green fuel hoses | FerrariChat
green fuel hoses
Discussion in '206/246' started by GermanDino, Sep 20, 2013.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,482
    Germany
    Matthias
    Does anybody have a source for 5mm and 16mm green fuel hoses?
    I ordered weeks ago with PR Products, but they still haven`t proceed with my order... no idea what`s going on there....
  2. TKO
    TKO Formula Junior
    Oct 22, 2004
    790
    SoCal
    Tom Kearns
    5 and 16mm ... inside or outside diameter?
  3. HMB-Dino
    HMB-Dino Formula 3
    2,258
    Pebble Beach, CA
    RonG
  4. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    inside
  5. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    thanks Ron
    but the main problem seems to be 16mm... the correct outside diameter is 20mm (so 16x20mm). Only PR Products seems to have the correct one, but they don`t answer e-mails or phone calls at the moment....
  6. HMB-Dino
    HMB-Dino Formula 3
    2,258
    Pebble Beach, CA
    RonG
    What is the ID/OD of the fuel line between the carbs? I know it was originally Cavis green, but the Spare Parts Catalog TAV-8 doesn't give a size, just FIAT 1/90531/80 Qty=2
  7. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    Matthias,
    Something to consider if you can't find what you are looking for is to use clear hose and then dye it. There are several products that come to mind like Dylon and RIT dye which are used specifically to dye synthetics. All you need is the dye and some hot water. The colour you get can be controlled by immersion time in the solution.
    I played with RC model cars in a previous life and this technique was commonplace to colour nylon parts. As an aside, you can also use this method if you want to make yourself some reasonably priced yellow nylock nuts for places like the suspension. The only caveat is that you would need to start with nuts that have a white insert so that they dye properly.
    Best Regards,
    Paul
  8. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    Hello Paul, that sounds interesting...
    I might test it, if I go nowhere with finding the correct ones...
    Many thanks.
    Regards Matthias
  9. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    I used Rit dye and made my own using clear tubing from McMaster-Carr.
  10. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    Dylon I can get easly here in Germany, also clear petrol tubes in the correct size, I will try at the end of the week....
    Would you dye the complete hose, also the inside?
  11. omgjon
    omgjon F1 Rookie
    3,568
    Spicewood, Texas
    Jon Gunderson
    I submerged the whole hose in Rit Dye, using a mix of kelly green, lemon yellow and golden yellow.
  12. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Jon:
    You got this to work? I tried the same stuff (albeit on brake fluid compatible hose), and it the tubing did not change color. Is the hose you used brake fluid compatible clear hose? As you many know, Miura's used Cavis green hose for the brake and clutch in a very visible location. I am trying to avoid using Cavis because it sweats brake fluid for a long time, causing paint damage, etc.
    BTW, I searched for clear hose in Mcmaster and didn't find much.
  13. racerboy9
    racerboy9 F1 Rookie
    2,634
    I have green hoses on my race Stratos restored a couple of years ago. Must be current production hose. I'll post a pic later and you can see if it is the correct green you are looking for.
  14. racerboy9
    racerboy9 F1 Rookie
    2,634
    #14 racerboy9, Sep 23, 2013
  15. GTA246GT
    GTA246GT Karting
    Oct 23, 2005
    79
    Sweden
  16. rynoshark
    rynoshark Formula 3
    1,033
    Pacific Northwest
    Did anyone ever inventory all the necessary Cavis hose sizes and lengths for the US Dino and the differences for Euro-spec Dinos?
  17. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    Paul gave me that trick and I have used it with RIT dye on white nylock nuts which i had yellow passivated and they came out great….also on hoses..one of the best tips yet! Good luck & Thanks
  18. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    I was happy with my textile-covered hose. Now I have a problem.
    Does Superformance, others sell a set? I hope someone says yes to Rynosharks's query.
    Andres
  19. Motob
    Motob Formula 3
    Nov 11, 2003
    2,353
    Frederick, Maryland
    Brian Brown
    Newco now sells the green hose in most all of the sizes used on Ferraris. It is not just dyed hose. I have used it and was very pleased with the color and quality of the hose:
    Newco Products - Newco Cavis Green Style Hose
    Brian Brown
    Patrick Ottis Co.
  20. rynoshark
    rynoshark Formula 3
    1,033
    Pacific Northwest
    #20 rynoshark, May 18, 2014
    On the "CAVIS BENZ 5 x 9" fuel overflow line on the firewall, noted in TAV 7 #14 (part 607E-821179), there appears to be a one way check valve and another rubber hose extension. This isn't in the parts book and I'm curious as to what this is, and whether it appears on other Dinos. It doesn't make sense to me what this would be doing here as I believe this hose is open to the air on the bottom and is just a drain in the event fuel is filled too high. Any ideas?
  21. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    Ryan, that valve isn`t original.....
  22. rynoshark
    rynoshark Formula 3
    1,033
    Pacific Northwest
    Thanks Matthias. I wonder why this would have been added! I'll remove it and look for any part numbers for clues. Perhaps somewhere in the huge amount of service history on my car I can find when it was inserted.
  23. GermanDino
    Aug 14, 2007
    3,482
    Germany
    Matthias
    maybe for US registration (close cycle fuel lines).....
  24. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I've tried this and on 4 types of fuel line clear tubing and 3 will take the color but loose much of its clarity. Is this your experience too and does it clear up when fuel flows?
    Thank you
    Both Euro and USA only had a cross tank vent line there.
    I'm using the German Rauclair-E and it has started to loose its clarity after 2500 miles
