Gold Kit still in use? | Page 4 | FerrariChat
Discussion in '348/355' started by huzilulu, Dec 8, 2023.
  1. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,633
    VA
    Brendan
    Aren't the OBD electronics and harness connectors manufactured by Bosch? Aren't these the same connectors used on nearly all fuel injected European cars of the era? Or did Ferrari custom spec something from Bosch that is unique from all other euro auto makers?
  2. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Thanks for all the input … I didn’t realize this was SUCH a passionate topic !!
    I know I need to upgrade a bunch of my connectors - multiple boots have crumbled in my hands as I did basic maintainence (O2 boots, coil wire boot and crank sensor boot)… I don’t know where to buy boots and/or connectors that fit the 355 - the kit imho makes this part easy. I can get the pins/tools from various sources , but how do I know which connectors and/or boots are needed to properly fix a 355? Is there a list of connectors used on the 5.2 355 somewhere ?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    You need a bunch of Bosch 2 positions connectors, some 3 position connectors, and a couple hundred Junior power timers pins. Boots are also sold to fit those connectors and readily found. Don't get the extra thick ones because they are impossible to use.
    cavlino and ernie like this.
  4. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    I haven't heard of anyone that has had problems. If one has a problem with the kit, its on the installer . A few on here have a problem with almost anything that comes up. Its the nature of the beast. I have also been to Dave Helms place and he is an amazing person and has come up with many remedies for the problems that many have with the F cars.
    Targatime, Subito Grigio and cavlino like this.
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Man I thought we buried this issue long ago. Can't we just let it die? If you want to repin go ahead and do it. You chose whether you want to spend the very high cost for gold plated stuff (since the metal is way more costly now than before) or revert to factory tin. Either way the car will run better. Don't run your car in the rain if you have gold, not that we do or that it matters in the short run. Your gold or tin repins are probably going to out live you any way. So who cares? It's your money. Me, I'd do tin because I can't afford the upgrade. And I am totally fine with it. As for whether it was a scam or not - give it a rest guys.
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    #81 m.stojanovic, Dec 29, 2023
    I wouldn't say it was a scam, just ignorant to recommend gold pins where the mating pin is tin. Very good idea to create the kit but it should have included pins with coating matching the coating of what they connect to.
    I like the advice "Don't run your car in the rain". I would also add: don't keep/store your car in humid environment and don't wash your engine.
    ernie and vvassallo like this.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
    Have you actually looked at the difference in cost of tin vs gold pins? Tin runs around $22/100. Similar in gold is around $28/100.
    Call it what you like. It would never have sold at the asking price w/o the lure of gold.
    taz355 and ernie like this.
  8. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    487
    London
    Steve C
    Why? The car is designed to be used in the rain. I drive mine in the wet quite often, and it usually lives outside on the drive. I live in London. The car hasn't dissolved.
    PhilB, taz355 and 308 GTB like this.
  9. johnk...
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
    That statement was in regards to if the GCK has been installed in which case any water which gets into the contacts will act as an electrolyte and initiate galvanic corrosion of the tin on gold interface.
    I'd also like to add a comment about re-pining in general. I would not just repin the entire harness if I had an electrical problem. Forget about tin or gold, but if you think you can manually correctly strip all the wires to the proper length without nicking some and then crimp them to the new contacts manually with even close to the precision and consistency that an automated system use for the fabrication of the harness can, I'd say you are dreaming. This is another case of don't fix what isn't broke. Find the area of the problem. Correct it and leave the rest alone.
    MAD828, IvanRico and redwedge like this.
  10. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Exactly, usually mafs for some reason and fire wall plugs.
  11. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Right, Steve. When it's raining I just switch to my rain tires and go back out on the track...
    Watkins Glen International - August 19, 2021
    Ob917 and mclaudio like this.
  12. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Although the cars won't dissolve in the rain... unfortunately most of the weather sealing boots have dissolved. Likely due to heat exposure and limits of the materials used. I know mine have. Something I plan to address when the cradle is dropped next winter. Until then watch where you point that hose.
  13. yelcab
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    The car won't melt, it will just not start.
  14. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    Oh oh
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,625
    The Brickyard
    The Bad Guy
    Question is,
    Will you use what the electronics industry recommends?
    johnk... likes this.
  16. johnk...
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
    #91 johnk..., Jan 4, 2024
    I really don't understand why people don't get this.
    It's kind of like pouring water into acid. Just because this happens A happens does mean B won't.
    A:
    B: https://youtube.com/shorts/p8X9Xx0G6ik
  17. johnk...
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
  18. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    954
    Europa
    Bob
    When someone says basically the same thing 2,637 times already the impact of the message is somewhat diminished.
  19. johnk...
    Jun 11, 2004
    11,284
    CT
    John Kreskovsky
    Oh, you should know better than to set me up like that. ;)
    How many times should it take?
    Image Unavailable, Please Login :D
  20. ShineKen
    ShineKen Two Time F1 World Champ
    20,065
    Southern California
    Nostradamus
    I vaguely remember those times. That’s when Ernie became “The Bad Guy” lol. @ernie We don’t always have to agree, but you are still loved by the community.
    AT&T lookin’ good the past month :)
    ernie and rob lay like this.
  21. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    @ernie is NEVER the bad guy
  22. ernie
    Nov 19, 2001
    22,625
    The Brickyard
    The Bad Guy
    T is looking good. ;)
    ShineKen and rob lay like this.
  23. Jenni
    Jenni Rookie
    Apr 30, 2012
    22
    Scuderia Rampante
    Jenni Helms
    I wouldn't mind having a conversation with you in regards to "I have failed Dave Helms"
    Call the shop, ask for Jenni and we can discuss more.
    Thanks,
    Jenni Helms
    aka, Dave's daughter
    303-938-9000
    Ricambi America and ShineKen like this.
  24. WATSON
    23,972
    WI
    I did call you. It was in direct relation to Post 64 in this thread.
    Your response was "we don't sell those retail anymore, but for $1,000 we'll send a replacement".
    Uhm...OK. I'll pass given the quality.
    I ordered a proper set from Ricambi. They are working great.
    I had an overheat issue on the car after I installed your burp tank hose.
    Here is how well your silicon hoses work compared to a basic Federal silicone hose I happen to have:
    I just don't need the headache. All the SRI stuff is off the car and in the trash.
    ernie likes this.
  25. WATSON
    23,972
    WI
    BTW, if you are going to quote me, use the full quote from post 70 in this thread:
