GIVE ME A BREAK, Shell V-power, Now it's Nitrogen enriched, Come on! | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Spasso, Jul 5, 2009.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #1 Spasso, Jul 5, 2009
    What the hell was V-Power anyway? They never did have a decent explanation for it.
    You do realize that the "air" your engine intakes is roughly 78% Nitrogen that passes directly past the valves that Shell's Nitrogen enriched gas is supposed to clean? "Dry air contains roughly (by volume) 78.08% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide, and trace amounts of other gases". So how can adding even more Nitrogen into the fuel make it any cleaner? Maybe they need to add methane instead. What a scam!
    While they are at it they should include a Turbonator.
    This product is a "vortex" type product that is placed in the intake tract that uses engine vacuum to create a vortex in the intake tract which 'A" does nothing for air/fuel mix because it occurs before the fuel is introduced. and 'B' causes turbulence in the intake tract which equals DRAG and reduced flow which SAPS POWER from the engine by requiring MORE vacuum to pull it all in.. . A second cousin to the Tornado, SpiralMax and a few others, all variations on a theme. And they are all worthless. The only thing they do well is take your money and make it disappear. You want to use that $69.95 and get more HP and better milage? Use it to get a good tune-up.
    In a word, it is JUNK!
    I just can't stand the bad science and phony hype I'm seeing these days.
  2. racerx3317
    racerx3317 F1 Veteran
    Oct 17, 2004
    5,701
    New York, NY
    Luis
    Ok, but it's still better than BP with "invigorate" which makes your old car run like new longer. I don't even wanna know what's really in that stuff, if there even is anything different than any other sort of fuel.
  3. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I think I need that "Invigorate in my morning coffee.
  4. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Missing a little something here fellas. What they are talking about is not clear because they don't want you to know because it is so darn simple and it works. By displacing carbon this compound really works at cleaning and keeping clean all parts of a internal combustion engine
    Its not really fertilizer but rather a form of nitrogen of which their are many. It is in all likelyhood a boron compound and probably Methyl Borate added to the gasoline in a liquid form. You can create it in your own shop by dissolving Boric acid in Methyl alcohol actually one of the only solvents that it will dissolve in.
    Other products contain boron such as Z-Max and AvBlend which is FAA o.k'd for piston aircraft for addition to oil and gasoline. Nothing new here really just a very progressive oil company reformulating and creating a much improved product with a funky marketing gimmic.
  5. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #5 Spasso, Jul 5, 2009
    For the sake of argument, A) WHY would they NOT want us to know if it's so simple and call it what it is, a "Cleaning Compound" (Insert name Here)? B) The fuel doesn't reach all parts of the engine. Just the valves and combustion chamber.
    Like in AIR
    How does a Boron compound and Methyl Borate relate to an advertised Nitrogen Additive in Gasoline? Isn't that mislabeling a product?
    "Progressive"? Come on. Like Chevron's Techrolene. No more progressive than anyone else, just continuing research and development..
    Shell is pulling customer base with a new buzz word using much the same technology as before until Chevron can pull them back with their "revoloutionary" additive which may or may not be much better. And lets not forget Union 76.
    Thank you for the enlightenment and I admit I am not well versed in fuel compositions and additives. I think the key statement you made in your last paragragh says it all, "Nothing New Here"
    I am sure they are formulating an astounding compound a we speak, hopefully it will roll the odometer back on the TR
  6. SrfCity
    SrfCity F1 World Champ
    Yea, a gimmick that probably sets them apart for some. Why not ride on the "nitrogen thing" that is supposed to make your tires last longer? The whole V-Power is supposedly some additive that the truck delivery guy puts in when he's pumping gas into the gas station tanks. Whether he remembers to do it each time is probably another thing.
  7. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    Marketers contribution to society
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Chock full of wholesome goodness! :p
  9. UroTrash
    Jan 20, 2004
    40,604
    Purgatory
    Clifford Gunboat
    Pales in comparison to the bogus over the counter (back of the magazine) medical treatments.
  10. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Are you saying Extenz doesn't work?
    I'm crushed:)
  11. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    It does if you pull hard enough.
  12. AceMaster
    Feb 6, 2009
    34,778
    Ontario, Canada
    lol
  13. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Would the extra nitrogen help on "Trail Rated" vehicles also? I have a friend that has been using the extra hour given to us in the summer to haul Alpacas using a trail rated vehicle on his way to bring his son to some golf tourneys. I'm sure he would like to clean the carbon at the same time...
    BT
  14. TheMayor
    106,638
    Vegas baby
    I always buy Shell. Call it a marketing gimmick but I feel if they support the Ferrari team, that's good enough for me to buy their product. In some small way, I'm making a contribution.
    I did see the Nitrogen thing though. I'm no chemist so it may be total bull. But, what about "Techron" that's been pushed for years by Mobile to keep valves and engines clean? Does that really work? What the heck is "Techron" anyway?
  15. Etcetera
    Etcetera Two Time F1 World Champ
    24,146
    C6H14O5
    :rolleyes:
    It isn't junk.
    Shell discovered that nitrides of ogen hydrolyze unburned hydrocarbons and allows for more complete combustion resulting in greater power per kilogram of petrol and lower tailpipe emissions.
  16. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    #16 tundraphile, Jul 6, 2009
    I saw the ads for Ni-enriched gas and wondered also because variations of nitrogen oxides are some of the nastiest tailpipe emissions that catalytic converters have to clean up. What benefit would adding even more Nitrogen be to the gasoline? It makes sense that it is actually some complex molecule designed to dissolve (displace, whetever) carbon on valves. I guess calling it nitrogen in marketing-speak makes it accessible to the non-chemist. Whether it works or not is questionable.
    As for the turbo-swirly-intake thingie, I can't see how they would work to improve power in any way. Perhaps they actually provide a restriction in the air intake, the MAF sensor detects lower airflow and reduces the amount of fuel injected accordingly. The vortex generated of fuel droplets and air might atomize more completely (although I doubt it) and in theory give you a cleaner burning engine with a little less power than before, but it is more efficent. But sounds more like snake oil to me.
    By the way, I know Seafoam has been discussed here before but I prefer it to Techron as a gas additive. One can about every 5000 miles does seem to help. If you have ever tried half a can in the crankcase and then change the oil afte 50 miles or so, the amount of gunk you get out is remarkable. I tried it in my old DD and the oil was completely black and opaque.
  17. rsqrd308
    rsqrd308 Formula Junior
    Oct 27, 2007
    357
    Phoenix AZ
    Rick Roth
    About 78% of the cost of a bar of soap is in the packaging. 'Nuff Said.
  18. rsqrd308
    Oct 27, 2007
    357
    Phoenix AZ
    Rick Roth
    Oh, and 46.8% of statistics are made up on the spot.
  19. ProRallyCodriver
    ProRallyCodriver Formula 3
    Oct 25, 2005
    1,250
    Alexandria, VA
    Dave Shindle
    So if the nitrogen disolves crud, what is it going to do to your seals, valve seats, hoses, fuel pump, fuel filter, fuel cell foam....?
  20. TexasF355F1
    72,694
    Cloud-9
    Jason
    I believe it's 91.7%. ;)
  21. Rosso328
    Rosso328 F1 Veteran
    7,357
    Central FL
    Paul
    82.5% of people always get that figure wrong.
    And about the same amount will always fall for the same old crap so long as it's labeled "New And Improved."
  22. BBL
    BBL Formula Junior
    Nov 1, 2006
    658
    Northern California
    Sean
    "Awww, come on guys, it's so simple maybe you need a refresher course. Heyya! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads, and I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State." :)
  23. JCR
    JCR F1 World Champ
    10,975
    H-Town, Tejas
    Techron was developed by Chevron. It is their trade name for a fuel system cleaner that contains Polyether Amines or (PEA). The are other brands also. Take a look at the MSDS. AFAIK the highest concentration of PEAs is in Redline SI-1 Fuel System Cleaner. And yes, it does work.
  24. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    You are taking my statement of "junk" out of context. I was referring to the Turbonator.
    What is Ogen?
  25. JV's89
    JV's89 F1 Veteran
    7,334
    Pittsburgh, PA
    Fletch ?
