Going after clicking noise in front end of 430 | FerrariChat
Discussion in '360/430' started by bobp, Oct 19, 2013.
  1. bobp
    bobp Karting
    Jul 21, 2011
    80
    New Orleans
    Bob
    #1 bobp, Oct 19, 2013
    While my mechanic said dont worry about it now, the metallic clicking noise when going over minimal bumps at low speed in my 430 is driving me crazy. I have read all the threads and today applied the group knowledge and will share pictures
    1st pic: remove sway bar bushing- just 2 bolts - pull it over and lube bar under it with lithium grease
    2nd pic: lube sway bar at wheel attachment,you can lift up the lip of the rubber cup and sprayed in lithium grease(thats the red tube)
    3rd pics found 1 torn ball joint boot, shot in lithium, all other 4 ball joints looked good but still lubed.
    Verdict- will have to wait till tomorow ran out of time and have to go to dinner- but I will post results good or bad.
  2. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    958
    Valrico, FL & Franklin, NC
    Joe Gliksman
    Mine was the sway bar bushings--lithium grease fixed it.
  3. bobp
    bobp Karting
    Jul 21, 2011
    80
    New Orleans
    Bob
    #3 bobp, Oct 20, 2013
    tightened sway bar bushing end bolts
    tightened lower shock bolt
    lubed everything in sight
    Still have the clicking when driving out the driveway or over small bumps!!!
    when I raise and lower the car with my jack I dont hear the noise which I find strange since the suspension is being compressed and recoiled up and down??
    Where else could this be coming from?? and apparently from all the responses it not uncommon???
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    If you have ball joints with compromised boots then its likely them. Clicking over bumps is classic ball-joint noise.
    You can jack the car and force the joints by hand or with a second jack (depending on the joint) to see if it has any play. It is hard to reproduce the ball joint noise sometimes with a car jacked up Vs driving. But once the boot fails the ball joint is on its way out.
  5. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Doesn't Hill Engineering make a better ball joint than an OEM?
    Alan
  6. up4speed
    up4speed F1 Rookie
    3,700
    Long Island, NY
    Chris
    I don't know if it's the same clicking that you have, but I fixed a clicking in my 360 very easily. The sway bar end link on the right side loosened up about 1/2 turn or less and that was enough to create a clanking that sounded like a knocking on the floor board of the passenger side. I also thought it was the ball joints initially, but realized it was just a simple fix. The nut to check is the one on the edge of the sway bar tube (In your original post, 3rd picture, red thing points to it). You may have already checked it, but that's what fixed my problem.
  7. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    My bet is on the lower ball joints. Changed all of my front end upper and lower ball joints on my Scuderia last winter. I went for the hill engineering upgraded version, fairly easy to do...
  8. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    johan; Did you press out the old ball joints on-the-car, or did you remove the arm and use a bench/stand press? If so what ball joint separator/fork set did you use??
    +1; use Hill E if they make the part you need!
    Now that Ricambi has graciously sourced small portions of Hysol this can be a DIY.
    Please review their DIY: Ferrari Parts, Accessories, and Performance Products - Ricambi America, Inc.
  9. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    I removed the arm and put pressure on the joint with a vise. I then heated the ball joint. It came out easy. I think there are a DIY somewhere...
