Gearbox warning light and engine shutdown | FerrariChat
Discussion in '360/430' started by stnilsson, Jul 10, 2019.
  1. stnilsson
    stnilsson Karting
    Jul 4, 2007
    150
    Helsingborg
    Stefan Nilsson
    A couple of weeks ago I was at a car meeting. When I started for home I drove about half a mile and then the engine just died. When I turned the key the warning light for the gearbox was lit and there was a warning buzz tone. When I procceded to start the engine it started and did run att low revs for a couple of seconds the it died again. tried to change gear with just the ignition on but nothing happened. Checked the oil level and that the pump was running when I opend the door, both things were ok. Also tried to cut battery power but no difference. Any ideas? The car is a 99 360 F1.
  2. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    361
    Do you know if the car has had the variator upgrade or tensioner? Hopefully one of your variators didn't break or the left hand tensioner.
  3. RedNeck
    RedNeck F1 World Champ
    12,307
    The CSA
    Me
    You need to get your codes read before cutting battery power.
    brookliner7 and whatheheck like this.
