Goodyear F1D3 for 77 308GTB | FerrariChat
Discussion in 'Technical Q&A' started by BillyD, Apr 14, 2006.
  1. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    #1 BillyD, Apr 14, 2006
    Well the QV replica 16 inch wheels arrived the other day & now its time for rubber. My research shows the Goodyear F1-D3 should be a good tire for my year round driving in the Northwest. I'm thinking about 225-50 front & 245-50 rear. If anyone has these tires on their car I'd appreciate a picture, with the chevron tire tread I'm alittle worried. The only track time the car will see is maybe 1-2 times a year when I finally sort the car & join local club. Let the comments begin please.
    Bill
    can't wait to get rid of the 60s Michelin technology
  2. Jdubbya
    Jdubbya The $10 Trillion Man
    43,589
    Hell's waiting room
    Bill,
    You went with the new wheels huh? Good choice. Did you get the windshield too? I don't know about the Goodyear tires but make sure you got the spacers with the wheels. It seems that some need them and some don't, but I can't see what having them would hurt.
    One way or another we will get together for a drive this year sometime.
  3. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    The Goodyear F1's are a great tire for this application - I have them on my stock 16 inch wheels on my 3.2 Mondial. The tread pattern is non-directional (as you know) so this prevents too much following ridges and other irregularities in the pavement. They are quiet and seem very, very sticky without a bunch of howling upon breakaway.
    Did you get staggered sized rims? The stock 16 inch QV rims are 7's on the front and 8's on the back allowing for some staggering of the tires sizes. I believe the stock sizing is 205 front and 225 rear. I definitely would not put a 245 on a 7 inch rim if that's what you have in mind - too much tire for 7 inch width.
  4. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    Yes 7x16 & 8x16.
  5. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Bill,
    I purchased a set of the repro wheels some years ago when they first became available from Superformance. When I fitted these wheels to the rear, I noticed the rear lug bolts were a little too long because of an interference. The remedy was to shorten the lug bolts by about 0.06 inches, which I carefully did on a bench grinder. Just be sure to check this out before you torque down the bolts. Otherwise, there is no reason to have to use spacers that I know of.
    Bill
  6. wise3
    wise3 Formula Junior
    Oct 10, 2004
    375
    FL
    Ward Orndoff
    It's been a lot of years since I tried 225's and 245's on my 308. I didn't like the squirm I got with my Bridgestone RE71's and Dunlop D40's, so I dropped back to 205/225. But a lot of people have been happy with 225/245. I think it depends a lot on sidewall stiffness. Hopefully someone will chime in on the Goodyears.
    One thing: unless you want to raise the rear, 245-45's would be more appropriate for rear diameter, if Goodyear offers it for these tires.
  7. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
  8. BigTex
    79,406
    Houston, Texas
    Bubba
    Hi,
    I have the Goodyear Eagle F1s, mine are GS-D2...???
    16" with widths as you note.
    205/55ZR16 on the front and 225/50ZR16 on the rear. That is the absolute max width on my wheels as the inside will rub if the suspension unloads too far!
    Take it easy over the railroad tracks! General lower ride height overall, it seems to be....lots more bottoming out on rougher roads, due to shorter sidewall....
  9. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    Thanks to all for their comments & Pictures. In the end I stayed with the Goodyear F1D3 but went with the smaller 205/55WR16 & 225/50ZR16 to help in puddles (my Vette has 275s and I hate white knuckling it in the rain). Also Birdmans 1977 GTB looks just like mine & I like the way it looks with this tire size combo.
    Bill
  10. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Thanks Billy!
    Mine is a little lower than stock, and the combo with the 16" wheels really modernizes the look. But the real treat is the difference in handling between the 14" wheels and the 16" wheels with modern rubber. WHAT a difference, like a new car. You will love it. I too felt that 245 on the rear was a bit much, but others have had success with it. I stuck with the stock widths.
    1977 GTBs rule!
    Jdubbya was referring not to spacers per se, but the hubcentric rings that come with the Superformance wheels for use on the front only. These help center the front wheels before torquing the bolts to be sure the wheels ride smooth. No idea why they are needed but they make a difference. They are just plastic rings. Search the archives, I posted pics.
    Birdman
  11. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    I have the F1's on my M3 and did a recent track event. I drove the piss out of the car and wasn't able to break them loose to hear tire squeel. I was extemely happy with the F1's on the track.
  12. f355spider
    f355spider F1 World Champ
    18,055
    Rain would NOT have been a problem...I'm running 235/45/17 and 255/40/17 on my BMW 540 M-Sport and they run GREAT in the rain...I've done 115 with no hydroplaning....
  13. jhsalah
    jhsalah Formula 3
    2,409
    Philadelphia, PA
    Jawad
    Hey Billy, all,
    Great to see this thread. Wish I had seen it a few days ago when I posted a question about what tires to get for my 1984 308 QV. Well, no matter, I did my own research and also ended up with Goodyear F1 D3, stock 205/55WR16 & 225/50ZR16 size. From everything I've read and the others I've talked to (mostly tire sellers) it's a great tire. And thanks to the person who put up the pics of those tires on the black 328 -- gives me a great idea of what they'll look like on my black 308!
    Happy driving.
  14. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    #14 BillyD, Apr 20, 2006
  15. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    ps 40 psi all around sound about right since max is 52?
  16. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #16 chrismorse, Apr 20, 2006
  17. Jdubbya
    43,589
    Hell's waiting room
    That looks great Bill! Birdman was right too, I was referring to the hubcentric rings. Like I said, some cars need them and some cars don't. I needed them for mine.
  18. BillyD
    BillyD Formula 3
    1,836
    Pacific Northwest
    Bill
    Chris,
    I was very tempted to do the 360 wheels, if I could have found a set reasonably priced & from a safe seller I'd have done it. Your car looks killer & I really like the Green, what color is the interior?
  19. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Very good on wet surfaces, and they work well in light snow (I know since I have been caught a few times in it).
    Thanks for the compliment, Chris. Spent a year picking out the wheels and tires.
  20. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Good grief! The original tires look like bagels!
