Getting codes to reappear. | FerrariChat
Discussion in '348/355' started by 348steve, Nov 30, 2018.
  1. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    #1 348steve, Nov 30, 2018
    Hello all, first post for me as I just bought a sweet 348 and am going to start the winter project of getting the engine out and serviced. Lots of stuff in this forum and others, highly appreciated. I'll contribute as I move on.
    In the meanwhile I want some advice on triggering codes, and whether it is all so important right now.
    The car is already up in the garage and I don;t want to drive it on the Canadian roads right now. Last week we did a leak down test and thus erased the existing CEL codes that were flashing (and I never bothered to extract).
    Now I'm trying to get them to trigger again while the car is up by simply running it, but alas the CELs won't re-appear. Yes the bulbs are in there and the CELs illuminate during starting procedure.
    Thanks in advance.
    Steve
    Oh, in case you ask, we did a compression test at the same time and thus removed the ECU fuses, resulting in the loss of codes.
  2. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Personally I would let sleeping dogs lie and when you drop your engine unplug every electrical connector you can find on and around the engine and it's wiring harness, spray them with contact cleaner, plug and unplug them a couple times, then put it back together and see what happens. Remember you can "drive" it without getting it salty by jacking up the rear enough to get the tires off the ground and then start it and run it up and down the gears as much as you want ( with appropriate ventilation)
    Sent from my VS990 using FerrariChat.com mobile app
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,381
    San Carlos, CA
    Mitchell Le
    Well, there is always that gold kit....
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Now Mitch......:D
    But seriously, you probably won't get a code to reappear w/o driving unless it is something like a totally failed sensor or component. Things like O2 sensors, etc, generally don't throw a code unless the signal they are sending is out of the acceptable range, and that usually required driving under load to trigger.
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Mitch - that is the equivalent of saying "Beetle juice" 3 times and John appears :D ;)
    ernie and steved033 like this.
  6. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,490
    Atlanta, GA
    Steve D.
    ernie, wax and Dave rocks like this.
  7. yelcab
    Nov 29, 2001
    13,381
    San Carlos, CA
    Mitchell Le
    I ducked after that post.
    ernie, johnk... and Dave rocks like this.
  8. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
  10. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    I like the humor here, this is a great community! I decided to just move forward with the project and worry about the CEL after I pulled the engine out, serviced it the way I plan then get it back together. The lights were always intermittent at best anyway.
    steved033 likes this.
  11. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    Lookin good
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Uuuugh.
    Why Mitch, why????
    taz355, steved033 and Dave rocks like this.
