430 - GogglesPisano's F430 Ownership Journey | Page 3 | FerrariChat
430 GogglesPisano's F430 Ownership Journey
Discussion in '360/430' started by GogglesPisano, Feb 14, 2023.
  1. collegeboy
    collegeboy Formula 3
    1,445
    Texas and Kaua’i
    Mikey
    Buying some of that stuff now.
  2. collegeboy
    1,445
    Texas and Kaua’i
    Mikey
    Any particular high temp fiberglass resin you used?
  3. GogglesPisano
    GogglesPisano F1 Rookie
    3,344
    East Bay, California
    Joe
    I just finished a vintage camper restoration so I took a chance with the resin I had on hand. We have a local store that sells it:
    https://www.tapplastics.com/product/fiberglass/polyester_resins/tap_bond_coat_laminating_polyester_resin/37
    They’re a chain but I don’t know how far they reach.
    Not sure that would be the most ideal resin if that was the top coat but I think I should be good for the little amount I did use to just smooth things out and anchor the mat. They do have high heat resins I can switch to if this fails but you might consider those from the get go if you’re starting fresh.
    collegeboy and AandSC like this.
  4. colorfull
    colorfull Formula 3
    2,400
    Franklin Park, New Jersey
    John Napoli
    You got that right, I def want mine to look like this
    AandSC likes this.
  5. GogglesPisano
    3,344
    Joe
    not a drive by but a quick cold start. Need to find a local stretch of road that isn’t full of traffic.
  6. Steve Heck
    Steve Heck Formula Junior
    Nov 1, 2021
    262
    TO Canada
    Steve Heck
    Wow Joe, that was certainly 'quick' ! LOL
    Sounds so smooth, exactly how it should be ... cant wait to hear more, will need a fly-by
    Cheers
    Steve
    armedferret likes this.
  7. GogglesPisano
    3,344
    Joe
    forty1, cavlino, mwstewart and 8 others like this.
  8. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,941
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    What was the cost of your conversation kit, looks great!
  9. GogglesPisano
    3,344
    Joe
    I’ve had my name on the list for quite some time now so I don’t think my price may be reflective of current pricing since some OEM pieces are getting harder to find. I would recommend getting in touch with George directly though (@modificator ) as he’s pretty responsive.
    I haven’t unwrapped everything yet as I really just wanted to see the shift tower since that’s the most impressive part. However, what I can see looks very high quality. Already had my wife hold the tower down as I pretend to drive :D
  10. colorfull
    colorfull Formula 3
    2,400
    John Napoli
    Believe it or not, it gets even better when you put it in the car:D
    fossilfuel and GogglesPisano like this.
  11. GogglesPisano
    3,344
    Joe
    Friendly reminder that old relays cause problems. Did this a while ago when I replaced my F1 relay with the one from Scud Ing Swiss but was cleaning things out today and came across my old ones.
    AHudson and Qavion like this.
  12. Qavion
    Qavion F1 World Champ
    14,651
    Ian Riddell
    GogglesPisano likes this.
  13. GogglesPisano
    3,344
    Joe
    Wanted to update this thread with some of the recent mods I posted about….
    1. My front end was way too high. Had it lowered and aligned. Total taken out about 3/4” to make it level with the back.
    2. Installed my Morimoto tail lights and decided to have a quick shoot to highlight these two things :)
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  14. GogglesPisano
    3,344
    Joe
    Managed to find some free time today and did a quick project. Installed my Forza controller and added some heat shielding to the side engine panels. I’m going to install a manual switch on the dash for the controller at a later date, but wanted to go ahead and get this in since it’s a quick install by itself.
    For the heat shielding, I want to expand this to all the engine panels but wanted to experiment with the rear most as they’re easy to remove and they had to come out anyway for the controller. I purchased some really thick DEI heat barrier: https://www.amazon.com/dp/B00JVAMONQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
    Made some templates of the backside using blue tape and cut out some panels to stick on. I kept it all a bit away from the edge and from the vent holes so you don’t see fibers poking through. The contours prevent a flat piece install so I used two patterns to complete the job. Here’s hoping this keeps my lights a little cooler at least.
  15. colorfull
    colorfull Formula 3
    2,400
    John Napoli
    #65 colorfull, Jul 16, 2023
    Damn, that's cool! Nice Joe
    So it's just held on by the adhesive backing?
  16. GogglesPisano
    3,344
    Joe
    Yeah. I scrubbed the back to prep and cleaned with thinner to give a clean surface. Should hold up in the heat.
    LorenzoR and colorfull like this.
  17. GogglesPisano
    3,344
    Joe
    I posted a while ago how bad the mounts were for my center brake light. I finally decided to dress it up a bit since I had extra heat shielding and a free hour.
    I yanked out the super flimsy stock heat shield and flattened it to trace a template. I bought some corrugated aluminum sheet for another project and cut a small section off to remake this. I added an additional layer of the fiberglass aluminized mat so it’s basically a replica of the stock piece only with better components.
    Folded it neatly, passed the wires through and reinstalled. One of those things I’ll never see again but I feel better because of it :D
    I also added some new aluminum washers against the body panel to keep corrosion at a minimum. Topped it with a stainless washer and stainless bolt.
    Sorry if the pictures are out of order. Not sure how to organize them.
    mwstewart, halr75, jerbear27 and 2 others like this.
  18. GogglesPisano
    3,344
    Joe
  19. colorfull
    colorfull Formula 3
    2,400
    John Napoli
    Capote related?
  20. enzoferrari
    enzoferrari Karting
    Jun 7, 2006
    51
    Awesome job Joe, looking forward to seeing the conversion and your opinion on how easy/hard it is for a DIYer, thanks for sharing!
  21. GogglesPisano
    3,344
    Joe
    I wish :) Unfortunately, John guessed it as top related. Sending off my front latch piston to get rebuilt. I know the rest are not far behind, but I don't have time/space at the moment to pull those out and just want to make sure I can enjoy my car for the summer.
    priericky128 and colorfull like this.
  22. priericky128
    priericky128 Formula Junior
    758
    St. Louis MO
    Rick
    There’s a little circlip where it pops off.
    The others are easy to take out id do the secondary ones above the windows at the same time.
    I’d do the ones behind the seats and in the engine bay together. They aren’t that hard to get out but they are harder than the front 3x.
  23. GogglesPisano
    3,344
    Joe
    That's what the instructions I read said, but there are zero circlips there. I could only find one clip at the end of the tooth rail. The piston was attached to the clevise by a collar that was locked on with a pin punch from the side and that first black pin was flush on both sides so it must have been pressed on.
    This next fall/winter I want to yank them all out along with the pump and send it out to have it all rebuilt.
  24. priericky128
    758
    St. Louis MO
    Rick
    Oh yeah sorry I thought you mean the teeth. Yeah the in between piece (not sure what to call it) is pretty difficult to remove. It can be drilled out I believe but not worth it since if you’re resealing it the whole piston comes out anyway iirc.
    Yeah I think my pump is leaking a little but honestly can’t tell if it’s just residual from me having it apart so many times [emoji28].
    I was planning to write a guide on the back cylinders when I get time. They are not hard but the back interior has to come out to pull the lines.
  25. GogglesPisano
    3,344
    Joe
    brogenville and colorfull like this.
