Anybody there still has problems with his glass of 348 slow?, I have the solution!, do it yourself!
I'm talking about it here: http://www.ricambiamerica.com/product_info.php?products_id=262540 Nothing against the price charged by RICANBI! (Total U $ 170.00 pair) Except that, learning that this universe of expensive toys, sometimes there are people making good money and easy! know that acquire a first part, and I'm curious, I decided to take a peek! and I was VERY upset to find that it is only 2 relays!! as a part cost me $ 85.00 U.S. + shipping + tax the other cost only U $ 5.00, made by me with identical materials found right here in the wilds of Brazil! so if ultil to be someone I'm with the electric diagram layout! (Free!)
Hi Full, i had that problem only for the right glass(i never understood why). I really appreciate if you can send me diagram and explain what I should buy in electronic store! Thank
Hi, I had the same problem and I've found this solution: http://www.btinternet.com/~frazer.smith1/ferrariwindow/index.html It works really well on both windows and it's easy to install. (half an hour for each window)
Hello! To my knowledge, the problem is due to an error in the wiring diagram made by Ferrari! there is a deficiency in the motor ground wire glass I do not know if the factory did recall at the time, should have been done! What do the relay is just fill in this gap, bringing the body from negative (door) After the project done, you must protect it in some container can be used even a small tupperware then just apply double sided tape and voila! Image Unavailable, Please Login
As to the two wires from the engine to the glass not have to worry about polarity can attach to any of the original (at door) following pictures then secure the ground was in the bolts of the door according to the photo Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hi Dani!, Diagram posted!, everything is very easy to do!... and your glass will be as fast as a cat! (normal speed of course!) KKKKKkkk!!
Great Full.....good job!!! Thank you from me and all the 348's owners! Soon as possible i'll let you know if it works.
Ok Dani! believe me, it is 100% effective! solved my problem once! Girl hug! (Daniele is man or woman?) In Brazil is a woman, if man is Daniel
Hello Ernie! It is a relay common good here! is called the relay service (universal multi-use) you just show the diagram to any electrician at a shop that he will know what it is! ok, hug!
www.ferrari-chat point nu/forum/viewtopic.php?f=77&t=1349&st=0&sk=t&sd=a&start=10 http://i51.tinypic.com/2zoex3d.jpg
I see that this is a different design in the case presented by me, is 100% true and in part purchased RICANBI what matters is bad work! that there had been properly tested?
It is perhaps a language difference, but I do not understand exactly what is being discussed in this thread. The accelerator modules you have are ones we purchase directly from the original Fchat designer, Frazer Smith, in England. (www.ferrariwindow.com). I have them in my 1990 348ts, and they indeed work as advertised and speed up the window. Call me today at Ricambi if time permits, or send a PM via FerrariChat. I'd like to understand better your frustration regarding the operation of the module. -Daniel
Hello Daniel! Actually I am very pleased with the part! What is being discussed here is that unlike the original pieces made by ferrari is that it is a very simple piece!, even homemade!, and thus should have cost a lot better! and, therefore, follows the formula to make their own personal part in the house! and as I said at the beginning of the chat, nothing to comtra RICANBI ok!, by contrast, whom we'd be without it! big hug!
Things of languages! I did not know how to treat, (man or woman!) It's clear now my friend! Have you done the project? Big hug!
OK, I understand. Build a better product, and I'll buy it. Really, if the product can be improved and proven, I would be very interested. It is always fun to find the projects of FerrariChat people in our Ricambi America catalog: F1 heat sinks Spider Top/Berlinetta Shade covers Window accelerators Gothspeed resonator caps and key blanks 328 door pocket springs High Voltage and Coolant Tank stickers etc. etc... all born here on FerrariChat and hopefully putting some money in the pockets of the folks who build and supply them to me.
