Greased Lightning Convert | FerrariChat
Discussion in '348/355' started by RSO1091, Dec 11, 2012.
  1. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    After reading numerous posts and threads regarding the best way to strip interior parts of the gooey coating, I tried using the recommended EZ-Off, brake fluid and other methods with overall success, but a lot of elbow grease and time. I then read the thread about using Greased Lightning degreaser (available at Lowe's) and decided to give it a try. I gotta tell you guys, there is absolutely no comparison between the two methods/products. To begin with, the GL has no fuming issues and comes in a pump-style bottle. No need to let parts soak, just spray on and use coarse steel wool, followed by another spray and some fine steel wool and rinse off. You might have to go back over some small portions of sticky finish you missed, but overall it takes this stuff off almost instantly. On the small crevices and nooks on the back of the ash tray door, I sprayed the part and let it soak for about 15 minutes. I then got what I could with the steel wool combination, but ultimately finished things off using my air compressor. Once the degreaser had a chance to sit on the sticky coating, a direct blast from the compressor took everything out of every nook and cranny. I want to thank the original poster who came up with this product idea and give him full credit for his discovery. Because this process has proven to be so easy now, I have decided to do the entire interior myself, a little at a time. The parts I have already re-finished with the plasti-coat look like they're brand new, as does the ash tray done in the Rustoleum fine textured finish (after using a zinc-based primer). Anyone contemplating re-doing their own interiors owes it to themself to try this stuff out. I have no affiliation with the product or Lowe's, just wanted to confirm how impressed I was with Greased Lightning. Henry
  2. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    893
    San Marcos, CA
    Vas
    Great info! Thanks.
  3. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I wish I had known about this product last year when I redid my sticky parts. I researched EVERYWHERE online and on various Ferrari sites and tried ALL the different methods. The absolute best method was the oven cleaner/brake fluid but it was still a major major PITA (I spent insane amounts of time on the steering column...hours!!!)
    Anyway, I'm glad a better solution has been found and can't wait to try it out next time I have to tackle this issue perhaps in my next Fcar!
    Thank you for the info...
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Nice info, thanks for sharing Henry.
  5. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Ive looked everywhere and cant find this miracle cleaner in Toronto, Canada. Ill have to pick some up when I go to florida.
  6. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,916
    Richmond
    Pete
    I might give it a try this weekend. There are 3 remaining sticky pieces in my interior - no idea why the PO did all the rest and left those, maybe they hadn't gotten sticky yet? He did all of the hard stuff and left the easy stuff (gauge pods), so shouldn't take me long.
  7. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    I too cleaned my major sticky parts (steering housing, ashtray etc...) with the easyoff method. I have to say the easyoff took me no time at all. But, my lungs suffered I am sure :>) I read somewhere about the GL also. So, thanks for the affirmation on the success of this method...
  8. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Just a brief post to clarify some things that I have been asked by others via PM. To re-finish the cleaned parts, I used Black Plasti-Dip (SKU#7581511203) on the switches, door parts and steering wheel encasement, then Zinc Primer followed by Black Rustoleum Fine Textured paint on the HVAC console and other metal parts. Everything is looking like it's brand new up to this point. Henry
  9. apex97
    apex97 Formula Junior
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    I just tried GL and I agree that it is a simpler less stinky solution than Easy Off.
    All I did after clean up was to apply two light coats of Rustoleum texture paint. It comes out really nice.
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Which greased lightning are you guys using? Is it the yellow bottle, super strength?
    Also many of you are making the ashtray part harder than you have to. Use paint stripper and it bubbles right off in less than 1 minute.
  11. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Don't think this product is available in Canada so I just bought a bottle while vacationing in Florida. Wife thinks I'm nuts....never bought a cleaning product before....
  12. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Not sure if it's the super strength one or not, but it is in a yellow pump bottle.
  13. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    #13 GerryD, Dec 16, 2012
  14. apex97
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    I used the super strength one, also in a yellow bottle!
  15. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    This is the super strength.....its hard to see on the lower left. I might be in the niagara N/Y area next week...I will pick me up some to try out.
  16. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Yeah I double checked. Mine is the Super Strength as well. I am done with the driver's side door (including stripping and re-dying the black leather portions), steering wheel covers and center console. Couldn't be happier with the results. Working in my shop and watching football games on a Sunday afternoon really makes the cleaning/re-painting time go by pretty quickly.
  17. ClydeM
    ClydeM F1 World Champ
    12,059
    Wayne, NJ
    Clyde E. McMurdy
    Ok, let me add my thanks to this thread.
    RSO1091 (aka Henry) pointed me not only to the Greased Lightning from Lowes, but to
    Plasti-Dip, made by Performix. Black #7581511203. I bought the paint on-line.
    A tooth brush, 5 minutes with GL, rinse (keep the water out of the switch). The passenger window switch was clean of sticky black mess.
    I masked-off the white switch icon with painter blue tape as well as the non-exposed base, then a quick zap with Plasti-dip.
    Amazing! It looks great! and Original!
    Now I'm ready for the next sticky mess.
  18. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    157
    Gulf Breeze, Fl
    Craig Payette
    It's amazing how sometimes a better way is found purely by chance. I was literally looking for the easy off oven cleaner in the house and couldn't find it. There were a lot of cars in the driveway and I didn't feel like going through the trouble of going up to the store to get more. So, I figured that I would give greased lightning a try, and when I saw the sticky goo come off as I was spraying the stuff on, I knew that I had to pass on this discovery.
  19. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    And we all REALLY appreciate it Craig. Thanks again...
  20. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    And we are very grateful that you did!
  21. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    It's almost like discovering penicilin by accident...
  22. Rs200tez
    Rs200tez Karting
    Oct 5, 2011
    144
    Bristol, England
    James
    Unfortunatey we can't get our hands on this in the UK because one of the ingredients is banned!
    "It is thought that 2-butoxyethanol contributed to the significantly shorter lifespan of Exxon Valdez clean-up workers, which is why Corexit 9527, which also contains the chemical was banned in the United Kingdom"
  23. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I bought and tried this Greased Lightning on a couple of sticky parts and it doesn't do anything. It seems like a cleaner more than anything.
    I bought it a lowes and the bottle looks just like the one on this thread.
    What gives?
  24. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    Sorry to hear that Erick, but it worked absolutely great for me. Did you let it soak for a while and use an abrasive cloth to take it off? Henry
  25. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I didn't, I'll go let it soak and see if that helps.
