Gearbox porn! | FerrariChat
Gearbox porn!
Discussion in 'F1' started by Fast_ian, Feb 2, 2012.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #1 Fast_ian, Feb 2, 2012
  2. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    OMG! Woody...
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,786
    Atlanta
    John!
    nice find! I don't know how those shift forks hold up. neato
  4. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Computer control..... They'd never be able to go that small if a jockey were stirring the cogs!
    All about *perfect* timing of the shifts. And these suckers last, what, 7 races now?
    Apparently, they'd go smaller yet but the FIA mandates a minimum gear width of 12mm - They were down to ~7mm a few years back IIRC.
    Cheers,
    Ian
  5. BMWairhead
    BMWairhead Formula 3
    Sep 11, 2009
    1,058
    Portland, OR
    Ted
    That is cool! WAY simpler and more straightforward than I would have dreamt...in concept, at least. The complication is making it small (important)...light (more important)...and reliable (most important).
  6. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Indeed.
    I "grew up" with Hewland 'boxes - Very, very, simple yet elegant design. I could do a ratio change in a few minutes - Pop the back off, stand the gear cluster in my (non-patented ;)) jig, swap the cogs and pop 'er back together. Easy-peasy.
    Getting the backlash right on the diff was a different tale though.....
    Cheers,
    Ian
  7. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    Your right it's porn for us robots..;)
  8. SWB
    SWB Formula Junior
    Nov 12, 2006
    964
    Toronto & Ottawa
    Seth
    Now, that's what I call an XXXtrac!
  9. Ferraripilot
    May 10, 2006
    17,786
    Atlanta
    John!
    What sort of backlash does a gearbox like this run on those things. Larger (.012+) or tiny (less than .004).
  10. 4re308
    4re308 F1 Rookie
    4,871
    Woodstock, GA
    Mitch D
    Wow that is awesome!
  11. Alex1015
    Alex1015 Formula Junior
    Sep 1, 2005
    949
    The original seemless shift boxes used two clutches and were hopelessly unreliable with many components needing to be replaced regularly (as in several times a weekend!).
    The switch to twin barrel design has been universally adopted for a few years now.
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    I'm *way* out of touch, but suspect almost none - They're changing so fast these days that it would just mess things up..... The infamous "it selected two gears at once" problem.....
    Cheers,
    Ian
  13. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Thanks Ian.
    I need a cigarette :)
  14. ingegnere
    ingegnere F1 Veteran
    5,566
    Montreal
    Would be nice if Ferrari adopted this design for production - as Lambo did for Aventador - instead of the dual clutch design which is too big and heavy.
  15. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :D
    I've just set the hi-res version as my wallpaper! - I can "study" it at will now ;)
    Cheers,
    Ian
  16. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    Just think, years ago it would be Farrah Fawcett on the real wall instead :)
    Next to the obligatory Countach of course.
  17. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    VERY cool, but I somehow can't get my head around how that gearbox design is supposed to work. Wouldn't you be engaging two gears at once with the two forks attached to each shaft/barrel? And what are the "gears" at the left side of each barrel doing? :confused:
  18. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Not if the timing is spot on....
    Ensuring the timing is indeed spot on. My take [and I've been wrong once today already, so YMMV ;)] is those plungers on the left are the feedback controls - They feed the TCU which then disengages one at (pretty much) the same time as the other engages - Hence seamless.
    I think......
    Cheers,
    Ian
  19. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    While not ingaged isn't the second gear "primed"?
  20. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Ahhhh. After staring at the picture for some more minutes, I finally got it. I thought of the forks being fixed to the barrels the whole time, which of course would prevent the latter from rotating... and confused the hell out of me ;)
    So as in a usual gearbox of that kind, the barrels rotate and the forks follow the shape which can be seen directly above them on the barrels.
    Your suggestion of the plungers on the left makes sense. Now that I have understood how it works, that seems the most plausible explanation to me, too.
  21. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :eek: Oh no! - That definitely wouldn't work! :)
    As BMW guy noted - It's remarkably simple in concept. Getting it to execute correctly is left as an exercise for the reader.......
    Cheers,
    Ian
  22. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    No sir. [But, again, I've been wrong already today....] - It has no idea which gear I'm going to select next so can't "prime" anything IMO.
    Cheers,
    Ian
  23. Alex1015
    Sep 1, 2005
    949
    No, if you notice, on the barrel at the top of the picture the paths for each fork are difference. So when selector fork has moved the dog ring for to the middle and the barrel spins again, then the other fork on the barrel will move.
    Or a variation on that, depending on the way in which the ratios are ordered. Enjoy thinking about that one ;)
  24. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    I already got that now, but thanks again for the explanation! As I said, I was under the impression that the forks were fixed to the barrels, which would render the usual operation with rotating barrels impossible, which somewhat made my head explode! :eek:
  25. Ferraripilot
    May 10, 2006
    17,786
    Atlanta
    John!
    #25 Ferraripilot, Aug 7, 2012
