Go to source for air-conditioning parts? | FerrariChat
Discussion in '308/328' started by Ak Jim, Mar 5, 2021.
  1. Ak Jim
    Ak Jim F1 Veteran
    9,641
    North Pole AK
    What is a good source for air-conditioning parts? I'm looking to get a larger condenser, new drier, and a couple of new hoses. I replaced the compressor (went with a Sanden style) back in 2010 but don't remember the company I used. Thx.
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I've just been googling around as I need parts for my air conditioning project, but most of the parts have come from coldhose.com. I'd love to see how you get a bigger condenser in there. I'm not saying it's impossible, just having gone through this I want to see! I replaced mine, but it is essentially the same size with modern construction.
    waymar likes this.
  3. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    +1 for Coldhose....I just bought some reduced barrier hose to try out. Much smaller hoses to snake thru the tunnels. Now I need to find a crimper tool for reduced barrier fittings.
  4. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    A couple of years ago I bought a Sanden from Italian Car parts, it was 600.00
    I hope that helps.
    Thank you,
  5. Ak Jim
    Ak Jim F1 Veteran
    9,641
    North Pole AK
    Sorry but different car. I posted in this section because this group is the most hands on owners in my opinion. Probably cleaning 45 years of crud out of the condenser and radiator might be a good start! Image Unavailable, Please Login
    Du_Man likes this.
  6. raemin
    raemin Formula 3
    Jan 16, 2007
    2,349
    Lyon (FR)
    R. Emin
    I've been on the same boat: the info I've found on the 308 forum (see Carl rose guide on https://ferrari.cdyn.com/carl_rose_docs/Ferrari 328 AC Recharge.pdf) does apply to the 365/400 cars.
    There are a few exceptions though: the recommended compressor seal kit does not apply enough pressure, so you have to buy an Aspera seal kit (eBay). Also the 400 can accept a wider range of driers as we've got more room.
    I got a Chinese condenser meant for light trucks, same size as original, but twice as thick : https://fr.aliexpress.com/item/32363087412.html . Please note that the connectors are the newer types (with O-rings). Not an issue if you also change the hoses. They are now getting rid of these for $30... I should have bought a couple for spares, as this condenser is badly exposed to debris.
    I notice you do not have the Lucas Fans, your fans are compatible with the much more powerfull ones sold for the Golf cab, maybe worth a look. (https://www.mister-auto.com/ventilateur-moteur/volkswagen/golf/golf-i-cabriolet-155-1-5-70ch-1979-1983/)
