Gearbox sealant question | FerrariChat
Discussion in 'Boxers/TR/M' started by JohnMH, Jan 3, 2017.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,800
    Bologna
    I am replacing the leaky viton o ring where the shifter shaft emerges from the transmission on the left side of the engine. The left front engine mount is off, I am about to try to remove the plate covering the three shifter shafts (I cannot recall if I have to remove the left front manifold to get it off). The rectangular cover for the opening in the side of the transmission has no gasket - do people use sealant on that cover?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,476
    romano schwabel
    I use RTV for this cover, but only very thin. you only may use hylomar, but also only very thin
    could you please tell me the part number of this viton O-ring?
  3. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,800
    Bologna
    105140.
    Thanks!
    I assume that I need to drain the transmission oil to get in there (as obviously oil sits inside the seal so as to enable it to leak out). Still, I have a hard time imagining that cavity is filled with oil without a gasket for the vertical cover.
  4. turbo-joe
    Apr 6, 2008
    9,476
    romano schwabel
    to replace this O-ring you have to remove the cover 117790, and to pull out the shaft 111870 you have to remove the cover 107450
    have fun with working :)
  5. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    Yeah I've had that side cover off numerous times. Just use RTV. Clean both surfaces.
  6. SBDaytona
    SBDaytona Karting
    Jul 13, 2010
    69
    #6 SBDaytona, Jan 5, 2017
    I just use Permatex Grey on a nice clean surface. Not too much as you don't want it in your travelling around in your gearbox. If you are really keen you can use a Viton Quad O Ring for a better more durable seal. I find it is better to exercise the O Ring with a socket as the shaft does not want to go in too easily. Good luck.
  7. ago car nut
    ago car nut F1 Veteran
    5,487
    Madison Ohio
    David A.
    What about Loctite anaerobic sealant 515?
  8. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,800
    Bologna
    Thanks to all that responded, I replaced that o ring 5 years ago, the viton quad o ring sounds like a plan.
    I forget, do I need to remove the manifold? I think so...
  9. SBDaytona
    SBDaytona Karting
    Jul 13, 2010
    69
    I have always done the seal when the engine is out of the car John.
    Does anyone know if there is enough room for the shift rod to come out so that the O Ring can be changed with the engine in the car?
    I have been in to adjust the shift mechanism with engine in the car and the front LH set of extractors needed to be removed.
    All the best.
  10. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    You must remove the manifold to remove the side cover.
  11. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,800
    Bologna
    No, engine is out. Last job to do before it goes back in. Thanks for the hint on the manifold, saves me an hour trying to do it with the manifold in place before giving up and removing it.
  12. wintech
    wintech Karting
    Jun 1, 2011
    206
    Perth WA
    Pete K
    SB I do believe that there is a post on that from memory. It does require the LH/RH shift adjuster removed to allow it to go forward (once the shift forks are removed)
    Then on reassembly of course; the shifter needs readjusting.
    What I found inside of mine (gearbox) was a significant amount of excess black silicon had gathered round the GB pump intake filter, from previous work carried out! bit of a shock to see it in there, but no evidence of it getting past the filter.
    Just a suggestion from what I found; the torque settings on the side plate after sealing and replace were not sufficient to seal the redline in there. as the weight of that side of the motor has only 1 close fitting lug to support the weight other than the 14 or so studs.
    The wave washers are high tensile yes, but still thin enough to to transfer the small flat area of the hex nut through and into the cast alum. Not exactly a metal on metal torquing.
    I had the pleasure of doing the job again after I leaked a Litre from the plate in 2 wks. 2nd time I used HT flat washers, and took the nuts to torque; using Permatex Grey. A smooth even thickness smear, then wipe away excess from non clamping faces. I left it for half an hr after torquing, then went over again 3Nmt more.
    I put the weight on the engine mount straight away and let it sit for a day or so to cure.
    I don't have any oil spots from any part of the car on the carpet now!
  13. ago car nut
    5,487
    Madison Ohio
    David A.
    Would anyone recommend Loctite 515?
  14. Rifledriver
    36,938
    Yes.
  15. Rifledriver
    36,938
    Locktite would suggest 518 for that.
  16. Steve Magnusson
    26,668
    +1 - 518 has better tolerance to contamination, better gap filling capability, and is thixotropic (so stays in place better) than 515.
  17. Rifledriver
    36,938
    I am really glad you defined that word.
  18. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,426
    Canada
    Newman
    Could win at scrabble with that word
  19. SBDaytona
    SBDaytona Karting
    Jul 13, 2010
    69
    +1 518 works great. Apparently it is also thixotropic - which means if you step in a bucket of it it will likely pull your boot off :) Good to know the shaft can be removed with engine in as - thanks.
  20. ago car nut
    5,487
    Madison Ohio
    David A.
    I haven't heard that word thixotropic for 45 years. Early 70s. lol
  21. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,999
    I learned on F-Chat that "THREEBOND" was best sealant for gearboxes. Is Loctite 518 the new top of the list?
    I don't know if THREEBOND is thixotropic ? :)
  22. Chief20123
    Chief20123 Karting
    Dec 22, 2012
    169
    Melbourne,Australia
    Fred
    I've used THREEBOND 1215 to seal gearbox about a year ago. I don't have any oil leaks.
  23. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    Wow. Is this place informative or what? 2 pages to answer what sealant to use on a gearbox.
    Thorough to say the least.
  24. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,800
    Bologna
    Seal in. Gearbox closed. Engine in. Thanks to all.
  25. turbo-joe
    Apr 6, 2008
    9,476
    romano schwabel
    and gearbox leaking??? :)
    if not may be you have forgotten to fill oil in? :)
    only joking
