Going to look at my first Ferrari Tomorrow | FerrariChat
Discussion in '348/355' started by Lars_vet, Apr 25, 2007.
  1. Lars_vet
    Lars_vet Formula Junior
    Feb 25, 2007
    603
    On the open road
    Lars
    well, as the title says, im going to Ferrari Denmark tomorrow, to see a 348 GTB.
    Can anyone tell me the specs of the brakes on the 348´s?
    Rotor size, and number of caliper pistion?
    Does the brake system change over the 348 models/year?
    Is the engine in the GTB the same as the tb?,and what causes the Hp increase?
    best reagrds
    /Lars
  2. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    The GTB has a slightly higher max RPM and a little different intake plenum. I believe the extra HP is mostly from the higher RPM allowed. Don't know the brake specifications. Good luck, try sending a PM to Henkie, he is in the Netherlands I think.
    BT
  3. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Welcome to Ferrarichat Lars. :):)
    Why do you want to know the rotor size and pistons in calipers? :)
    They are all the same, throughout all 348's. :)
    They are single piston calipers and I forget the disc diameter sorry. If no one chimes in here with the correct specs, I will let you know tomorrow if you like. :) Later 348's, GTB's, had 20HP more and higher redline. :)
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,684
    South East
    Jimmie
  5. IanMac
    IanMac Formula 3
    Jul 26, 2006
    1,455
    Scotland
    Ian
    ???? Four piston calipers on mine - at least on the front.
  6. Lars_vet
    Feb 25, 2007
    603
    On the open road
    Lars
    Well i use my cars at track days etc, and im interestet in the brake setup.
    Im very surprised its single pistons inthe front? really?
    Thansk for all the info!
  7. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    Brakes on later ('93 and up) are Brembo 4 piston calipers on all four wheels. Earlier model had different brand, but still 4 piston calipers all the way around.
    GTB was a later Euro model ('93 and '94) so it should have Brembo 4 piston calipers on all 4. I don't know the specs off hand, but my '94 tb has upgraded slotted rotors with stock brembo calipers. This was a challenge car, so stock brakes with upgraded pads should work fine for tracking.
    The GTB also had slight upgraded motor. 119G (as apposed to the 119H block for US cars) that had larger pleniums, different cams, and more compression. This brough hp up to 320.
  8. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Now I feel completely silly!! :):)
    I confirmed with another Fchatter (wont mention any names ;)) about the 348 brakes and he told me they were single piston calipers all round and were the same brakes used throught ALL 348's. :)
    I wanted some rebuild kits for my calipers, thats why I asked him to confirm for me. :)
    Sorry about that. :):)
  9. Moca
    Moca Formula 3
    Feb 3, 2007
    1,547
    Hungary, Szombathely
    Peter
    We want some pictures, if you buy that beauty ;) Good luck!
  10. CarbonJ
    CarbonJ Karting
    Mar 29, 2007
    239
    Arizona
    Jason
    Congrats and good luck!
