Grease on Wheel | FerrariChat
Grease on Wheel
Discussion in '308/328' started by kman369, Dec 13, 2015.
  1. kman369
    kman369 Karting
    Nov 21, 2014
    99
    Winnipeg, MB
    Barry
    I took my wheels off to get them refinished and the right front wheel has grease on the inside of the wheel where it touches the axel. It looked like it could be excess grease from the barrings but there doesn't seem to be anything leaking out and the axel is dry. Any thoughts ? The axel turns with no problem. Just wondering if there is something I should be looking at. :)
  2. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    If I understand your description there was grease on the hub (axle)? Either way Ferrari wheels are hub centric which means the inner diameter of the mounting flange of the wheel is the same size as the raised lip part of the hub/rotor/etc. Short version is often times owners will put anti seize compound on the raised lip to prevent a reaction between the different metals, aluminum/mag of the wheels and the steel of the hub.
  3. kman369
    kman369 Karting
    Nov 21, 2014
    99
    Winnipeg, MB
    Barry
    That makes sense but the left side was clean and dry.
  4. URAS
    URAS Formula Junior
    Oct 17, 2014
    955
    Canada
    vince
    Could it be the rack leaking or a leaking shock absorber? May look like grease if mixed with road grime.
  5. kman369
    kman369 Karting
    Nov 21, 2014
    99
    Winnipeg, MB
    Barry
    It's completely dry and clean underneath. Thought maybe the Center hub cover was leaking or something. Maybe it was over greased at one point. I'm going to pop the cap off and re grease the barring and make sure it's sealed.
