Go-Pro question | FerrariChat
Go-Pro question
Discussion in 'Creative Arts' started by Cozmic_Kid, Oct 1, 2012.
  1. Cozmic_Kid
    Cozmic_Kid F1 Veteran
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    So a family member who liv in Stl got a Go-Pro camera for his birthday. he now use it when he rides his motorbikes :D
    He is annoyed with the wind noise though.
    So my question for the Go-Pro users is...
    What is a perfect solution to reduce windnoise significantly when you wear the camera on a helmet? A microphone placed somewhere else?
    Or maybe a little furball sticker or something?
    Any help would be appreciated.
  2. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,644
    California
    Ethan Hunt
    Did you check the gopro website? I think they have accessories for that sort of thing.
  3. Cozmic_Kid
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    *hehe* No I did not :eek: :eek: :eek:
  4. Cozmic_Kid
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    Not much of interest on there *LOL*
  5. suggett48116
    suggett48116 Formula Junior
    Oct 23, 2007
    267
    Brighton,Michigan
    Carl
    #5 suggett48116, Oct 1, 2012
    I ride a motorcycle and have spent some time perfecting recording with a GoPro. To get rid of wind noise on the helmet you will most likely need a mic somewhere else out of the wind path. I bought a fur cover (micover.com $19.99) that goes over the open back door which helped a lot with wind noise but the audio from the GoPro still is poor. I bought a tiny mic from e-bay ($13.99) that works much better but needs to be out of direct wind also and requires the use of the GoPro skeleton case. I've also used a $150.00 Rode Videomic also which worked super. the picture is a open back door with and without the fur cover and the e-bay mic.
  6. 4REphotographer
    4REphotographer F1 Veteran
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    I've never been able to get perfect sound from any video camera with filming on car (I'm going to assume it's the same on a bike). I think the only way to really get perfect audio is to get a seperate audio recorder and put it somewhere without any wind whatsoever. The deadcats do seem to work, but they never totally get rid of noise, especially once you get over 35 mph or so.
  7. suggett48116
    Oct 23, 2007
    267
    Brighton,Michigan
    Carl
    #7 suggett48116, Oct 1, 2012
    I have had pretty good luck by placing the GoPro behind my windscreen when using the small plug-in e-bay mic it's out of the wind.When using the Rode with deadcat I still put the GoPro behind the windscreen but the Rode goes under the tail section using a bolt I put in the empty hole that was my passenger peg mounting holes. The Rode is pointing at the exhaust so you only hear that! I have video of both setups if you like.
  8. 4REphotographer
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    I'm assuming you record from the Rode separately?
    I'm thinking about picking up another Go Pro and then finding a way to mount a separate audio recorder to my rear toe hook and point it at the exhaust, shouldn't be much wind noise mounted to the rear of the car.
  9. suggett48116
    Oct 23, 2007
    267
    Brighton,Michigan
    Carl
    No the GoPro Hero2 has a mic input :) below is a small clip of the Rode Videomic on the R6
    [ame]http://www.youtube.com/watch?v=oyq3JaiYK7g[/ame]
  10. 4REphotographer
    Oct 22, 2006
    6,197
    Arlington, VA
    Chris
    So you had a cable going from the GoPro all the way to the back of the bike?
  11. Cozmic_Kid
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    Thanks a million for the info. :D
    Ill forward it to him.
    He ride vintage bikes so I dont think he have a windscreen, but I am sure he can figure something out
  12. suggett48116
    Oct 23, 2007
    267
    Brighton,Michigan
    Carl
    Yes. I use a 6ft. 3.5mm Belkin cable that's sold as an extention for MP3 players.
  13. Cozmic_Kid
    Dec 1, 2005
    7,573
    Denmark
    B. Frandsen
    OMG!! Got home and watched this video!! :eek:
    If I had a motorbike I think I would kill myself!
