Getting 355 into neutral if paddle shifters are not responding???? HELP | FerrariChat
Discussion in '348/355' started by hallsdad, Mar 11, 2018.
  1. hallsdad
    hallsdad Karting
    Mar 6, 2010
    88
    Cayce, SC
    Steve
    Hi,
    I just took the car out for a quick spin and the car seemed to drive normal but after parking out of the garage I got in the car and now it will not go into neutral (therefore I can't start it) by hitting both shifters? How can I get the car into the garage???
    If you see this and know the answer, please respond quickly since as we have bad weather coming for a couple days.
    Thanks,
    Steve
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Steve, are you sure you are letting the pump prime enough prior to trying? If the pump light is flashing, you cannot select any gears.
    BTW - call my cell if you like and I can try and help you 716-553-6130
    WATSON likes this.
  3. WATSON
    23,863
    WI
    Some quick thoughts....
    Without hydraulic pressure, the system will not shift.
    Is the pump running and does the gearbox warning light extinguish?
    Check the two large fuses in the foot well.
    Check the F1 relay that is located behind the drivers seat.
    A crazy thought......the battery OK?
    Do let us know how you get on.
    Dave rocks likes this.
  4. hallsdad
    hallsdad Karting
    Mar 6, 2010
    88
    Cayce, SC
    Steve
    Thanks Dave. Yes, I always let the pump completely prime. After trying about 4 different times, it finally just worked and is now back inside. The car has basically sat the last year so I wonder if that has anything to do with it. I am still curious if there is an emergency 'fix' if this happens again and I won't get into neutral.
    WATSON likes this.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, it's the Ferrari tool to disengage the clutch - I have one and we will make them sometime this year. :)
  6. hallsdad
    hallsdad Karting
    Mar 6, 2010
    88
    Cayce, SC
    Steve
    Once the weather and time permits, I'll be in the garage trying to get to the bottom of this. I'll start with the items mentioned above.
  7. scrappin35
    scrappin35 Karting
    Dec 13, 2011
    187
    FT Lauderdale
    Jim H
    Steve, this has happened to me a couple of times as well. I suspect its an intermittent issue with the neutral sensor. What I have done to resolve this easily on both occasions is to open the drivers door put my ass up against the door jam and rock it backwards. I remember reading it somewhere and it worked like a charm!
  8. hallsdad
    hallsdad Karting
    Mar 6, 2010
    88
    Cayce, SC
    Steve
    Well that would have never crossed my mind....but if it happens again it will be the first thing I try. Thanks!!
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    Check your motor mounts both of you.
    Many many times the motor mounts sag, sagging motor mounts turn into poor mechanical orientation for the actuator thus too much force to shift therefor locked up tranny.
    Shifter guys when it gets real bad notice because of the obvious feed back but us F1 guys its more of a work or do not work.
    This gets overlooked lots.
