Great now my frunt lid will not open!! | FerrariChat
Discussion in '308/328' started by masonfamliy04, Nov 12, 2008.
  1. masonfamliy04
    masonfamliy04 Karting
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    I just put my 83 308 qv front hood on. Now it will not open!! WTF!!!! The hood has not been on the car for two years. When I pull the front lever it releases the hood 3/4 to one inch then it is locked again. If I try to pull up on the hood with the lever pulled open still nothing! I can push it back down, I can hear a click. I can hear the cable release the latch then it will pop up the 1 inch. Is there a safety latch? please help!!! thanks Bill!
  2. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    try pulling on the lid while holding the open latch - inside the car ........ might work!
  3. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    I did that, like I said it will pop up the one inch but then nothing. I then can push it back down and re-close it.
  4. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    push the lid all the way down, hold it and ...... and pull the lever
  5. 8KRedRacer
    8KRedRacer Karting
    Jun 7, 2007
    196
    Georgetown, KY USA
    Alan Bennett
    #5 8KRedRacer, Nov 12, 2008
    The same thing happened to me about five years ago. The previous owner ran a make shift cable to the latches and the cable had stretched over time thus not releasing the bonnet. What I did (if I remember correctly) was removed the front grill/bumper and unbolted the bonnet at the hinges. Then carefully slid the bonnet towards the front of the car until the bonnet was clear of the latches. Be carefull not to scratch your paint (bonnet studs on the underside) while removing the bonnet. Also, it is helpful if someone can give you a hand. I hope that helps!
    Alan
  6. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    Thank you I will try that to night.
  7. GeoMetry
    GeoMetry Formula Junior
    Apr 14, 2008
    471
    Virginia
    Richard
    #7 GeoMetry, Nov 12, 2008
    Did you try the backup cable? Both the front and rear lids have a second cable on my 85 QV. They are hidden pretty well since they are seldom needed. Mine is normally tucked behind the carpet but I pulled it out for this picture. I assume they are there just in case the primary cable breaks.
  8. ferrari sulla pellicola
    ferrari sulla pellicola Formula Junior
    Jun 21, 2004
    621
    Los angeles
    Richard
    sounds like a latch alignment issue as there are 2 latches on these so one of them is probably hanging up..sometimes it helps to have an extra person to do this once the lid is closed have the out side person gently press down on the lid in the center,once its compressed down the person inside pulls the release open and then outside person can try to pull the hood up.if that fails than do the same thing on which ever side of the hoods not releasing.
  9. masonfamliy04
    Nov 29, 2004
    221
    Brooksville Florida
    Bill, Amanda, Tyler
    I want to thank all you guys for your help!!! In the end I had to take 5 of the 6 hood bolts out. It was not that hard, but my wife had to come down in the shop and help. If this hapens to you use two people it's the only way. I think I made the hood to tight to the front, this made it catch on the crash safty slide. Now both of the latches are working as they should! I'm going to diagnose more in the morning. Thanks all!
