430 - GogglesPisano's F430 Ownership Journey | Page 14 | FerrariChat
430 GogglesPisano's F430 Ownership Journey
Discussion in '360/430' started by GogglesPisano, Feb 14, 2023.
  1. GogglesPisano
    GogglesPisano F1 Rookie
    3,299
    East Bay, California
    Joe
    I'm pretty certain that's what he meant as in the horizontal plane of the shift gate. I don't think the up/down adjustment is an issue here.
    oc23 likes this.
  2. Mario Andretti
    Mario Andretti Formula 3
    1,799
    Boston
    When you adjust the cables in the back; you need to make sure you take the cable play and actuator play into the account. You have to be very precise to zero out to be in the middle of that play for both when you select your point where you set and tighten...Easier to do if you are looking straight at the actuator, which means plastic pan out.
    GogglesPisano likes this.
  3. GogglesPisano
    3,299
    Joe
    Last time I spent maybe 30 min going back and forth on the one cable and driving around with the diffuser off for easy adjustment. I don't think there's a way to do it with the diffuser on, is there? Or are you talking about another plastic pan?
  4. Mario Andretti
    1,799
    Boston
    I did it with the whole big plastic pan under the car off, and diffuser off... just so I can look at the actuator perpendicular (or close to). You do have a better look from the front side of the rear lower frame bit...
    In the pic the pan is on, but just wanted to show what I mean...
  5. modificator
    modificator Formula Junior
    442
    Florida
    George
    In any case if the shifting gets worse when hot, the shift cable to adjust is the lower cable at the actuator (which rotates the actuator shaft). At the cabin end, it is the cable which attaches to the "triangle" on the left, corresponding to the sideways movement of the shifter.
    oc23 likes this.
  6. LorenzoR
    LorenzoR F1 Rookie
    But George, isn't the cable your referring to the main one to focus on for ease of going into gear adjustment? The other cable is for forward and back which how far your in gear is the easiest to adjust if I'm correct
  7. modificator
    442
    Florida
    George
    Hi Lorenzo, that is correct. The shifter front-back movement is easy to adjust, the side to side is the difficult one. The point here is that the shifting can be perfect when cold, but if it gets worse when warm (due to transmission metal expansion) - it most likely means that the original adjustment was not done correctly and further, small side-to-side adjustment is needed.
  8. Abowabah
    Abowabah Rookie
    31
    Jacksonville, Florida
    Karl
    Nicely done..Looking forward to the updates.
  9. GogglesPisano
    3,299
    Joe
    Thanks. Slowly collecting parts for future mods. Next on the list is the Founders headlight upgrade.
  10. Freddan
    Freddan Formula 3
    2,428
    Vansbro (Sweden)
    Fredrik
    Good choose of mod! If you we I'll do the carbon inserts like the scuderia, I have a brand new set laying :)
  11. GogglesPisano
    3,299
    Joe
    these are already carbon on the inside but anybody looking to modify their stock lights should definitely take this offer. I even have a spare set of lights they can use.
    grtoz likes this.
  12. GogglesPisano
    3,299
    Joe
    I love my Kline but, even with the headers, the muffler is just too damn good. Really makes it almost quieter than stock. I’ve been thinking how I could keep the valves open just a hair to let some noise through instead of making it super quiet and fortunately, someone bumped the old exhaust mod thread up.
    So, using that, I purchased a set of 1/4” split collars off amazon: https://www.amazon.com/dp/B0CR68YN8F?ref=ppx_yo2ov_dt_b_fed_asin_title
    These are stainless unlike the how-to’s black oxide so they blend a little better and hopefully won’t rust. They’re cheap hardware though taking the “stainless” description with a grain of salt.
    Anyhow, popped them on my valves in a minute and played with the volume levels using my Forza controller going open and closed until I found something I thought sounded good. Surprisingly, it was barely any movement. Maybe a few millimeters at most.
    I’ll likely play around with them some more but I’m happy for now. Gives it just a bit more aggressiveness without being too quiet so my only options aren’t super quiet or super loud anymore.
    You could likely accomplish the same thing by adding gasket spacers to the diaphragm end but this was way easier and more adjustable.
    mwstewart, Nico*, gammi and 5 others like this.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
  14. colorfull
    colorfull Formula 3
    2,360
    Franklin Park, New Jersey
    John Napoli
    Ingenious! Never thought about having an option here, great idea!
  15. ditpixs
    ditpixs Karting
    Apr 22, 2019
    232
    Nor Cal - Tracy
    Aaron
    Great idea! Might have to give it a try.
  16. Ferraray
    Ferraray Rookie
    28
    Ray
    I just got in my stainless Kline headers we can compare when I put them on. Steel wrapped in inconel. Took 4 months. Current setup is capristo test pipes and S line.
  17. GogglesPisano
    3,299
    Joe
    Nice! We can do side by side throttle blips.
    Ferraray likes this.
  18. GogglesPisano
    3,299
    Joe
    Took the car to work today so I had a chance to test out the exhaust mod. I think this is what turns the Kline exhaust from good to great. I have to stress that the amount I made it stay open is incredibly small. Anything more than a few mm and it basically sounds like it's wide open. You can see from the pic how far up the collar is on mine and I might try to close it up just a half mm more depending on how the drive home goes. If you're in the same boat as I was with thinking the closed position was too quiet, this is absolutely the way to go.
    LorenzoR, colorfull and Nico* like this.
  19. colorfull
    colorfull Formula 3
    2,360
    John Napoli
    #344 colorfull, Jun 26, 2025
    I like the fact that when it’s closed, it’s quiet and when you accelerate, the rush is from the speed and not the sound, I find it to be a very pure feeling
    I mean I love the sound and almost always have them open, but sometimes it’s nice to just experience the car in, relative, silence to feel how it is behaving without the audible blast which invariably draws your attention and focus
    ……though you’ve got me wondering
    no matter the case, thank you for inventing yet another solution for these amazing machines!
  20. GogglesPisano
    3,299
    Joe
    Finally had time this weekend to install the Founders headlights. Man, are these things super nice! It’s a welcome upgrade from the foggy stock ones with the chrome projector trim. Plus, it’s not some over the top mod that clearly looks aftermarket.
    Install was a huge pain (like all things). Lots of fiddling with the mounts and adjusting things. I ended up using my stock gaskets because I felt they helped me get a more flush look but the gaskets that came with the lights certainly looked more robust. Best of all, I had time to clean areas I don’t see normally :)
    I took the time to add PPF to them and get it down the sides, behind where the gasket sits. My stock lights had PPF, but the edge was visible. Now, they’re seamless. I’m not a pro, but I think they came out ok. There’s still some small lines of moisture that need to burn off so the final pic shows some of that, but they’ve already cleared up a good bit from when I originally put the film on. I used a water/alcohol solution to mist on the backside of the PPF so I had enough slip, but the added alcohol helps it evaporate faster.
    If anybody is considering these, i highly recommend them.
    Sj_engr, elysianweb, AandSC and 7 others like this.
  21. colorfull
    colorfull Formula 3
    2,360
    John Napoli
    They look awesome!
  22. Help Me DIY
    Help Me DIY Rookie
    25
    Greensboro, NC
    Aaron Sorgius
    Founder's lights just ordered... install video added to the list of future videos I'll be making. AFTER I finish the top install video ;)
  23. JPCIII
    JPCIII Karting
    Oct 4, 2024
    136
    Katy, Texas
    Jason P Curtiss III
    Looks fantastic!
    Jason
  24. Help Me DIY
    Help Me DIY Rookie
    25
    Greensboro, NC
    Aaron Sorgius
    Did you not end up installing the gauge faces? Last pic with the carbon cluster looks like it still has the stock ones.
  25. GogglesPisano
    3,299
    Joe
    I did not. I wasn’t happy with the way the back was coated as it wouldn’t have allowed the light to shine through evenly. It was odd because the first few were correct but the last one had some coating over most of the dial that only left the digits in the illumination zone. Also, the resolution was a tad off. I think because it wasn’t screen printed.
