Getting Gas Issue on a 360 | FerrariChat
Discussion in '360/430' started by patrickenglert, Nov 19, 2012.
  1. patrickenglert
    patrickenglert Rookie
    Jul 31, 2012
    19
    St. Louis, MO
    the pump keeps shutting off after a few seconds when I get fuel.... it does this every time when I get gas... it is the like the vapor return is blocked and the pump shuts off automatically... any thoughts?
  2. andrew911
    andrew911 F1 Rookie Silver Subscribed
    Sep 8, 2003
    2,894
    Northern NJ
    it's a pain, but try holding the pump handle at a 90 degree angle while filling. I do this on my 360, and often did it on my prior 911 as well...
  3. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    I insert the gas pump upside down in my 430, then use the lock to have it keep pumping till full. Works great once you get used to it.
  4. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,544
    Charleston, SC
    Curt
    Same here.. Upside down is the trick.
  5. Chiaroman
    Chiaroman Formula 3 Rossa Subscribed
    Apr 21, 2004
    1,687
    New Jersey
    I stand there and hold the handle "up" a little.
    Sorry but I just can't set that little clicky thing and walk away.
    Don't overfill...first click and you're done.
  6. patrickenglert
    Jul 31, 2012
    19
    St. Louis, MO
    tried that as well... worked a bit better but not much.... I will try the 90 degree and see if that works any better.... what chaps my ass is I drive the car everyday (18,000 miles since March) so I get gas all the time and it is getting very frustrating..... Thank you for the input... any idea on what is causing it?
  7. andrew911
    Sep 8, 2003
    2,894
    Northern NJ
    Probably the shape of the pipe leading to the tank (s)- probably pressure/gas flow backs up triggering the pump to stop. Try it with the 90 degree (or upside down) trick- it's really not that bad. I can fill it just as quickly as my normal car with a 90 degree hold- it's not that big of a deal to me..
  8. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Replace the charcoal canister (part 180132) and check that the anti rollout valve (part 180030) isn't stuck shut because of the charcoal pellets breaking down from the canister and getting sucked back through the system.
  9. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    As above, check the vapour cannisiter - see here: Aldous Voice.
  10. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I had this issue and while trying to diagnose a different problem I found I had two blown fuses in the compartment behind the drivers seat (mine is RHD car).
    I replaced the two fuses and fixed my problem with the unexpected bonus that the next time I filled the car the pump didn't cut out till 75+ litres had been delivered. Prior to this I had no error lights, no faults but the damn pump might cut out as many as twenty times or more during a fill.
    I'd say your problems are most likely in the fuel evaporation / emissions / filter area.
  11. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    There is this one newer station by me that always gave me trouble in my '09 Boxster and now in my F430. So I just do not get gas there. Try to find a place that has older pumps they are not a environmentally friendly (vapors) but work so much better for tricky cars like these.
