Glovebox issue on 599GTB | FerrariChat
Discussion in '612/599' started by FNCOOL, Mar 5, 2021.
  1. FNCOOL
    FNCOOL Karting
    Feb 8, 2020
    115
    UAE
    GEZEN BILIR
    Hello friends. The button to open my glovebox does not function and I'm told it's a control unit problem and part is not sold separately. How common is this and any solution if you are familiar with the issue?
    Thanks in advance for the support.
    Sent from my VOG-L29 using FerrariChat.com mobile app
  2. craze
    craze Formula 3
    Mar 5, 2021
    1,161
    Melbourne
    Michael
    Some models need engine running to open or ignition on I think
  3. FNCOOL
    FNCOOL Karting
    Feb 8, 2020
    115
    UAE
    GEZEN BILIR
  4. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    361
    Jeddah,Saudi Arabia
    Majd B.
    Some times, using the key fob to lock / unlock the car 3 times will solve issues related to doors, windows or glove box.
    George Vosburgh likes this.
  5. Justin Hughes
    Justin Hughes Karting
    194
    Oxfordshire - UK
    Hughesie
    Theres a manual release underneath for emergency opening as well if needed
  6. George Vosburgh
    George Vosburgh F1 Rookie
    I've had luck with the key fob trick, also you might try turning the power completely off at the battery and reset the entire car.
  7. FNCOOL
    FNCOOL Karting
    Feb 8, 2020
    115
    UAE
    GEZEN BILIR
    Key fob trick unfortunately did not work for me this afternoon. Let's try then the other trick but I beleive my mechanic has tried already resetting by the diagnostic tool.
    I am aware of the emergency pull, we even fabrikated a stronger pull thing but it's annoying to go there when I need sth on a Ferrari.
  8. brogenville
    brogenville Formula 3
    2,329
    Robin
    You need to find out if power is getting to the glovebox solenoid when you press the switch by probing the wires. If not, then there will be an issue with either the fuse or the relay most likely.
  9. tazandjan
    39,392
    Robin- Or the switch.
    brogenville likes this.
  10. cfensty
    cfensty Formula 3
    1,109
    South Carolina
    #10 cfensty, Nov 10, 2024
    Hi everyone. I’m having some problems getting my glove box release to work. I’ve checked the fuse and removed the relay and tested it and the relay is fine. I tried locking and unlocking the car three times from the fob if I’m understanding that correctly and that didn’t work. The switch is brand new. I have no idea what to do next, but I find it odd that I’m only getting 4.5V at the fuse port. When I push the switch with the car running nothing happens. There is no click on the relay. Any ideas?
    LondonParis likes this.
  11. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    457
    Navarre, Florida
    Nick P.
    I've had trouble before with the trunk release, fuel door, and glove box buttons not working on my (612) car. This always seemed to be tied to using the battery master cutoff switch, which I've had to use on many occasions. Then I read the owner's manual a little more carefully. It states:
    On every (battery) reconnection and before starting the engine, proceed as follows:
    - unlock and lock the doors with the remote control. (I only do the sequence one time)
    I've been doing that procedure ever since, and I haven't had any more trouble with my solenoid release buttons. I'm not exactly sure what is going on there, but I think the lock/unlock sequence with the key fob helps to reestablish communication with the body control module or other peripherals. I hope this helps.
  12. brogenville
    2,329
    Robin
    Just to add to the list of reasons, in this case a dumb one, why your glovebox might not be opening on the switch... there is actually a menu option in the car setup page on the instrument cluster that allows you to disable the button.
    (I definitely didn't spend a couple of hours of checking fuses, relays, switches and wiring, battery resetting and lots of locking and unlocking before coming to this realisation... :mad:)
    Skidkid and Rex71 like this.
  13. Alden
    Alden F1 Rookie
    3,784
    Central Florida
    Could the car be in "valet" mode?
    Alden
