What happened to these? Cant find them on the ricambi site, is Gothspeed out? Did I miss something? thanks
I’m hoping someone will buy the rights from goth or reverse engineer this product. I have one and it’s a godsend. Can’t believe it took 20 yrs of pain for someone to create this solution. It’s a shame he’s gone.
I think the problem is they are illegal. I read somewhere about the us gov epa broke a company that was making emmision bypass devices such as this but not for exotic cars. I think they mad them for a more popular car, got sued by the gov, lost, and went broke because they had to give everyone their money back or something like that. Sorry i cant elaborate
Not sure which one specifically is mentioned by Grant but there was a slew of them actually, most were diesel related, not to mention the whole VW scandal. Here is one for example, most products were designed to prevent cel's for the most part and let the car keep running bypassing issues. https://www.epa.gov/enforcement/edge-products-llc-settlement
I don’t think these would fall under the same scrutiny. They have nothing to do with emissions per se ,only the cat temps.
Yeah you may be right. Yet here we are unfortunately for whatever reason. I would not risk getting on the radar myself. Who knows, unfortunate though.
Isnt there a thread called "fear not the slow down light" that shows how to make your own fooler boxes to delete the temp probes and keep ECU happy? Is that what is being asked here?
There is a lot to unpack on this and some of us have been actively involved in coming up with better mousetraps to work around the sdl system. Gothspeed was making sdecu boxes that replaced OEM sdecu boxes and also had a “dummy” version in his lineup as well. For whatever reason goth and his boxes are NLA and that’s the story
I don't know the reason these are NLA. Goth is a brilliant guy. That said, it's my understanding that all of his products are side work. Product liability insurance is not cheap especially when it involves components that could be related to a car buring to the ground. Anyone in this space needs to evaluate the rewards vs the risk.
If you’re asking about cars in general and not fcars the answer is no. I don’t know what other species has sdl and bank and engine shutdown other than Ferrari. It’s origin may be from their racing background but that’s conjecture on my part
If I had to guess, it is the wasted spark on Ferrari that causes you to lose two cylinders if one plug fouls. Raw fuel into the cat and they overheat. Ask me how I know. Next project is coil on plug with MSD . Still have the wasted spark but twice the spark to each plug to prevent fouling.
It's wasted spark yes, but fuel is not sent to those cylinders as the fuel is controlled by the ejectors / ECU. The SDL system purpose is to protect the CAT(s)
BMW-s for the Japanese market (E12, E21, E30, E23, E24, E28) had an exhaust temp thermocouple and a special control "relay" marked "950C" (I happen to have one). The thermocouple shown is actually for BMW E60 M5, E63 M6 and E65 so some later BMW models also had it. Image Unavailable, Please Login Image Unavailable, Please Login Some Porsches (sorry about bringing the "P" in) also had the EGT monitoring: Image Unavailable, Please Login
Dave, that would only be true on a 5.2 car. Lose spark on a 2.7 and raw fuel is dumped into the into the cats. SDL! Had that problem a couple of years back. Remember, we talked about it. What's worse, unburnt fuel also means excess O2 in exhaust which means the engine goes rich. Anyway, what is the need for them. The green Ferrari TCUs seem to work just fine. Seems like with many things around here there was a manufactured problem when a few cars had problems with the SDL and bypass valve.
Had the same problem on my 2.7. They run rich and that is what they run a hotter plug than 5.2 and are easy to foul. If you drive these cars a lot at some point you'll foul a plug. Bad engine thermostat which many have had will keep you in this very rich enrichment cycle putting raw fuel in. Couple that with a very weak spark. Once the plug fouls spark is too weak to overcome. A MSD box puts out twice the spark as our coils. I had a ton of fuel enrichment taken out with my new computers and that solved that problem and I have run without thermocouples for years. If your TCU goes bad which mine did several times, it puts you in limp mode and it is hardly drivable. Had that happen several times out on a highway. Car won't go more than 40 mph. In my opinion I think Ferrari threw a bandaid on the problem with thermocouples at least on 95s.
John, you are saying on a 2.7 fuel is injected to cylinders on the wasted spark? If so, it still must flash off - right?
I wasn't talking about a 2.7 running richer than a 5.2. I was saying that if you lose spark, for what ever reason, a 2.7 does not shut off fuel to any cylinders. 2.7 cars can not sense a misfire. So fuel keeps flowing and with a misfire the cylinder charge just gets pumped into the exhaust. Since the fuel is un burnt, there is excess O2 from that cylinder. This makes the O2 sensor think there isn't enough fuel and the ECU richens up the mixture. This does nothing to reduce the O2 in the exhaust so the fuel trim goes even richer. FWIW, I've never had a problem with a cat TCU and never fouled a plug in my car, (95 2.7), even after losing spark due to an intermittent problem. After 8k miles my plugs are a nice light tan. I don't drive my car any where close to "drive it like it was meant to be driven". I putt around back country roads, shifting around 5 or 6k. Seldom apply more than 1/2 throttle. I give it a blast up an on ramp every once in a while, but that's about it.
No. What I was saying is that the 2.7 does not sense misfires and therefore does not cut off fuel to a misfiring cylinder. I thought you were saying a 5.2 does that, cuts off fuel to a cylinder if it senses a continuous misfire, in your response to Bob . I think what Bob was saying is that due to the wasted spark ignition, if a plug fouls in one cylinder then you may actually lose spark in 2 and both cylinders end up dumping un burnt mixture into the exhaust. I think that is quite possible. However, in my case the problem was a bad coil.
