Goodyear RunOnFlat tires | FerrariChat
Discussion in '360/430' started by wrcimprezza, Mar 7, 2014.
  1. wrcimprezza
    wrcimprezza Karting
    Apr 26, 2011
    65
    I'll soon be needing to change my F430 tires and I do like the idea of staying in control after a puncture and being able to drive it with a flat. Are these things a gimmick? I assume not as Goodyear are a top brand they are mentioned in the owners manual. Not wanting to start a war about what tire has the best grip, just wondered if anyone has had the misfortune of having a flat on these and what your thoughts are.
  2. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    I think you may have to have the optional TPMS otherwise you won't know you have a puncture.
  3. Ferrari-F1
    Ferrari-F1 Karting
    Jul 12, 2013
    238
    Southern California
    I'm like you and also prefer to remain in control after a puncture...nothing wore than being stranded on the side of the road in a Fcar
    I usually take it to my nearby discount tire or someplace like that and use whatever brand they have. usually Michelin pilots or pirellis
  4. plahaye
    plahaye Rookie
    Nov 2, 2003
    49
    S La. swamp
    Phil LaHaye
    Run Flat Tires: Why You Should, or Shouldn?t, Buy Them » AutoGuide.com News
    You might want to read this article. I suspect you feel like they might help you maintain control if a tire goes away and that may be true at normal highway speeds in a straight line. If you are whistling along on a curvy road and a tire goes, the run flat will not help much. An elephant to race horse comparison, but I had run flats on my H1 Hummer and removed them because of the weight and balance problems. I suspect that they will do nothing good for the way your Ferrari handles.
  5. wrcimprezza
    wrcimprezza Karting
    Apr 26, 2011
    65
    Thanks for the info Phil, just ordered a set of PSS rubber having read that!
