glowing red hot cat | FerrariChat
glowing red hot cat
Discussion in '348/355' started by 44qsake, Jul 2, 2012.
  1. 44qsake
    44qsake Rookie
    Oct 25, 2011
    36
    Troubleshooting an SDL & Limp Mode for some time. Replaced 4xO2 sensors and few other things. While codes were being knocked out, SDL & Limp Mode remained.
    Tonight I started to troubleshoot cat ECUs. I disconnected Bank 2 (Driver side) ECU and went for a drive. Limp mode went away, however, Bank 2 cat was glowing red hot. Luckily I was not far from home. Quickly got the leaf blower on it to cool. I'm on to something. The question is what.
    I believe this means the ECU is OK. Any suggestions why cat is getting so hot?
  2. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Possibly the cat is broke and the core lodged in sideways. I have a couple here that did that
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,730
    Fuel mixture is way off and the Cat is having to burn all the excess Fuel to keep emissions down.
    Or it could be a bad cat.
  4. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Is it firing on all cylinders?
  5. st4rk
    st4rk Formula Junior BANNED
    Dec 7, 2011
    447
    If the fuel mixture was off, wouldn't both cats be red?
  6. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Not necessarily. Each bank operates independently.
    One or two dead cylinders could put enough fuel in a cat to heat things up.
  7. F355Bob
    F355Bob Formula 3
    Nov 4, 2003
    2,001
    Madison, Wisconsin
    Check to see of plugs are fouled and not firing. Had this happen a few years ago and it was a bad plug.
  8. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,540
    Charleston, SC
    Curt
    Agree with this. Had this on my 360. Not firing on 1 or 2 cylinders, spent fuel went into cat and burned there. Don't drive too much on it, it'll trash the cat. Pull the plugs and check visually for changes in ash color. The ones that don't match are probably bad/ignition wires/coils bad.
  9. st4rk
    Dec 7, 2011
    447
    Ah, I see, that makes sense.
  10. schefdeh5
    schefdeh5 Formula 3
    Nov 2, 2008
    1,529
    U.S.A.
  11. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Bet you've been holding on to that photo for just the right opportunity, eh Schaf? Priceless...
  12. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Not an F car but, last time I had a cat glowing red hot, it's because the valve timing was off.
  13. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,089
    Honolulu - Seattle - Okinawa
    Steve
    How are the headers on that bank? Failing headers will trick the ECU via O2 sensor reading to dump fuel into that bank. That would kill your motor and cat.
  14. schefdeh5
    schefdeh5 Formula 3
    Nov 2, 2008
    1,529
    U.S.A.
    I had to do it....:p
  15. pourquoi_ne
    pourquoi_ne Karting
    Mar 16, 2006
    224
    England
    Pity!
  16. pchop
    pchop F1 Rookie Rossa Subscribed
    Jun 12, 2002
    2,667
    Usually NY often elsewhere.
    I had the exact same thing happened to me on my previous 355. The car drove fantastic all night and all of sudden, the SDL came on and I drove the car home in limp mode. When I got to the garage, I can see my passenger side Cats glowing through the engine bay. Took it to the dealer and it turns out that my cats were old and clogged.
  17. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Bad spark plug wire is a strong possibility.
  18. 44qsake
    44qsake Rookie
    Oct 25, 2011
    36
    Thanks for the input. It seems checking plugs and wires the easiest place to start. How will I know if a wire is bad?
  19. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    When on the highway, how low does your coolant temps go? If your coolant goes below 11:00 o'clock (180°F or 82°C is normal thermostat opening) after full warm up, it means your thermostat is 'stuck open' (normal fail position). This causes 2 problems, the first is your ECU will think your engine is cool and will richen the mixture. The second is the coolant is rushing through the engine, which does not allow the coolant enough time to draw sufficient heat away from the engine.
    Sooo, your engine will actually be hotter than the coolant temp gauge shows. Then because of the lower coolant temps the ECU will administer extra fuel as if the engine were cool ...... causing the rich A/F ratio, leaving that extra fuel to burn in the cats, overheating them.
    Note: The ECU coolant temp sensor and the temp gauge sender are only inches apart in the same coolant path. So what ever your gauge reads, so does the ECU.
    +1 ......
    +1 ....
  20. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,015
    socal
    i like this idea. 1996 355 obd2 car i assume? 15 y/o with low miles is as bad as high miles. cat substrate breaks down and plugs = heat. Since car is obd2 if the other theories presented make sense then you would see 0300 series codes for misfire. your sdl are probably working and have been telegraphing the problem for quite some time. It is starting to get critical. put a gage on the exhaust and see what the back pressures are. Increase pressure on the right where you got the red cat = cat death time to replace. If you get sdl's and p0300 series codes at the same time then I'd start looking at plug wires, injectors etc...
  21. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    You beat me to it. I was about to post that a misfire should throw a P030x code.
  22. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I lost a cat due to 3 intermittent spark plug wires.
    The cat glowed and the substrate subsequently failed
    When I tested (you will need a multitester from your local auto parts store....around $20-50 bucks depending on features but any one will do) all the spark plug wires for resistance....I found the readings very consistent, however when I subsequently tested for continuity (while lightly twisting and bending the wires) 3 of the plug wires showed no continuity.
    Replaced all the spark plug wires and no issue since.
    This is a very common problem on 355's .
    The design of the spark plug wire routing is very pleasing to the eye however very poor in design in that the spark wires are crammed into the valve covers.
  23. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Do you have the stock ceramic cats or aftermarket metallic cats?
    If stock ceramic cats......take a rubber mallet and tap the cats.....if they have failed you should be able to hear a rattling sound as you tap the body of the cat.
  24. 44qsake
    44qsake Rookie
    Oct 25, 2011
    36
    Thank you all for suggestions. Turned out to be a bad plug. She is fixed.
  25. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Glad to hear.
    Sometimes it really is the simple thing. :D
