Greetings. Need help with BBi distributor parts !! | FerrariChat
Discussion in 'Boxers/TR/M' started by ralfabco, Apr 19, 2005.
  1. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Greetings.
    I am looking for a complete set springs, pins, and little buckets for mechanical weight in distributor. 4 X
    Car is a 1983 BBi (BE car)
    The parts should also be the same, as used with the 400i.
    PLEASE HELP. I miss the Box !!
  2. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    Have you tried the owners site?
  3. chevalcabre
    chevalcabre Formula Junior
    Nov 2, 2003
    893
    Montreal
    Steve Maman
    623-780-2200
    simply take it apart..carefully.... use parts cleaner...clean everything...gt car parts has the weights.... reinstall... you are getting no advance.... they are seized or glued with old oil etc....i do them with my eyes closed at this point... call me if you need more help. pesach kasher ve-sameach.
  4. henryk
    henryk Formula Junior
    Dec 9, 2003
    479
    Door County, WI
    My 83 BBi's distributor froze on me, last year. I cleaned and lubed it. I did have to machine a couple of bushings...........those "plastic" ones that turn the advance. They where worn thin, and one was cracked. I used "oil-impregnated" bronze stock. It worked fine.
