy priced as only import. Plus I was told that it was good for it new but oils have come on so much over 20 years that pretty much anything is better these days?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,166
    Central NJ
    Dominick
    There is so many options and opinions
    If you go by ferrari gl5 sync
    If nothing else go with Mobil 1 or Valvoline ..even though some say that may affect synchros
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,139
    Josh @jtcarprojects
    Redline 75-90 NS been my go to. i do it once a year for piece of mind.
  9. ketel
    ketel Formula 3
    Aug 6, 2007
    1,356
    Sausalito, CA
    Redline MTL
  10. jcurry
    24,153
    In the past
    Jim
    Redline 75-90, even experimenting with slip additive, was not kind to my gearbox. Shell currently being used. Some diff chatter when cold but otherwise good.
  11. Rifledriver
    37,316
    They call for GL5 oil. Most GL5's are formulated for positraction. Redline 75-90 NS is specifically made for those who do not want positraction additive.
  12. Snapshift
    Snapshift Formula Junior
    944
    Centralia IL
    Lyle D. Pahnke
    I started using Royal Purple Max 75 -90 Max gear with friction modifier for LS differentials. In my F430. Seems fine to me but I am probably in the minority. Was recommended by my independent mechanic shop. It seemed a little quieter and has no problem with shifting. I am using Scuding Swiss SEB ecu which may effect differential chatter in sport mode but I don’t have any issues.
  13. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Thanks all. After much research and thinking I’d rather use something basic yet acceptable with the thinking it’s better to change more frequently rather than use top rated stuff and change with longer intervals I went with this stuff which is around 1/3rd of the price of similar oil. A friend has used it in his 360 and reports no difference whatsoever from redline etc
    https://www.ebay.co.uk/itm/373537080219
