348 - glove box fix | FerrariChat
348 glove box fix
Discussion in '348/355' started by jebones, Feb 16, 2019.
  1. jebones
    jebones Karting
    May 13, 2015
    62
    NEOhio
    Since the little strut is no longer available I came up with a simple, if crude fix. A 1/4 inch spring mounted to the lower strut mount and upper hinge screw. The spring is from an assorted set of springs I bought for refurbishing a throttle linkage on an Alfa. I'm sure they ca be bought at any hardware store.
    Next step will be to get a proper lower pin and paint it the spring black. I may get a second one and try to even out the length on each end. I have a little video of it working but can't upload it. To close the lid, simply touch the spring in the middle and it folds.
  2. allandwf
    allandwf Formula Junior
    Aug 27, 2011
    267
    Scotland UK
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #3 Ferrarium, Feb 16, 2019
  4. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    The little strut is easily rebuilt for $25 from Strutwise in BC. Takes them about a week or two.
  5. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Good fix; but the strut is still available. I got one last year I think direct from Ferrari dealer. That said, they aren't suppose to last that long so your fix might be better!!
  6. Ricambi America
    Sponsor Owner
    Yes, they are absolutely still available. I refuse to sell them however, because they suck. There are plenty of alternatives that can whip the llama's ass. (early internet reference ;) )
    Get yours rebuilt/regassed or whatever. On my 348, I achieved a great deal of inner-peace with the realization the glovebox was too small to store anything except gloves anyway. And driving a Ferrari 348 when its cold enough to need gloves is a lesson in misery. I think Ferrari figured it out with the dashboard glovebox offered in the later F355. NONE!
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,169
    Malaysia - KL
    Miroljub Stojanovic
    If you have not thrown away the old "shock absorber", you can make a coil-over out of it:
    ernie, alexjack and QSA like this.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  9. jebones
    jebones Karting
    May 13, 2015
    62
    NEOhio
    Well gentleman, thanks for the replies. My recent internet searches have apparently been inadequate because I wasn't able to find any information on availability. My attempt at a quick fix came to me while opening a boat engine cover that used this spring principal to hold the cover open. I will proceed accordingly and also remove the failed strut from the center consul and get them both replaced or rebuilt.
    Again thanks, the F-chat community comes through.
    Jim
    QSA likes this.
  10. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Thanks for starting the post and sharing your solution. This is a good thread with multiple options all in one place and will surely encourage new ideas as well. I’m already thinking of some.
  11. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
  12. ernie
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    Stooge fix award!
  13. jebones
    jebones Karting
    May 13, 2015
    62
    NEOhio
    @ernie The spring was from an assorted kit I bought years ago for a throttle linkage project. It measures 3 in. by 3/8 in with about 2 inches of straight wire on each end. I used needle nose pliers to bend the loops. I was just curious if would work, its cool cus it's so simple. Once installed you may need to tweak the bends a bit it make it act like a strut.
    I also need the center consul strut and don't think this would work there. I plan on replacing both.
    ernie likes this.
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    First thing that comes to mind seeing that is RC Buggy coil over spring. McMastr Carr has them as well.
  15. m.stojanovic
    3,169
    Malaysia - KL
    Miroljub Stojanovic
    ernie likes this.
  16. ernie
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    Thanks for sharing Miro.
  17. bryanchin
    bryanchin Karting
    Jul 7, 2016
    82
    Malaysia
    Bryan Chin
    wow.. i did not know we had a glove compartment in d car... ROTFL
  18. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
  19. grigioalloygr
    grigioalloygr Rookie
    Apr 15, 2024
    2
    Demetre Katsouris
  20. m.stojanovic
    3,169
    Malaysia - KL
    Miroljub Stojanovic
    #20 m.stojanovic, Mar 5, 2025
    It appears that your car was originally a RHD and (cheaply) converted to LHD. On a LHD car, there should be a large relay/fuse box behind the rubber mat seen on your pictures. Where is the large relay/fuse box on your car? RHD cars have the box in the left footwell but you now have the pedals there.
    Or, perhaps, your car is a LHD but, for some reason, its relay/fuse box has been relocated. If this is the case, you can just have a custom made cover at the RH footwell.
