Gearbox shaft O-ring
Discussion in '206/246' started by afer, Feb 11, 2018.
  1. Auction Ends Tonight! 1984 Ferrari 308 GTS QV: this beautiful well known and documented 308 auction ends tonight on FerrariChat around 8pm Central Time. must be subscribed to bid on it. more information about our auctions under Auctions - About Auctions and bid under Auctions - Current Auctions. Good luck!
  1. afer
    afer Karting
    Jun 4, 2009
    116
    Uruguay, S. America
    Alvaro Ferraro
    I need to change the O-ring that goes were the shift shaft goes inside. It's a 1970 L series car.
    Anybody knows the correct ID and OD of this O-ring ?. Regards, Alvaro
  2. dgt
    dgt Formula 3
    Silver Subscribed Owner
    Jan 14, 2011
    1,017
    Northeast, USA & Oz
    Andrew
    Hi Alvaro,
    From my notes, supercedes to Ferrari part #10257060.
    25mm O.D., 2.9mm thick.
    If you look at an o-ring supplier, 3081 is the part as it’s a standard o-ring.
    Regards, Andrew
  3. afer
    afer Karting
    Jun 4, 2009
    116
    Uruguay, S. America
    Alvaro Ferraro
    Thank you very much Andrew. Yes, in the Spare Parts Manual the part is 3081 but
    it's a good info that is the number of a standard O-ring.
    Regards, Alvaro
  4. afer
    afer Karting
    Jun 4, 2009
    116
    Uruguay, S. America
    Alvaro Ferraro
    Hi Andrew:
    I was looking on Internet at an "Italian O-ring sizes" table and it show 3081 with an ID 20,30 mm and CS of 2,62.
    This is very different to the CS and OD you sent me. What do you think?
    Regards, Alvaro
  5. dgt
    dgt Formula 3
    Jan 14, 2011
    1,017
    Northeast, USA & Oz
    Andrew
    #5 dgt, Feb 11, 2018
    Ah yes, the sizes I gave came from my notes and these were measured dimensions of the old O-ring and are approximate.
    This was the table I used but I see the company went out of business but there is a backup here:
    https://web.archive.org/web/20160820180102/http://mdmetric.com:80/or/ita2gb.htm
    All the o-rings for 206/246 L-series are in the table above using the standard italian part# from the parts manuals.
    Best, Andrew
  6. afer
    afer Karting
    Jun 4, 2009
    116
    Uruguay, S. America
    Alvaro Ferraro
    Thanks again Andrew. The table I saw is similar and in both tables are the same dimensions for 3081.
    Regards, Alvaro
  7. Tired of seeing this ad? Upgrade now
