Gremblins in cooling fan circuit....Help! | FerrariChat
Discussion in 'Technical Q&A' started by Hozer, Dec 13, 2004.
  1. Hozer
    Hozer Rookie
    Feb 7, 2004
    1
    Novato
    Jeff Toquinto
    Hi! I'm new to this site and would first like to say, Thanks to all of you who keep this site going. Now, The big question; My alternator went south first, killing the battery as well. I've had the alt rebuilt and replaced the battery. upon my first drive the car overheated. No fans! I,ve checked the fans and they do work, one fuse has power the other not. Top of fuse block on that fuse looks just a little melted. Now when I tried connecting the wires off the radiator fan switch [or temp sensing switch] and key on... nothing. Next; after opening up the relay panel and swithing out relay, still no fans. Now after removing one of the relays and manualy grounding out one pin, Hey I've got fans. I would appreciate any advise before I get into replacing the relay panel or fuse block. Thanks, Oh, If it matters the beast is a 1975 308gt4.
  2. thecarreaper
    thecarreaper F1 World Champ
    18,124
    Savannah
    my 308 has been doing the same thing. i have power at the fan switch. i put in a new switch, the car has new QV fans and relays and still they do not come on.
    i am using the toggle switch method straight to the fans until i have time ti figure it out. must be the freaking fuseblock.
    i am redoing the rear axles and wheel bearing with the help of a few freinds. then i can drive it more and address the problem further. its almost as if something in the relay panel is not sending the signal back to fans to turn on.......... ?
  3. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Ain't it hard to remember that you came to drain the swamp when you are up to your armpits in aligators???
    Viva Enzo,
    chris
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    The fuse blocks on the 308s are TERRIBLE. They totally suck. Replace them with modern versions and all the electrics will work better. There are several threads on this. The design is lousy in several respects. I used to have the same fan problem. No more.
    Birdman
  5. 348SStb
    348SStb F1 Rookie
    Hozer,
    Before you get hazed in a hostile manner by a pretentious member of this forum, I will say it in a kind way.
    Please fill out your profile so that others may get to know you better and may provide better help to you. :)
