Going to have to weigh my car after I get the fiberglass bumpers installed. | FerrariChat
Discussion in '308/328' started by AZDoug, May 27, 2021.
  1. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Weight reduction so far:
    Remove factory muffler and cats and installed Anza exh (~1987)
    New 12 lb battery
    removed spare tire/wheel,
    no York compressor,
    no air pump
    no exh header heat shields
    The factory bumpers weigh what, 80 lbs each? How about the compressible bumper mounts?
    An aluminum radiator replacement in on the list, also, the stock copper one has some heft to it.
    Doug
    mexicruiser likes this.
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    US cars have heavy door impact beams. Don't know if they are removable.
  3. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Mine doesn't have any beams,and it is a US car.
    Doug
  4. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    I wanted to ask why the concern about weight ? Your car is not going to be any faster in regards to what you are replacing . The 3x8s from the factory are already light in weight .Wouldnt you be better off making modifications to the motor, as in your aftermarket exhaust, or any of the mods that I see the specialists do on 3x8s.
    Thank you
  5. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Well, taking approx 400 lbs off a 3200 lb is going to do something, no?
    And weight is the cheapest thing you can do. And lesser weight also means better cornering and handling, in general. The polar inertia of all the weight hanging off the front and back is not good for quick handling response.
    I already converted it to 3.6 liter about 18 months ago.
    I like zippy cars, the generic 308 as is, is not one of those anymore, though 40 years ago, it was relative to everything else out there in 1980.
    But not now, in stock form, its a pig compared to just about anything modern. Why not have beautiful styling combined with modern performance?
    Doug
    308gts79 and ginoBBi512 like this.
  6. Imatk
    Imatk Formula Junior
    May 6, 2007
    774
    Hey if you decide to go to a Euro bumper let me know. My front bumper has a slight crack around the turn signal so I've been looking for one.
  7. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    I've already got the fiberglass bumpers on hand, i just need the time to install them.
    So, yes, my OEM bumpers may be for sale, they are in exc condition.
    Doug
  8. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    I believe bumpers alone are around 40-45 pounds each.......
    308 milano, miketuason and wise3 like this.
  9. ginoBBi512
    3,535
    SO CAL
    GINO RUGGIERO
    I did not know there was 400 lbs of weight savings that you can achieve on a 3x8 !! My 89 is still strong, I dont think I will spend any money with regards to motor mods, I like the idea so to speak, but Im not willing to go through the ignition mods , I like the motors components to be all factory. I agree that the 308 / 328 s sub 300 HP from the factory is just not quite powerful enough. Im grateful that the drivers experience thats built into these cars out weighs the low HP numbers. A Tubi / test pipe / K & N , has given my car a little extra grunt .
    Thank you
  10. Dal308
    Dal308 Karting
    132
    Coppell, TX
    Dude
    It will be interesting to see where you wind up. I have fiberglass bumpers, aluminum radiator, aftermarket parallel flow condenser, lightweight starter, slightly lighter than stock wheels, a Sanden compressor, but a full size battery. I have Verell's shock setup which I think saves from weight also. I'm at about 2750 pounds with the tanks half full and no spare.
    I think even a hundred pounds weight savings make a difference. If not in outright performance, in the feel of the car.
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Jbrauer and dinoart like this.
  12. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    351
    Mid West
    Paul John
  13. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    That about where i want to be.
    Thanks for the bumper weight confirmation, Mike.
    A pound here, a pound there, pretty soon you are talking about real tonnage*. :)
    *modified from a quote attributed to the late senator Evert Dirkson:
    "A billion here, a billion there, pretty soon you are talking about real money."
    Thanks for the info from both of you.
    Doug
  14. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,265
    Worcester, England
    Phill J
    Something to bear in mind when it comes to weight saving is: Weight distribution.
    You can make a car as light as can be, but if you mess the weight distribution up, it'll be fast on the straights, and corner like a broken shopping trolley!
    There's a reason why the pro's weigh each corner of the car ;)
    As for Colin Chapman, he didn't always get it right - Some of his race cars got a reputation for being unreliable, and even dangerous, due to his weight saving measures.
    mike996 likes this.
  15. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,328
    Montana
    Kim
    I read a bit on Colin Chapman when I had mine 78 Lotus Esprit. IIRC was afraid to return to Italy(?) for some time as he faced murder charges after one of his drivers died following one of Chapmans “make it lighter” ventures.
  16. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    From a handling and acceleration point of view, losing 40lbs off both ends is a good idea. Moment of inertia.
  17. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,315
    Germany
    Steven
    Talking weight reduction
    Us bumpers to ultralight (4lbs) ones
    Doors ( 75+lbs eacht) to 15lbs glassfibre ones
    Door and quarter glass to lexan
    Complete front and rear clip replaced by glassfibre
    Seats replaces by carbon buckets
    Brake calipers from an F360
    Removed top liner
    New ultralight center console
    3pcs compomotives
    Light exhaust
    Removed pop up light mechanics
    Glass fibre hood and bonnet
    Replaced stock shocks by aluminium ones
    Probably some more..
    Added a turbo setup. Needles to say, the car drives COMPLETLY different than my 328..
    steven_ew likes this.
  18. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I’ve been keeping a running tab of weight savings as I’ve restored my car over the years. Here’s the rundown, for reference:
    Cats 8.4lbs
    Ac compressor 23.6lbs
    OEM Muffler (45.6) to Ansa (36.8), savings =8.8lbs NOTE: got the Ansa spec from someone else here, sounds a bit heavy to me
    Remove spare tire: 35.8lbs
    Gear reduction starter = net savings of 9.7lbs
    Oem Radiator (27.8lbs) to aluminum (13.6lbs)
    = 14.2lbs savings
    -100.5 lbs TOTAL
    PLUS:
    Remove and store tool kit and jack bag (didn’t weigh)
    Smog equipment delete
    - pump (didn’t weigh)
    - injection rails (didn’t weigh)
    - sphere canister (didn’t weigh)
    - charcoal canisters - kept
    - Aluminum coolant tank (didn’t weigh)
    - Exhaust header heat shields (didn’t weigh, but next to nothing).
    - OEM Euro rear bumper: 8.4lbs (including attachment posts). Haven’t installed yet to weigh vs OEM.
    - Still working on sourcing a front, so ??
