News
Goo removal
Discussion in 'Technical Q&A' started by plugzit, Feb 5, 2006.
  1. plugzit
    plugzit F1 Veteran
    7,349
    Redondo Beach, CA
    Bruce Bogart
    What's the best stuff to remove undercoating? What about all the foam and glue junk from the leather upholstery in the interior?
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    14,841
    FL / GA
    Bill Tracy
    Goof off is an excellent product for removing all sticky residues. Sometimes you need to soak the surface, but it has worked for many applications for me. You might want to test it out on a small area first to see if it has any ill effects (discoloration etc...)
    BT
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,066
    The Brickyard
    The Bad Guy
    Why do you want to remove the under coating Bruce?
  5. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    #4 sparky p-51, Feb 6, 2006
    Here ya go Bruce. Simple green is what I used. Spray it on and let it set. Spray it on lots more. When gunk starts to loosen, spray it more and use a stiff brush. Repeat process until clean. Wipe whats left off with paper towels then rince with H2O and wipe again. Sure dont need that brown goo on suspention parts. No snow in So Cal and they dont salt the roads. Cleaned up underside of engine also. Makes it look much better. Dont know about interior glue. Have fun.
  6. To remove this ad click here.
  7. plugzit
    plugzit F1 Veteran
    7,349
    Redondo Beach, CA
    Bruce Bogart
    Lookin good! Thanks for the advice and the pics. I can only hope mine looks that good when I'm done. Don't understand why a car originally sold in CA would have that gunk sprayed on it-probably some evil dealer employee.
  8. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,157
    Austin TX
    They were ALL sprayed in Maranello. Product called "Dinol". 2 part process. Not an option.
  9. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,439
    VIR Raceway
    Peter
    Yep, "Tuff Kote Dinol" and in the warranty and service booklet, you had to have it checked at the dealer annually or semi-annually.
    For serious undercoating, dry ice and whack it!
    Wow, takes me back.
    -Peter
  10. Rifledriver
    27,157
    Austin TX
    I went to Dinol school. My only question was How do we get this crap off?
  11. To remove this ad click here.
  12. sparky p-51
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    Actually, solvent or gas is supposed to work the best, but sure didnt want the place to go BOOM. I did use solvent on the front suspention and it didnt seem to work any better than simple green. Green does not go BOOM. No brainer. One of the Northwest F chat guys lets the simple green soak on the area to be cleaned overnight and washes it down the next day with high pressure H2O. Gets rid of a lot of the hand towel work. Bet hot H2O would really do the job.
