Greener Aircraft, Innovative Design Topic | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by JeremyJon, Apr 13, 2011.
  1. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    well, i'm not an enviromentalist, but i do think the extent of the aircraft industry is due to see changes in the near coming years, simply as a matter of economics (vs green) in fuel consumption, and operating costs overall
    aging fleets, means the replacements 'should' incorporate the best thinking we can muster, to address concerns of enviro impact, in design and development
  2. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    true, the private owner/operator is definitely a different mind-set, then employees of a charter or cargo company
    even the independant is going to change with the times, when available options change ...look at racing as example, available fuels changed, and teams adapted, retired old cars and carried on ...IMO the same will be so
    this falls back to my previous question for those here inthe industry ....for the medium sized craft segment, how much life is there in the existing available planes?
    it seems to me there have been not many truly "new" designs, the piaggio 180 discussed here, was a design started in the late '70s! ....i agree to that VJs are a 'toy' only
    sadly, the diesel option doesn't seem realistic based on the engine weight i agree, unfortunately ...otherwise this fuel option, torque at low rpm (good for prop drive) and even fuel capacity required reduced ...are all good things
  3. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    #28 JeremyJon, Apr 16, 2011
    interesting, i can understand that ...the raptor UAV uses basically a helicopter engine with prop, but of course it doesn't need to meet the same cruise and payload considerations
    your insight makes me think about a few things i've learned, and on the use of an alternate fuel such as diesel ....when working in northern canada for many years, we used alot of helicopters ...once a tech told me that they could run on diesel in a pinch, but would need a engine rebuild immediately afterwards....
    ...i also know that the military (US) have been using small multi-fuel turbines (power generation i think?) that can use diesel, even purple diesel, without the rebuild issues...
    ...to meet the power-weight in a medium craft, couldn't a company specifically build on it's existing turbine design, with the use of diesel in mind, to re-design for that purpose and with low-maintenance in mind too?? hmm
  4. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    The more you have to lift, the larger the craft you need and the more fuel you will burn. If you want environmentally friendly, you need "light weight".
  5. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    I'm only 37 and have been flying since 2007.
    There have been a dozen new designs in the last 10 years but all those companies failed. Not because the design was bad but because the government makes is sooooooo cost prohibitive to launch a new design.
  6. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    That's perfect. That's why I want this engine. I like flying mid teens, VFR, NORDO, Direct. There's no faster way to get somewhere.
  7. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Unelss you like to buy a lot of gas you really don't. That engine has a specific fuel consumption above .6 lbs/hp hr. At 250 hp you are burning over 150 pounds per hour (more than 23 gph). A good recip will be burning 18, so that's over $25/hr in DOC...
  8. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    A gas turbine can be made to run on most any fuel. The Model 250 is actually allowed to run for a short time (I think it was like 30 minutes, but don't quote me on it, I'm going from memor here) on gasoline. Diesel fuel is a very close cousin to JetA, but turbine fuel nozzles are susceptible to coking up, and of course, diesel begins to solidify and have problems with wax coming out when it gets cold, do it's really a bad aircraft fuel. Gasoline doesn't have the lubricity of JetA or diesel, so that's why you have to rebuild the fuel control if you run it on gasoline. If the fuel nozzle is designed so that it doesn't coke up, you can burn most any liquid fuel in a turbine. JetA costs a lot at the airport, but it's really not that much more expensive to make than diesel, just the cost of insuring it is what it is and the ability to follow it from cradle to your tank is what makes it cost more. Airlines don't pay all that much for it, but anything bought at an airport does..
  9. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    #34 solofast, Apr 16, 2011
    That's true for big engines, but small engines have a lot of room for improvement, and the technology to do that has been demonstrated, but it isn't in production yet.
    Let's start by defining big and small. As it is now the dividing line is at about 1300 hp. Above that size engine you can cool the blades and the compressor is big enough that higher cycle pressure ratios (above 13 to one) become common. Those engines typically get SFC's of about .45 lbs/hp-hr. To put that into perspective that's actually a bit better than a good normally aspriated gasoline recip (.48) and not as good as a diesel (.36-.38). So if you look at engines like the T700 (2100 hp), T800 (1500 hp) or Series IV PT6 (2100hp), you are looking at cooled blades a bit higher PR's and very respectible SFC. Some people are thinking that the PC12 is thirsty, but when you consider the amount of power you are using, it really has a pretty efficient engine. Not cheap because of the cooled blades, but they are efficient.
    The problem is that small turbines, below 1,000 hp have lower pressure ratios (around 8 or 9 to one), and the blades aren't cooled, and consequently they burn a lot more fuel than recip's. That's all true, but the real reason is that there hasn't been as much money invested and development carried on in small engines. The leading small engines (PT6 series II, RR Model 250 C20, and TPE331) are all really old engines. They were first laid out over 50 years ago. Think about that for a minute. How much better are car engines than they were in 1960? Those legacy engines have an SFC of .6 or higher, while even the latest engines in that size class have an SFC of about .52 (think Honeywell HS900), which is better, but still not quite as good as a recip.
    Recently there has been some development and testing of smaller engines (in the 750 hp class), that have much better SFC than the current production engines. Honeywell has run a 750 hp engine under the Army's Small Heavy Fuel Engine program. The Army put up $25mil and Honeywell matched that and they have demonstrated the program goal of an improvement in SFC of 20% from the baseline (old tech engines). There is another company working under a government contract that will run a core early next year using advanced materials that will have an SFC of less than .4 lbs/hp-hr. That's within 5% of a diesel, and the engine actualy weighs less than the legacy turbines. One of the reasons the airframers aren't bothering to put an RR500 into a 4 place airplane is that about the time they get it certified, they are going to be facing some new technology and they will have paid a big bill to cert their airplane only for it to be obsolete in a couple of years. To put that into perspective, think about an engine that weighs about 200 lbs (a lot less than a PT6), makes 700 hp at takeoff, and at altitude, making 360 hp, pushing a Lancair propjet at almost 400 kts and burning about 20 gph....
    Bottom line is that the technology to improve small turbines is out there and is being developed, but the market for turboprops is relatively small. Unless you have other places to sell the engine, you can't make a business case for the cost of development and certification on the turboprop market by itself.
    Pratt is in no hurry to replace the PT6. It is the ultimate cash cow, paid for a long time ago and making money every day. The issue is, as it almost always is, more a matter of economics than it is technology. When somebody makes a move in the market, the others will have to jump in, but until that happens it's still a standoff. It's happening slowly, but it's going to happen.
  10. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    #35 Jason Crandall, Apr 17, 2011
    It makes more than 250 in the mid teens if it makes 500 at sea level.
    But yes, recipes are much more efficient. Just not as sexy.
  11. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Well, it would if it was capable of running at takeoff power at cruise. Unfortunatley that isn't the case. About all it will do at 16,000 ft at takeoff power is about 270 hp, (take the pressure at that altitude, add ram pressure, divide by 14.7 and multiply that factor (.54) by the sea level static horsepower) but that's assuming you can cruise at 100% power, which in that engine you can't. As I said, it depends on how it was rated and what percentage of the rating you can use for cruise. If you ran it at 80% power at 16,000 ft, you are only getting 215 hp, which is, like I said ealier, pretty anemic.
    Sexy, yes and it makes a nice turbine whine, but don't plan on going very far or very fast with one. At altitude with a turbo recip (and yes they aren't sexy), you will be able to get 260-300 hp and that translates into cruise speed. With 215 hp in a four place retractable at 16k, you are looking at something like maybe 230kts cruise. You gotta want a turbine really bad to pay $150k more to go slower and burn more fuel. I'm sure there's a market for it, but it's pretty limited.
    For a four place single turbine, you pretty much need an engine rated at about 750 thermodynamic horsepower as a minimum, 500 isn't going to cut it. You can put a 500 hp gearbox on it to keep the weight down and flat rate it at 500 hp, but for that market you need a hot rod and be able to go much closer to 280-300 kts at altitude to justify the higher cost. A 750 hp turbine is going to cost almost the same as a 500 hp one. The parts aren't that much bigger, and a lot of parts (like the expensive fuel control) are the same pieces. While the actual cutting time on the machine tool is a bit longer (like 7%), setup time, inspection time and assembly time are the same.
    This is why, unfortunately, that engine isn't likey to find a home in an OE application. Mooney learned a hard lesson with the PFM series of engines. Customers want something for their money. Although the PFM was sexy and smoother and much more quiet than the Conti, when you pushed the throttle to the wall, it didn't go any faster and it wasn't any more reliable either. So in response to that they voted with their wallet and bought the the Conti.
  12. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    Got it.
    Didn't Mooney recently advertise development using the RR500?
    What engine does the Lancair Evolution use?
  13. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Mooney and RR jointly announced that they entered into a "cooperative agreement" to evaluate the RR500 in future products. My spies tell me that this is going nowhere for pretty much the above reasons.
    The Evolution uses a PT6-34 rated (not concindentally) at 750 thermodynamic horsepower for takeoff. It has a 560 hp gearbox on it, so it is flat rated at 560 up to about 13,000 ft. That's a pretty thirsty engine with an SFC in the .595 lb/hp-hr at takeoff power, and a bit higher at cruise. If you are crusing at 300 hp, you are looking at 180 lbs/hr, or about 25.5 gallons per hour. Cha ching....
  14. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    A Baron burns at least that. That's less than half what a PC12 or TBM burns. It's not bad.
  15. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    hey solo, great posts man ....you obviously are "in" the biz
    my questions are obviously out-side-looking-in, as thoughts for alternative directions possible ...it seems the biz is very slow to move, but i can understand better of NAA making things so expensive to certify, that it takes only a "sure thing" to attract investment
    funny you mention wax-diesel, because we've used diesel as "the" best choice for cold climate work, so i'd have thought it ideal for aircraft use ...i'm surprised to hear JetA cost, i actually thought it was far more, especially in comparison to diesel, even regular gasoline
    so what is the best direction for the aircraft industry to take? is it develoment on existing craft and engines to improve efficiency? is it to reduce the purchase cost of a new craft to enter service?
    is there any particular 'emerging market' (so to speak) in the aircraft world?
    ...i'm curious to know more great insight, thanks guys :)
  16. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Thanks, it's a tough biz in that you really need to have the vision thing down and have a lot of guts. As they say aviation is the best and fastest way to turn a large fortune into a small one..... The amount that it takes to cert any engine is so large that if you can’t make a business case it isn’t going to happen, and the market has gotten more fractured, that it is difficult to figure out where you can sell enough to make it pay off.
    I’m really not familiar with the LSA market. To me it’s kinda like a bugeye Sprite. It’s fun to run around the neighborhood in, but if you want to go a long distance it isn’t much fun. Good for training and bumping around the patch, but it isn’t what I’m interested in. I think it’s great for the hobbyist, but the limitations on speed don’t do much for me so I lose interest.
    If you look at what Cirrus and Columbia did it was pretty amazing. In a very short time they totally changed the look of GA airplanes. That said, a lot of low hanging fruit in airframes went away with the change to composites, and that hasn't slashed the cost of airframes. If somebody would figure out how to stamp (or superplastic form) and then inexpensively JOIN aluminum, you might have a way to cut the cost of airframes down a lot and that would be a game changer.
    Not to be too parochial, but propulsion will have a lot to do with what comes next in the four and six place single engine market. Airframes using the existing engines are pretty well optimized. You could put retractable gear on a Corvalis and make some more improvement, but it won't be huge. If you look at the price point for these airplanes the incremental cost of a new generation of turbines will add about $120-150k to the selling price and that is probably a price point that would sell. Cessna and Cirrus have sold a lot of airplanes and those customers would have something nice to move up into. With good SFC the useful load and range would actually improve relative to the existing turbo recips. Think of an Evolution burning 18 gph going more than 300 kts in the mid teens with a slightly pressurized cabin. I think something like that is doable with the emerging technology and it would probably sell over 200 units a year for a number of years.
    I was always in love with the Epic aircraft, they really nailed it with that airplane. If somebody could get something like that certified, it would be a strong seller. If Klapmeier can get his version certified it will sell. Would like a potty in the plane for that price, but if it’s fast enough maybe you aren’t up there long enough for it to be an issue.
    If there were a 250 hp diesel that didn't weigh a ton (ok, well 1/4 of a ton) I think that would have an impact on the lower end of the market.
    Direct injection gasoline technology could also make a diesel less attractive. There are already spark ignition outboards that can run on JetA and that would allow a much lighter engine than a diesel if you wanted to run jet fuel.
    What happens with unleaded avgas will also shape what happens. If Swiftfuel is adopted you will have 100 octane and a direct injection smaller bore engine could run a compression ratio of 11 or 12 and have nearly the sfc of a not too hot diesel. Think of a 360 cu in aluminum small block turning at 2600 rpm making 250 hp (I'm no fan of geared engines). It will be little lighter, could live a long time and the cost might be 60% of a lycosarus if it was based on auto technology. Lower cost motors would go a long way to making aviation a lot more affordable.
    Sorry for the long post, kinda rambling here.. The biggest impact will come if costs come down a lot compared to what they are now. Green is nice, but I don't think it will drive the market. Initial cost improvements will have a bigger impact, and lower operating costs are nice too, but will take second place to initial cost.
  17. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    that's amazing insight
    i'm obviously not a aircraft maker (nor ever will be) but i'm genuinely interested in how & where the aircraft market is going
    i don't know that "greener" was correct for the thread title, but overall it is a pressure on all markets, and us all in general, given limited resources of petroleum, and environmental impact an exponentially increasing concern worldwide.....although aviation is only one small area, all areas (auto, industry, etc) are all contributors.....i myself am not a hardened 'enviro-mentalist' LOL but i do think it's a concern in all aras of life to some degree
    okay, back on subject....
    i agree LSA isa niche group, and in general aviation industry the big stuff has a rather obvious course, it's really the middle market that i think has opportunities
    the commuter charter is one i think (IMO?) or the "air taxi" as-it-were, bypassing large ports and waits, for localized trips, like state-to-state or like mid-west to east-coast
    i don't know how aviation segments the sized aircraft groups exactly (ie. 6 passenger, 14 passenger, etc) but it seems to me a growth area if can be made economically priced, in large part to efficient fuel use design with low purchase price and maintenance costs
    for joining aluminum, there are a few technologies out there now, like the stir-welding method, and even bonding adhesives (ie. lotus), used in conjunction with extruded-form aluminum ....the combination makes for lightweight and good strength, at low cost comparatively
    for none-jet engine tech, it seems to me the auto industry is a great place now to draw from, as engine tech has moved forward alot in past years ...i know there are companies now moved past the subi flat-4 engines, offering LS V8 engines for retro-fit into aircraft, which to me makes alot of sense, lightweight, great power-weight output
    example, a mustang GT of 10 years ago, is out powered by a current v6 'stang by almost 100hp!
    for diesel piston craft, i've only found limited work out there being done, mostly 4-cylinder and up to 200hp range (so far), though rumors are of v6 and v8, up to 300 and 400hp range coming
    to me, this is an area that the vw/audi engine group could really get into, using thier already existing aluminum block diesel engines as a starting base ....if they were so inclined
    as you say though, that any airport fuels are marked up ....why is that? simply because they can?
    i know we can get drums of avgas, and even easier diesel, up north, and so with any rural location, so access is not an issue ....in conjunction with lower cost (which adds up quickly when even only cents/liter difference) and more efficient engines, low rpm + torque, is why i thought it would make a great aviation alternative use fuel
  18. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    #43 JeremyJon, Apr 19, 2011
    i was just looking up info on these as you mentioned them, is this one you mean?
    http://www.epicaircraft.com/LT.html
    interesting for sure, a carbon composite fuselage, and an existing pratt-whitney engine ...is this not a certified design? ...it seems like they are selling (or intend to) the LT lists an asking price of 1.9 million, for a 6 seat aircraft (requires assembly)
    http://www.epicaircraft.com/LT_images/LT_parts.jpg
    this is the most recent info i found on Klapmeier and his kestrel aircraft program
    http://www.aopa.org/oshkosh/oshkosh10/news/100723klapmeier.html
    http://www.kestrel.aero/aircraft.html
    these two designs are very similar ....are they in a high sales area segment of the medium market? ...or did you mean the jet driven 6 pass craft?
  19. Jason Crandall
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    #44 Jason Crandall, Apr 19, 2011
    Yeah, the Epic is great but not certified. The certified version will be more and if that's the case, I'd rather have a TBM850 made of metal. I used to have an SR22 and I'm no fan of composite. Too feeble (at least what Cirrus uses is). What Cirrus calls composite, I call fiberglass.
    I've seen a couple Epic's but I wouldn't say they've sold too many. Over a $1M for a non certified 6 place, pressurized home built is not a big market.
  20. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    All very true. The Epic isn't certified and at $1.9M with a lot of assemby required you aren't going to see very many around. I've been through the Cirrus factory and it's not built as tough as a metal airplane. That's why I'd like to see a real metal airplane that didn't cost an arm and a leg.
    I've seen friction stir welding and it sounds like a great thing, but it's a lot harder to do in practice than with two flat pieces clamped to a table. When the Eclipse started using FSW, it was supposed to be the holy grail and was going to cut the cost of the airplane to where they could make them for what they had sold them for... Well, we all know that didn't happen and the biggest reason that that Eclipse failed was that they couldn't sell what they were building for what it cost to build it. For what ever reason, schedule, tooling development, strength, I don't know, but if you look inside the hull of the Eclipse all of the stuff below the floor was put together with a bizillion rivets and looked pretty conventional.
    Aluminum is a bear to bond together, it forms an oxide very quickly and that makes bonding difficult. I know that everything from the GA Tiger to the Cessan Encore and all the way to 777 have bonded stuff, but it really isn't cheap. If you want to make a lot of money in aviation, figure out how to connect thin aluminum to thin aluminum without expensive bonding, causing no distortion and do it for pennies per length of joint... People a lot smarter than me have been racking their brains on that one for a long time and still haven't found anything better than rivets.
    Composites are cheap in boats, but somehow in airplanes they got a lot more expensive. And Cessna learned an expensive lesson in quality control of composites when they sent the wings of the Corvalis to Mexico and got back some junk parts.
    I used to have a T shirt that said: I know there's a lot of money in aviation, I put it there... True then, true now.
  21. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    i read the eclipse is being (sort-of) built still, through 'total eclipse' ....i was going to say, that seems to be the financial way by picking up an already good certified craft, in thier case the company went under bankruptcy ....then again, shows how depressed the market is, for that range of aircraft, so might not be a 'smart' investment
    i can undersand the aluminum bonding problem, i've seen it 'powder' over immediately when exposed to air ...lotus and such have only relatively small areas of contact to bond, so is not really such an issue
    if the idea of composite fuselage a preception issue some what maybe? i just mean that it always feels stronger when there is some weight to a vehicle, yet with CF the structural strength is there
    for boats of course, there isnt the high degree of consistant materials layering or maybe too the higher cost materials to use, so cheaper ...many boats are still f-glass, no kevlar or CF in them
    to bad a wing profile couldn't be extruded, then small supports bonded inside ...even a slightly thickness, could allow for fewer internal supports?
    .....i'm not an engineer, so don't shoot me! LOL
    is the air taxi business working or growing at all? i dont know anything about it, but it seems to make sense from a "get around long wait times" & short haul perspective
  22. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    You mentioned an extruded wing profile. This was done by Lockheed on the Electra. They extruded the skin and integral stiffeners as a rolled up tube. When cured, they sawed the tube's outer skin lengthwise and flattened the curled up item to become a wing skin with integrally formed stiffeners. The problem with that kind of thing is that you cannot taper the thickness of all materials as you go out to the tip so you're carrying around stuff that you don't need....weight.
  23. Tcar
    Tcar F1 Rookie
    So do they have to do the bonding in a non-oxidizing environment... maybe a nitrogen environment?
  24. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    They typically don't because you would have to protect the part from the air from when it was last cleaned until it was coated with the bonding agent. I understand they do it with coatings or abrade it after the bonding agent is applied. Either way unless the process is controlled carefully you can end up with bad bonds and that gets expensive if you have to redo it.
    If you are a big company with expensive equipment you can do it successfully (Boeing and Cessna do it all the time), but it just isn't cheap. Once you get the two parts together, they have to finally cured in an autoclave at temperature. I've been in the Cessna facility where they were doing parts for the Encore and they had huge autoclaves for doing fuselage parts.
  25. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    agreed, i'm no engineer, but then they can do some amazing things now, including they have come a long way with the extrude technology
    they can extrude really thin profiles now, and include internal bracing in the pattern, of course it's limited to being a 2 dimensional die, the one feature is that an extruded form like that would also have the inherent strength of being a single form (no seams)
    it's an interesting idea to throw out there ....of course, if not for a wing necessarily, could be used in other ways?
    oh, in some interesting lotus engineering literature i was reading, they start with an extruded form, then use hydro-forming to change the shape into a non-linear form (ie tapered, curved, etc) and stretch the skin to be much thinner ....kool! :)
