General F1 trans question | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by GTS Bruce, Mar 15, 2016.
  1. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    806
    Orchard Park NY
    Bruce Roche
    My 575 F1 has an auto button which I never use. Not interested. Never tried it. Was the 355 F1 introduced with an A button or was this introduced to a later model. Have heard 575 people complain that it doesn't work well while I know a guy with a 430 that says it works perfectly. He uses it when he buys a coffee and drinks it while driving. GTS Bruce
  2. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    My 355 had an auto button. Absolute crap & a waste of time IMO.
    However, I have heard some folks apparently 'used it' to justify to their significant others; "hey honey, it's an automatic!...... " ;)
    Cheers,
    Ian
  3. GTS Bruce
    Oct 10, 2012
    806
    Orchard Park NY
    Bruce Roche
    Thanks. Answers my question. Apparently it works better in a 430 than a 575 or 355. Wonder if it works well in a 360? Marvelous piece of engineering when you shift it. Heard the A button was an afterthought when added. GTS Bruce
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I used the auto button only one time in my 98 355 F1 GTS and that was the test drive (the prior owner started off in auto). It's horrible - shifts are at too low of RPM and jerky.
    I also tend to believe it leads to premature clutch wear. Case in point - I'm considering up grading my current 08 Maserati GT to an 09 GTS with 599 F1 transmission. Car has 13K miles and a clutch reading of 45% of wear. I'd bet 10K miles were done in auto.
  5. Rifledriver
    37,220
    It should work just as well as shifting manually. I never understood comments like Ians. It short shifts unless you put it in sport mode but they should work very well.
    Their big problem is the placebo effect from the internet.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    When I drive my car and shift via the paddles, I almost never shift below 5K RPM - often 7-8K. Auto does not shift the car at those high of revs. It's not a placebo.
    Using the F1 at low RPM makes for a poor experience and jerky shifts. Shifting at high RPM's makes for a pleasant and fun experience :)
  7. Hoodude
    Hoodude F1 Rookie
    3,453
    North Carolina
    RE
    ..joe,I applaud your ability to keep your driver's license😉👍..
    Cheers,
    RE
  8. mello
    mello F1 Veteran
    5,499
    CA Bay Area
    Steve
    My wife said that it works like her 1989 Volvo Turbo 760 that she drives during her college days.
  9. Rifledriver
    37,220
    I am trying to tell you it should not produce jerky shifts at any RPM. If I shift it at 1500 RPM it should still be a good shift. Besides the auto mode is perfectly capable of shifting at redline and in fact it should do so. If your car does not it is not working correctly.
    Additionally the clutch programming is identical for auto or manual mode. Those who believe there is a difference in wear are incorrect.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Brian, I've clocked many miles on my car and what I'm trying to explain to you is that low RPM shifts are not smooth while high RPM shifts are. I've driven other 355 F1's (most recenlty a 4K mile car) and it behaved the same.
    It's all a moot point as I shift my car at high RPM's and it's all good.
    I think you are going to suggest my system is not setup properly (on my 14K mile car) and based on my experience I think it is.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Sorry, I fully disagree. The system is not designed to shift at redline in auto mode as you suggest. You are suggesting in auto every gear change will be at 8500 RPM and that is false.
  12. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    I think the software detects the pressure on throttle, and will shift if the accelerator pressure is low, and hence you don't require max revs, but when you are pressing on, it registers that you need higher rpm shifts. I must say, I've not tested that, as I can honestly say that I have never used the auto button myself
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Sid,
    I've driven a 458 in auto and manual. The 458 in auto is pretty amazing and totally a different experience than the 355.
  14. GTS Bruce
    Oct 10, 2012
    806
    Orchard Park NY
    Bruce Roche
    458 is a different box correct? Dual clutch.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yep.
  16. Doug_S
    Doug_S Formula Junior
    Apr 8, 2007
    450
    NJ
    Doug
    I had a 360 and a 458. The auto mode is different. The 458 is adaptive and in Race if you push the throttle it is very aggressive. Even at lower speeds it will stay in a higher gear.
    The 360 seemed to me very primitive.
  17. daytona355
    12,655
    London
    Sid Korshak
    I'm not talking about my 458, I'm talking about the 575, 360 and 612 boxes, and the 430 come to that, which all have software of the type I described, or so I've been led to believe in the past. My 458 is a different animal I know with the DCT box, even then, I haven't tried auto. Just seems to be a waste to have a Ferrari and let it try to drive itself, even if it's good at it!
