Got a ThinkScan 689BT | Page 2 | FerrariChat
Discussion in '360/430' started by kenneyd, Feb 3, 2025.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    Cheap way to do e-diff bleed
    Use a power supply connected to solenoid
    DC Power Supply Variable, 30V 10A Adjustable Switching Regulated DC Bench Power Supply with Intelligent Charging Mode, 18W USB Interface, Precision Encoder Knob (Black) https://a.co/d/0KMa9K2
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,646
    San Jose
    dc
    #27 Sj_engr, Feb 5, 2025
    Thanks, I had heard of using a current limited 12v wall power adapter and tapping the solenoid as a solution also.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    Yes that is true - but having control over the amps is important to do a a good bleed.. you need about 1.1 amps to get the necessary pressure
  4. Mario Andretti
    Mario Andretti Formula 3
    1,837
    Boston
    So does this tool do the e-diff bleed in the end? Sorry if it's mentioned .... My Thinkdiag needs a yearly subscription of 50 bucks and does not do e-diff bleed.
  5. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,032
    NE FL
    Ken
    Yes, I posted a few screen shots in post 20, although i have not actually tried it.
    I think that was the most attractive part on this one, lifetime free upgrades. I've had a few tools where i would buy a car software only to have it stop working the next time i used it.
    This one works offline, no login required, so even if the upgrade servers disappear, it still works... in theory lol.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    Mario .. two questions .. does the option not show up or it just doesn't work since you have old firmware in ECU ? Are you connecting with iphone or android ?
  7. Mario Andretti
    1,837
    Boston
    Option shows, but does not work... connected with an Android.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    Mario
    It will not work with any launch tool including the one in this thread ..it goes back to the ECU version ....you can always put a tech request in and maybe they will fix the software..but it may be that ECU is communicating thru the bus the same way as the newer ones
  9. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,646
    San Jose
    dc
    eDiff ECU firmware, right? I wish someone would file a few tickets to get the 2.13 firmware eDiff supported.
  10. Mario Andretti
    1,837
    Boston
    I have exactly the same thing ! Manual writing on ediff with 2.19, and Thinkdiag reporting 2.13.... What gives :)
