News
Glove box won't open
Discussion in 'Technical Q&A' started by jungathart, Aug 6, 2004.
  1. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
    Hi
    I need a little help figuring out this problem: on my 83 Mondial QV, depressing the switch to release the glove box will not work. When I manually pry it open I notice that if I push up on the plunger and depress the switch than it will hold up but cannot do it from a released position. Is there not enough current to the solenoid to magnetize it all the way up?
    How would I fix this?
    Thanks in advance. Will give feedback.
  2. Rifledriver
    Rifledriver Two Time F1 World Champ
    26,949
    Austin TX
    Switches go bad, but so do solenoids. Solenoids also get sticky, try lubricating it first with WD40 or equiv. If that doesn't do it I hope you have a good volt/ohm meter (every Ferrari do it yourselfer should) and check the voltage at the solenoid, it should be very close to batt voltage. If so put a solenoid in it, if not go back to the switch and check there.
  3. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
    Hi Brian,
    WD-40 did not work. Would it be prudent to go to the fuse box and replace the 5 A fuse with an 8 A to allow more current to the solenoid?
    I am not able to access the solenoid itself to touch the voltmeter to it: I think I would have to take apart the glove box itself.
  4. Rifledriver
    26,949
    Austin TX
    Fuse amperage shouldn't make any difference, But if your car still has the old style ceramic fuses, corrosion on the ends at the point of contact could. I don't think that will fix your problem but it can't hurt to try. You can always go straight to the switch ck voltage there and bypass the switch to eliminate those as the culprit.
  5. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
    I do have ceramic fuses and will check for corrosion.
    Is there any trick to correctly popping out the switch to test it?
  6. SefacHotRodder
    SefacHotRodder F1 World Champ
    Dec 20, 2003
    10,918
    NJ
    Chris
  7. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    .....USE A STIFF CREDIT CARD TO OPEN
    THEY WANTED $400.00 TO FIX THE BOX IN MY TR.....FORGET IT...
  8. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
    Hi,
    I was referring to the switch on the console itself. I am already using an old credit card to trick the hatch open
  9. theunissenguido
    theunissenguido Formula 3
    Silver Subscribed Owner
    Jan 21, 2004
    1,577
    Argent/Brasil
    Micheal Jordan
    Try to turn the switch several times on/off. Most likely the internal contacts have some oxidation on it. By turning the switch on/off, the oxidation will dissapear.
    Guido
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    What worked for me was:
    Disconnect battery
    Buy a spray can of Radio Shack electric contact cleaner
    Spray it into the switch through the sides
    Immediately cycle switch many (25+) times quickly
    Allow to dry one - two hours
    Reconnect battery
    Works fine now.
    hth, your results may vary.
    good luck
    rt
  11. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,844
    NoNJ/Jupiter FL
    Steve W.
    I have the same problem with my '84 Mondial QV. Pop the button and the compartment doesn't open. I'm going to try the contact cleaner suggestion and see if that works. Plus clean the solenoid also. Of course, yesterday I was driving around and the thing just popped open on me for no reason. Go figure. LOL
    Regards,
    Steve W.
  12. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
  13. FasterIsBetter
    Jul 22, 2004
    5,844
    NoNJ/Jupiter FL
    Steve W.
  14. jungathart
    jungathart Guest
    Jun 11, 2004
    3,350
    NoVA, AmeriKa
    Komrade Jung
    Will post, Steve
