Good for another 5 years! | FerrariChat
Discussion in '348/355' started by kenneyd, Nov 3, 2017.
  1. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    I actually was looking forward to doing my own major. I've worked on all different kinds of cars and planes for years, so when my car hit 5 years it didn't take long to put it on the lift. In hindsight, I would have been nice to wait 2 months to finish out 2017 so there would be a "last major 2018", but then again, i have no plans on selling it anytime soon.
    I spoke to two local shops here that work on Ferraris and both indicated to me they were, "swap the belts and done" jobs. I really wanted to do it right and have the cams Image Unavailable, Please Login , so that just turned into more affirmation on my decision to do it myself. Plus I personally believe the buttress cracks are caused my mechanics leaning on the quarter panels.
    First I want to thank the users here on Ferrari chat for all the great post here with instructions and write ups that took most of the guess work out of this.
    PRE-work pictures
    Compression check:
    1: 213 5: 197
    2: 215 6: 200
    3: 220 7: 210
    4: 222 8:190
    Looks like a mess!
    Image Unavailable, Please Login Hope I can remember those hoses!
    And its out!
    All in all, it took about 7 hours to get the motor out,
    90% of the work took 3 hours, one particular fitting (the power steering) took over an hour itself.
    The other 3 hours were spent looking for tools and taking pictures
    Pretty clean! Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    flat_plane_eddie, Yassa and Robb like this.
  2. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    Parts are here!
    Finding TDC:
    Huge thanks the Fatbilly bob and rifledriver.
    Pictures are not in order
    Cam seals
    Cleaned: Image Unavailable, Please Login
    Torqued:
    0.5 degrees advance:
    Close as i could get it on this bank.
    Bank 1 intake: 0*
    Bank 1 exhaust 0*
    Bank 2 intake 0*
    Bank 2 exhaust .5* early
    I used all three methods, Ferrari, Lobe centerline, and 20 tho lift, but preferred the ferrari method and used the others as a backup.
    Also the Ferrari method was the easiest and most consistent by far, followed by the lobe centerline. I always found these numbers to be within a degree or less.
    I found it interesting that according to several post here from prominent members claim Ferrari TDC is based on when the piston first reaches its highest point of travel. I found a very clear 3 degrees of piston dwell, meaning true TDC and ferrari TDC are 1 degree different.
    I based all my numbers on Ferrari definition of TDC. Using True TDC all those numbers are 1 degree avanced
    Tensioning the belts as per the manual!
    New water pump.
    No leaks, but it had a squeak when turned by hand
  3. INRange
    INRange F1 World Champ Silver Subscribed
    Jan 27, 2014
    12,672
    Virginia/Florida/Caymans
    JD
    Nice work and the pictures are great! Have you put it back into the car?
  4. Boaf 32
    Boaf 32 Formula Junior
    Aug 23, 2016
    392
    US
    This is great. I actually look forward to doing an Engine Out, but have some time. I have a 4 post lift and seen multiple posts for the engine out on a 4 post, but want to get a 2 post soon. How do most of the Ferrari shatters deal with the AC gas recovery. Would like to hear?
    Boaf!
  5. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    NEW:
    motor and trans mounts, many hoses, numerous seals etc.
    Trans mounts
    Valve cover paint was actually really good, but very dark. I sprayed to match the Plenums Image Unavailable, Please Login
    Inspired by "F355bob"
    I seen many of cars ruined by red paint in the engine bay. I think there is a fine line between hideous and great. I chose to mimic the look ferrari has used in virtually every model except the 355, and paint just the plenums wrinkle red. Im very pleased!
    DONE!
    Back on the road!
    I love how you can see the plenums through the bonnet!
    I also rewarded the car with a new carbon fiber splitter from M-tecnologia. Matches the spoiler!
    crinoid, F355Bob and Qavion like this.
  6. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,635
    SoCal LA/OC/New Mexico
    Tim Dee
    Nice
    Looks like a
    Well Done!!!!!
  7. F355Bob
    F355Bob Formula 3
    Nov 4, 2003
    2,001
    Madison, Wisconsin
    Very nice!
  8. Robb
    Robb Moderator Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,418
    Robb
    Outstanding.
    Robb
  9. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    It's been proven to my by Ferraridriver (Dave) in the 550 section that you can get much closer that .5 degrees as the cam pully / cam make a vernier scale.
    Interesting you measured 3 degrees of dwell - I've measured 1 on my 95 motor. In your example, you would be 1.5 degrees from the universal understanding of TDC and it's the mid point of the dwell.
    Regarding the buttress cracks - I don't think for a second it has anything to do with anyone leaning on the car. More likely the load as the car is lifted or even movement on the road.
    Regardless - strong work and thanks for sharing. Nothing more rewarding than doing your own work ;)
    crinoid likes this.
  10. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    762
    Vermont
    john truskowski
    Very well done!
    I'm really looking forward to doing my first major. The lift is going in next summer, and then I wait. I'm sure she will keep me busy till then!
    Efudd1957 likes this.
  11. jjtjr
    Aug 29, 2016
    762
    Vermont
    john truskowski
    Also, just curious how many miles elapsed since the last major? And what was the condition of the belts and tensioners?
  12. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,630
    San Carlos, CA
    Mitchell Le
    Nicely done ... too much red for me but hey, it's your car. I like the splitter though. I would scratch the hell out of that one on my driveway.
  13. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    Only about 6k. Both the belts and the oem bearings looked/ felt new
    Sent from my SM-G930P using Tapatalk
  14. CTE55AMG
    CTE55AMG Karting
    Jul 19, 2010
    94
    Stratford, CT
    Looks great, nice work, bet that feels great!
  15. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,798
    Lake Villa IL
    Looks great! Very nice work :)
    The splitter/spoiler and Hamann's really go well together.
    Looking back at the invoices on my car I have another year to go to hit the 5 year mark. Trying to decide if I'm going to do it this winter or wait another year.
    Agreed with Dave on the buttress cracks. If it was just the sheetmetal and the tech was 300lbs, maybe. With a square tube structure supporting it I just can't imagine someone leaning on it imparting any kind of bending/twisting force in comparison to the stresses endured on the road or track.
    Did you check the cam timing as it was when you pulled it out (maybe you said so and I missed it). Just wondering how much it was off and if you can feel a difference by correcting it.
  16. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
  17. Robb
    Feb 28, 2004
    14,418
    Robb
    Yeah, I'm just not into that much ketchup spilled in the engine bay...
    Robb
  18. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    So, seeing as how the belts and bearings seemed new after 5 years, you're still going to redo them in another 5?
  19. yelcab
    Nov 29, 2001
    13,630
    San Carlos, CA
    Mitchell Le
    You pays your money you takes your chances
  20. Nader
    Feb 12, 2011
    990
    East of Seattle
    In this case, the cure is worse than the disease.
  21. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,611
    AZ
    Rick
    Nice!
  22. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,854
    WI
    This looks great. I'll be doing my own next time as well.
  23. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    New airbox mounts:
    ~6k mile, 5yr old belts and tensioners:
    New SS acorn nuts and .5mm washers for valve covers and SS nuts and 1mm washers for everywhere else
    Top, heater hose with a buble
    Bottom, oil tank vent line cracked
    44k mile/ 18yr old motor mounts
    Short ram intake installed
  24. INTMD8
    Jun 10, 2007
    6,798
    Lake Villa IL
    My 5.2 car had issues with surging in crosswinds when I had the intake hoses connected to the 1/4 windows. Will be interesting to hear if yours is ok or not.
  25. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,027
    NE FL
    Ken
    Really? I thought this was the way that challenge cars and the 348 are hooked up, is it not? Did they have issues with surging?
    I did it so it's completely reversible, so if I do I'll just change it back
